linuxfox00
| Posted: Mon Sep 09, 2013 2:01 am Post subject: d50 no signal |
I just bought this a few days ago but i can only get component video though it now.
I have an hdfury and ive try to run a signal to it put nothing shows up. i have my input a setting set to hdtv- Ypbpr, and try rgb.
I ran a vga cable to it yesterday and it worked fine then i did a reset and now i can't get anything expect component video.
what am i doing wrong please help.
| Posted: Mon Sep 09, 2013 2:34 am Post subject: |
Try pushing "INPUT A"
linuxfox00
| Posted: Mon Sep 09, 2013 2:36 am Post subject: |
| AnalogRocks wrote: | | Try pushing "INPUT A" | yeah i did that its on input a
| Posted: Mon Sep 09, 2013 2:48 am Post subject: |
What's your exact setup? Do you have HDFury1 2 or 3? What source are you using?
linuxfox00
| Posted: Mon Sep 09, 2013 2:51 am Post subject: |
well right now i just wanted vga to work but i cant even get that going i have a rgbhv to vga and my pc was set to a minimal resolution and i had tried rgb and hdtv on input a video settings.
| Posted: Mon Sep 09, 2013 2:53 am Post subject: |
When you say you did a reset what exactly did you do?
linuxfox00
| Posted: Mon Sep 09, 2013 2:55 am Post subject: |
theres a reset button the projector it's self i held it for 20 seconds and it came up do you want to restore to factory defaults i hit yes
| Posted: Mon Sep 09, 2013 3:10 am Post subject: |
Oh no.....
| Posted: Mon Sep 09, 2013 3:24 am Post subject: |
| linuxfox00 wrote: | | theres a reset button the projector it's self i held it for 20 seconds and it came up do you want to restore to factory defaults i hit yes |
Ahhh never noticed that one. Of course I'm not with my D50 right now.
| Posted: Mon Sep 09, 2013 3:36 am Post subject: |
Is that cable a Bluejeans cable? Custom looking?
linuxfox00
| Posted: Mon Sep 09, 2013 3:43 am Post subject: |
no its like a really good one that looks like it may have came with the hdfury i have a really bad cable i got with my linedoubler only 3 of the 5 cables work with that.
and yes i have my pc set up with both outputs setting a signal so the output is on.
http://imageupper.com/i/?S0200010050011G13786979501728504
| Posted: Mon Sep 09, 2013 3:50 am Post subject: |
I recognize that cheap cable. Belkin isn't it?
I think you need to ask Curt on this one. I'd help you further but I won't have hands on my D50 'till next weekend.
linuxfox00
| Posted: Mon Sep 09, 2013 3:51 am Post subject: |
| AnalogRocks wrote: | I recognize that cheap cable. Belkin isn't it?
I think you need to ask Curt on this one. I'd help you further but I won't have hands on my D50 'till next weekend. |
Ok thinks for now I will probably just keep reading though the dealer setup manual for now and tinkering.
| Posted: Mon Sep 09, 2013 3:58 am Post subject: |
Which version of the HDFury did you get BTW?
linuxfox00
| Posted: Mon Sep 09, 2013 4:19 am Post subject: |
| AnalogRocks wrote: | | Which version of the HDFury did you get BTW? |
looks like v1 no power supply but when i bought it. the guy had it running hdmi though his cable box and it did work.
| Posted: Mon Sep 09, 2013 5:25 am Post subject: |
| linuxfox00 wrote: | | AnalogRocks wrote: | | Which version of the HDFury did you get BTW? |
looks like v1 no power supply but when i bought it. the guy had it running hdmi though his cable box and it did work. |
Only a few things can properly power the HDFury1 without the power supply. The three things I have are PS3 60gb, Xbox Elite, Samsung HDTV tuner. You may or may not have enough power in your source. Try it and see once you get the D50 back up and running.
| Posted: Mon Sep 09, 2013 6:19 am Post subject: |
There's no point in discussing anything until you get a power supply for the HDFury. About 80% of Fury issues are solved with the power supply. It's MANDATORY.
Sorry, that sounds rude and short, but you really do need it.
linuxfox00
| Posted: Mon Sep 09, 2013 2:24 pm Post subject: |
that still doesn't solve the no signal from vga, which im not running through hdfury
| Posted: Mon Sep 09, 2013 2:28 pm Post subject: |
True. Have you selected RGBHV for that input, since those RGBHV inputs also double as component? if you're in component mode, it won't recognize the RGBHV input. Are the H and V cables on the right BNC connectors? Does the VGA-BNC cable work? One broken sync line, and you won't get anything.
linuxfox00
| Posted: Tue Sep 10, 2013 1:47 am Post subject: |
yes the cable worked as of 2 days ago. I have tried to set it to all different setting in the inputs menu all that comes up on the bottom of the screen is existing input mem
