| Posted: Sun Jan 12, 2014 10:58 am Post subject: |
I reserve the right ot form my own opinion
If you really have to heighten the projector that would push the decision towards the smaller projector... from the description the G70 has the worst tubes, and they are amongst the hardest to find in good shape, even rarer, than the 1292 tubes.
TTHD
| Posted: Sun Jan 12, 2014 6:12 pm Post subject: |
| gjaky wrote: |
I reserve the right ot form my own opinion  |
It's your opinion which interests me
Yes, I have to heighten the projector... No other choice... But my first objectives are the quality of image and the possibility of installing the machine for a long time. The tubes of the G70 are the worst, you're right.
Thanks for taking the time
| Posted: Sun Jan 12, 2014 6:30 pm Post subject: |
But be aware that a raised 1292 would be more like a bunker or pool table rather than a coffe table in front of your couch
TTHD
| Posted: Sun Jan 12, 2014 6:47 pm Post subject: |
| gjaky wrote: | But be aware that a raised 1292 would be more like a bunker or pool table rather than a coffe table in front of your couch  |
It's one of my fears... I even wondered if I could really install a big CRT projector. But I want it
| Posted: Sun Jan 12, 2014 6:59 pm Post subject: |
| TTHD wrote: | | gjaky wrote: | But be aware that a raised 1292 would be more like a bunker or pool table rather than a coffe table in front of your couch  |
It's one of my fears... I even wondered if I could really install a big CRT projector. But I want it  |
I also have a raised floor front projection setup, on the top of that the room is not a dedicated theater room, and it has a longish shape and I am forced to project across, so the least ideal setup to say that, but I'm lucky to have a NEC PG xtra, because it has one of the best size/performance ratio of all CRTs.
TTHD
| Posted: Sun Jan 12, 2014 8:35 pm Post subject: |
I see that I'm not the only one to have ''bad'' install conditions!
Here's a pic of my dedicated room.
I'm thinking about the way I can make an effective and practical hushbox, adapted to my constraints
TTHD
| Posted: Thu Jan 16, 2014 6:27 pm Post subject: |
Hi everyone,
After some e-mail discussions with the seller, I'll buy the Sony 1292. He wants to keep his G70 (because of its design and its size) and doesn't still know if he's going to sell his 1209s.
Does anyone know some examples of crt projectors owners who have built a husbox (coffee table design) for an heightened one?
Best regards.
| Posted: Fri Jan 17, 2014 1:12 am Post subject: |
Build a coffee table and raise the couch and run ducting undr it and a fan on the end to get rid of the heat.??
TTHD
| Posted: Fri Jan 17, 2014 9:23 am Post subject: |
I know the theory! My question was more "practical".
When I use my BG808, I have to heighten it at 17" from the ground. It will be the same with the 1292 but the Sony ; that means that the top of the projector will be at around 30-32" from the ground and even more the hushbox.
So I'm looking for some ideas of "attractive" solutions ...
stridsvognen Guest
| Posted: Fri Jan 17, 2014 9:25 am Post subject: |
Lower your screen.
fragzero
| Posted: Fri Jan 17, 2014 9:34 am Post subject: |
Why can't you put it on the ceiling? I know you said you couldn't but your room does seem to allow it?
TTHD
| Posted: Fri Jan 17, 2014 10:45 am Post subject: |
| stridsvognen wrote: | Lower your screen.  |
TTHD
| Posted: Fri Jan 17, 2014 12:22 pm Post subject: |
| fragzero wrote: | | Why can't you put it on the ceiling? I know you said you couldn't but your room does seem to allow it? |
The ceiling (in drywall) is at 12 feet, suspended from 5 feet of the roof framing. The ceiling is tilted at the back of the room and the digital projector Panasonic fixed at this place, at 21 feet of the screen.
I can't tinker my ceiling to install the 1292.
fragzero
| Posted: Fri Jan 17, 2014 2:49 pm Post subject: |
While possible it sounds like a daunting task to install a 1292, i wouldn't dare to try it.
Although hiding the 1292 in the ceiling does sound nice
TTHD
| Posted: Fri Jan 17, 2014 4:31 pm Post subject: |
| fragzero wrote: | While possible it sounds like a daunting task to install a 1292, i wouldn't dare to try it.
Although hiding the 1292 in the ceiling does sound nice  |
I'm an adventurer!
I'm dreaming of a good CRT projector for a long time.
I "just" have to find an attractive solution for a ground installation.
| Posted: Sat Jan 18, 2014 6:06 pm Post subject: |
| TTHD wrote: | I'm an adventurer!
I "just" have to find an attractive solution for a ground installation. | I almost never say this, but that's a nice room, and I would not screw it up by parking a small automobile in the middle of the room. If you want CRT performance and pic quality (without the 13 fans of the 1292 creating a Hurricane in your home theater) get a JVC RS65.
TTHD
| Posted: Sun Jan 19, 2014 6:25 pm Post subject: |
| draganm wrote: | | TTHD wrote: | I'm an adventurer!
I "just" have to find an attractive solution for a ground installation. | I almost never say this, but that's a nice room, and I would not screw it up by parking a small automobile in the middle of the room. If you want CRT performance and pic quality (without the 13 fans of the 1292 creating a Hurricane in your home theater) get a JVC RS65. |
Hi dragan,
Tanks for the compliment.
I know you're probably right but I want to test a good CRT projector and take some fun to settle it.
Furthermore, the RS65 is a bit expansive for me!
I'll try with the 1292. If the results aren't satisfactory, I'll install it in m'y bedroom.
napos
Joined: 21 Oct 2006 Posts: 164 Location: Athens, Greece
| Posted: Mon Jan 20, 2014 12:42 pm Post subject: |
Having used my Marquee 8500 since 2003, I would definitely recommend it as far as reliability. I have only had to perform one repair on the horizontal deflection module during all those years and having upgraded the neck boards and the video input module with Mike Parker modifications, I can say that the image has improved tremendously. Add a Moome HDMI card to the mix and you are all set. Having seen your room I would definitely recommend that you place a Marquee on the floor and lower your screen. It is a shame to miss out on the CRT experience, plus lowering your screen will be more comfortable from your seating position on your couch. C'est domage mon amie, le Marquee est simple a configurer et utilizer et si tu trouves un 8500 avec des bonnes tubes, ca va fonctioner pour 10 ans.
Nicholas
_________________ Marquee 9500LC Ultra with MP mods, Moome HDMI 1.3 card, Lumagen Radiance XS, Oppo 83 BluRay, Toshiba XE-1 HD-DVD, HTPC with Media Player Classic.
TTHD
| Posted: Mon Jan 20, 2014 2:38 pm Post subject: |
Hi napos,
Thanks for your message.
I'm disappointed for the Marquee but the 1292 is a very good machine.
I can't lower my screen. It's a painted screen and it's at the right position in relation to my seating position (eyes at the median of screen when seated).
I'm going to take my time to find a solution to install the projector in an adapted hushbox, in spite of its complicated position.
Félicitations pour la manière dont tu t'exprimes en anglais et en français!
Bye.
napos
| Posted: Mon Jan 20, 2014 8:59 pm Post subject: |
Merci TTHD. How wide is your screen? The 1292 is not as bright as other 9" CRTs, so I would avoid going over 2.4m wide (106" diagonal in 16:9).
