| Posted: Mon Feb 03, 2014 10:42 am Post subject: |
Sync is where their issue lies.
Analog, ive used it on both my 9PG and XG with no issues.
mookee
| Posted: Mon Feb 03, 2014 3:36 pm Post subject: |
so 9v battery minus to where please?
mookee
| Posted: Mon Feb 10, 2014 4:27 pm Post subject: |
after i tried the different combinations, as i wrote before, i didnt get any usefull signal anymore when i wanted to try it with 9 instead of 5volt. so i figured, well, messed something up, gotta do the whole circuit with a new lm1881 again, justz in case.. and now the same result-nothing useable, i mean nothing at all, not the good picture with the bad sync, just nothing than lines and flickering. it can be than i wirde the lm wrong, asit got no mark of pin 1 at all, nut i dont think so, and also, i had the same dead picture with my old circuit. wondering if i might shot my board. is there a reset button.. FUUCKK!!=)
mookee
| Posted: Mon Feb 10, 2014 4:29 pm Post subject: |
after i tried the different combinations, as i wrote before, i didnt get any usefull signal anymore when i wanted to try it with 9 instead of 5volt. so i figured, well, messed something up, gotta do the whole circuit with a new lm1881 again, justz in case.. and now the same result-nothing useable, i mean nothing at all, not the good picture with the bad sync, just nothing than lines and flickering. it can be that i wired up the lm wrong, as it got no mark of pin 1 at all, but i dont think so, and also, i had the same dead picture with my old circuit. wondering if i might shot my board. is there a reset button.. FUUCKK!!=)
| Posted: Mon Feb 10, 2014 11:19 pm Post subject: |
Wow you are having a time of it aren't you?
My only issue with the real cables now is the weak signal. I'll buffer that up through the Extron box next time I play with it. That SONY D50 likes a hotter signal.
| Posted: Tue Feb 11, 2014 2:25 am Post subject: |
Did you check the caps on your DEF board like i suggested?
