Squealing and buzzing Cine 9
Goto page Previous  1, 2, 3
Posted: Mon Oct 28, 2013 7:31 pm    Post subject:
Curt, focus lead was not able to move when I open the cover, was zip tied in place. I put 8 layers of heat shrink on it, but the issue remains, and it isn't this lead cause I left it hang out while I ran the set, and ran the back of my hand along it to see if it was capable of arcing, but nothing.
Posted: Mon Oct 28, 2013 8:33 pm    Post subject:
I'd still suspect HV issues, either the quad or splitter.
Posted: Tue Oct 29, 2013 2:10 am    Post subject:
I have two spare splitters, ones says blury the other i cant read. There is nothing but silence in the splitter area.
Posted: Tue Oct 29, 2013 5:36 am    Post subject:
Insulation on Quads breaks down internally. If you every remove it from the projector you will see one side different from the others and that material you would be looking at breaks down causing the hissing noise. If its not there or at the splitter and you seem to say the splitter is OK you could get some leakage at the tubes where the HT cable is attached but the noise would be coming from that area of the projector. Try another Quad if you have it.
the big E
Posted: Tue Oct 29, 2013 6:33 am    Post subject:
Case I know this may seem strange but I had a projection tv do about like this within a month the flyback went dead and was arcing internally even before it failed
Just a thought it may be in the hv power supply or a tube lead
Also now you know how I felt when my Ecp was doing this very same thing(except it would arc at random times with no warning) also I noticed the picture on the red tube would twitch and slightly lose focus I replaced the high voltage power supply it helped some but not a lot(never got the issue nailed down before the lvps bit the big one)
All you would hear was a LOUD SNAP and the alignment grid would pop up(not good when you a few feet from the beast)
crt king of black
Posted: Tue Oct 29, 2013 9:24 am    Post subject:
E its none of those things. Leads are all perfect. No arcing or even any sound comes from that section of the machine. It is all sectioned off.
I havent got a spare quad at this point. Not the leads, no arcing that end.
If there a way to insulate the quad? Has anyone tried it?
Posted: Tue Oct 29, 2013 9:38 am    Post subject:
I am sure there is a thread or two about this with a minor success. Its very difficult to do.
Posted: Tue Oct 29, 2013 9:40 am    Post subject:
Some information here
https://www.curtpalme.com/forum_archived/viewtopic.php@t=32488.html
Posted: Tue Oct 29, 2013 10:38 am    Post subject:
Thanks mate Wink Will have a read now.
the big E
Posted: Tue Oct 29, 2013 1:58 pm    Post subject:
I know but you now know how I felt when I had hv issues with my Ecp that's my point
crt king of black
Posted: Tue Oct 29, 2013 2:12 pm    Post subject:
try taking the quad off the side of the chassis. Float it in mid air, or as best you can. That might reduce/eliminate it.
Decibel
Posted: Tue Oct 29, 2013 2:30 pm    Post subject:
Curt ... I think that's impossible.
The quad have a multipolar wire very short that's connected to the main board.
Domenico (Barco fan!)
Posted: Tue Oct 29, 2013 2:32 pm    Post subject:
As long as he can get the metal plate away from the chassis, that will isolate that ground plate, and can stop some internal arcing.. sometimes. Some quads fail that way, and at least he can see if the issue is quad related. I've had both quads and splitters (and sometimes EHT boards) cause noise in the image.
Posted: Tue Oct 29, 2013 11:47 pm    Post subject:
Curt, will it work if i put a piece of rubber in there?
Youre tellin me nothing, i battled HV arcing issues 7 years ago on a Sony.
Posted: Wed Oct 30, 2013 4:25 am    Post subject:
I had a 2" purple arc on my Ampro 4000! Very cool!
Francisco
Posted: Fri Nov 01, 2013 8:36 pm    Post subject:
Hi Case, this is one of the most common problems of the 909 919 etc.
The quad you have comes from a 1209s or 808, it will work with cine 9 without problems. Friend of mine has it also in his Cine9.
But I bet this one wasn't new when replaced the original, so it's not a suprise if this one is failing now.
With my 4 x 919 I got also 5 defective quads and fortunate some spares as well.
Sometimes they start arcing internally, after a while it will also go outside and you can smell it too when that happens.
One of the defective quads arced so bad that it went black at all sides.
There's a guy which tried to repair quads but I don't think he suceeded. Rubber plate won't help you, the arcing and sound comes from within the quad and will come out soon or later or it will fail before completely. I would suggest you to buy a new one. Personally I think this is the problem. Splitters hardly fail and if they do you would have other issues.
Good luck!
ElTopo
Posted: Fri Nov 01, 2013 9:34 pm    Post subject:
The quad is the "cheapest" part of the Cine9.
Barco Cine 9 the one and only
Posted: Fri Nov 01, 2013 11:47 pm    Post subject:
Im on it, should have some spares soon. It gets limited use lately anyway as the XG is set up in my bedroom and now has its own HTPC as well. Ive get some screen material samples coming to test out, once everything is set i will throw a new set of tubes in the spare housings and get everything ready for a full brand new setup.
Im likely increasing the screen width to around 2.7m and changing to a 16:9 screen instead of the 5:4 aspect that worked so well with the XG.
Page 3 of 3
