New screen is up...
Posted: Thu Dec 26, 2013 11:30 am    Post subject: New screen is up...
... And its awesome. Huge step up in sharpness.
I havent finished setup yet, but ill get to that soon.
Had to move the projector back alot cause the new screen is somewhat wider.
HK-Steve
Posted: Thu Dec 26, 2013 11:53 am    Post subject:
We want pics.......
Great news on the bigger screen.
Posted: Thu Dec 26, 2013 12:13 pm    Post subject:
Yeah mate the contrast and brightness settings are now abit lower, using more tube width, picture is amazing.
Im now keen to go with a couple projectors and build a new room, probably go a 4.5 meter wide 2.35 screen, but itll be a while off.
Posted: Thu Dec 26, 2013 12:15 pm    Post subject:
One thing this CineMAX does is fill a big screen nice and bright, ill give it that!!
Posted: Thu Dec 26, 2013 2:29 pm    Post subject:
Great news Case!!!
Enjoy!!!
jeffslife
Posted: Thu Dec 26, 2013 4:08 pm    Post subject:
COOL !
We are ALL job creators !
jask
Posted: Thu Dec 26, 2013 9:32 pm    Post subject:
pictures please!!
Posted: Thu Dec 26, 2013 9:47 pm    Post subject:
Smile
Posted: Thu Dec 26, 2013 11:45 pm    Post subject:
Im at work!! Youll have to wait!! Laughing
Posted: Fri Dec 27, 2013 8:41 am    Post subject:
Ok, here it is, i just put the speakers back in the walls. Was going to raise the center one up abit but id have to cut the timber and also patch a hole.
HK-Steve
Posted: Fri Dec 27, 2013 12:28 pm    Post subject:
Looks Great. Well done..
Centre channel looks good where it is. leave it..
Do you get much reflection off the contents in the bookcases?? Lots of white in them.
Cheers
HK-Steve
Posted: Fri Dec 27, 2013 12:29 pm    Post subject:
Is that a turntable bottom left on the table??
Posted: Fri Dec 27, 2013 1:06 pm    Post subject:
Yep, Sherwood turntable there, awesome sound!!
Not as much reflection as youd expect, all those on the right are Master System and Mega Drive games. No where else for them to go cause my home isnt really very big.
Those speakers look quite low, but are pretty close to ear heightwhen laying back in the lounge to watch a movie. The tweeters are angled toward the listening position anyway.
HK-Steve
Posted: Fri Dec 27, 2013 1:09 pm    Post subject:
I suspected that the tweeters were adjustable from the look of them, Which speakers are they??
Dig a hole and bury the games..... joking... ha ha
Posted: Fri Dec 27, 2013 1:23 pm    Post subject:
Haha!! Those games are awesome fun!!
They are Jensen inwalls, nothing much special about them, but the sound from them is quite ok.
digitalayon
Posted: Fri Dec 27, 2013 5:48 pm    Post subject:
holy sega games batman!!!
Posted: Fri Dec 27, 2013 9:55 pm    Post subject:
Only thing left to do now is set up for 3D, but im still yet to find out what timings people were using for 1920x1080 @72Hz to get rid of that minor ghosting the nVIDIA glasses seem to have on a CRT.
Someone did say ( think is was NoosXP ) something about adding 100 inactive lines to the bottom of the image, which would almost certainaly go close to fixing it, but i am not sure what setting they are changing to do this.
Got the lense flapping dialed in last night and that too was way easier on this screen. The astig is abit out along the left and right edges, but ill get to that, its perfect everywhere else. Can very easily read the text in Windows on 1920x1080 very sharp and clear.
Posted: Fri Dec 27, 2013 11:08 pm    Post subject:
Though I have the older version of nVidia 3D kit (162.50 stereo drivers + wired glasses from VGA dongle) I have zero ghosting with standard 1080i-96Hz timings (that was experimented by kschmit2 back then), just thought to share as an interesting result.
Posted: Sat Dec 28, 2013 1:39 am    Post subject:
Mine are wireless yes, ive never done 1080i 96Hz, what timings are you using for that?
I have to ask cause on the newer nVIDIA drivers the default timings are changed in some cases.
Posted: Sat Dec 28, 2013 8:09 am    Post subject:
When I used the integrated intel VGA I have used exactly the same numbers what kschmit2 posted in on old thread (what I don't find now), after I'm changed to nvidia those numbers are not recognized by the projector as same source, so after some playing I came up with this. The Barco has shorter retrace than the PG so it should do this fine too.
Otherwise I seem to remember Marc said the ghosting is a result of sync delay, because of the highly different path for glass driver and the monitor output, if so this timing will also be ghosting with your setup, so you also should try to add those 100 lines at the end.
I haven't noticed any shortcomings of using an interlaced resolution for 3D.
New nvidia 1080i-96Hz timing
 Filesize:  48.17 KB
 Viewed:  6749 Time(s)
pstrip_1080i_96Hz.txt
Original 1080i-96Hz powerstrip profile
 Filename:  pstrip_1080i_96Hz.txt
 Filesize:  420 Bytes
 Downloaded:  161 Time(s)
