gnnash
Joined: 10 Jul 2013 Posts: 216 Location: Lake Elmo, MN
| Posted: Wed Oct 23, 2013 1:08 pm Post subject: |
Alright, I'll admit I was wrong. I played with the stripper again a little more last night. When plugging it in between my receiver and HDQ, I got all sorts of noise and dropouts.
I hit OK on the remote for the HDQ, to see what resolution it was getting. To my surprise, it was running with an input of 1080p / 60! The poor HDQ was trying its best to display something wayyy outside of its specifications, and must have really been working those DVI input chips hard.
After a bit of fiddling with the EDID, and a sequenced power up (turn everything off but the HDQ, then turn on the stripper to read the HDQ's EDID, turn on the receiver to read the EDID from the stripper, and then the blu-ray player to read the EDID from there), the stripper worked flawlessly, as my Blu-Ray player outputted 1080i on the menus, and 1080p/24 during movie playback.
So, the metal-cased version of the stripper does indeed work well for me, allowing me to output HDCP-protected material through the analog outs of my Lumagen HDQ.
stridsvognen Guest
| Posted: Wed Oct 23, 2013 1:30 pm Post subject: |
Thats good to hear..
| Posted: Wed Oct 23, 2013 2:21 pm Post subject: |
| gnnash wrote: | Alright, I'll admit I was wrong. I played with the stripper again a little more last night. When plugging it in between my receiver and HDQ, I got all sorts of noise and dropouts.
So, the metal-cased version of the stripper does indeed work well for me, allowing me to output HDCP-protected material through the analog outs of my Lumagen HDQ. |
If possible, can you set your BD player to 24Hz only? It's a bit nicer than switching between 1080i and 1080p 24Hz because the system won't have to re-sync so many times. Some BD players will allow "forced" 24Hz to keep the player at 1080p 24Hz.
Your current solution may work fine, but you may also find inconsistent results with EDID flowing up the chain so it may not work on every power up. The primary key as you have found is to make sure the Lumagen is turned on first and then follow the power on up the video chain. If you program a universal remote you can automate this.
gnnash
| Posted: Wed Oct 23, 2013 2:27 pm Post subject: |
Unfortunately no, I've played with the settings, and 24 Hz is only ever active when a 24Hz source is playing. The main GUI, setup screens, and online content apps seem to run at 30/60Hz. 24Hz is only an option that I can enable or disable on the player.
Fortunately the lumagen is the only thing that has to re-sync, and it's so fast to do so, I never even notice the change.
I intend to get a harmony remote eventually for this all, right now it's all in a state of constant change. I'll play some more after work tonight, hopefully the cheap splitter/stripper captures the EDID on its powerup, and maintains it, given the nature of how it seems to work. Since the stripper is always plugged in, maybe this will no longer be an issue. Until the power goes out, that is!
gnnash
| Posted: Wed Oct 23, 2013 2:34 pm Post subject: |
I believe I tried this before and it then outputted 480p when in the menus and such instead of 1080i, but I could have been turning things on in the wrong order. I'll try again tonight.
fragzero
| Posted: Wed Oct 23, 2013 2:35 pm Post subject: |
Afraid this does not work for all bluray players
stridsvognen Guest
| Posted: Wed Oct 23, 2013 2:41 pm Post subject: |
Yeah many players dont accept the Edit, like the Denon machines cant output 422 no matter how i put the radiance edit.
O cant wait to get my HDQ and test it with the splitter..
fragzero
| Posted: Wed Oct 23, 2013 2:55 pm Post subject: |
| Nashou66 wrote: | Oppo BP83.
Does the Oppo support 1080p24 on Bluray menu's and 480/576i through HDMI?
Seems like a great player to go with my HDP
stridsvognen Guest
| Posted: Wed Oct 23, 2013 3:03 pm Post subject: |
| fragzero wrote: | | Nashou66 wrote: | Oppo BP83.
Seems like a great player to go with my HDP  |
It will do what you like.. The 83 is my favorit BD player..
Ups.. It will not hold 24hz out on menu and BD startup, even if i put the radiance edit to just accept 1080P 24hz and set the oppo to convert to 24hz, think it only works for DVD.
| Posted: Mon Nov 04, 2013 10:25 pm Post subject: |
| stridsvognen wrote: | I ordered one, and its getting shiped to Craig from China.. Shipping 1$
https://www.ebay.com/?mkcid=1&mkrid=711-53200-19255-0&siteid=0&campid=5336656890&toolid=20008&mkevt=1
20$ total with PS and shipping.
Then Craig can scope the output, and tell us what the quality of this thing is.
I think we have to be carefull when judging HDMI product, the problems are more complex than most of us understand, and the problem are sometimes not in the unit we blame.
HDMI and HDCP is a pile of crap.. i can only think of DVI being worse. |
It got here while I was in Texas and is sitting on the bench. I will try really hard to find time to evaluate it this week. It might have to wait until after I get back from Californian though.
Thanks for sending it Kurt.
stridsvognen Guest
| Posted: Mon Nov 04, 2013 10:33 pm Post subject: |
| CIR Engineering wrote: | | stridsvognen wrote: | I ordered one, and its getting shiped to Craig from China.. Shipping 1$
craigr |
Your welcome.. hope its working, and looking forward to hear about your results.
| Posted: Mon Nov 04, 2013 10:44 pm Post subject: |
| stridsvognen wrote: | | CIR Engineering wrote: | | stridsvognen wrote: | I ordered one, and its getting shiped to Craig from China.. Shipping 1$
craigr |
Your welcome.. hope its working, and looking forward to hear about your results. |
No idea if it works. Still in the package.
stridsvognen Guest
| Posted: Mon Nov 04, 2013 11:10 pm Post subject: |
i played with mine on the HDQ, and it worked fine, but i prefer not to use the HDQ RGBHV out-.. looks like it wont handle the 1080P 60 hz bandwidth to well.
| Posted: Sat Nov 09, 2013 8:31 pm Post subject: |
So I haven't used or measured it yet, but I just took it apart. They are using the Explore EP9132 HDMI splitter, ST 8S003F3P6 microcontroller for "HDCP," and the Atmel 2C08N for storing EDID data. The only thing really of interest here is the Atmel because they are easy chips to write with a basic EEPROM programmer and thus can be customized. If you are having trouble with EDID and this splitter it would not be difficult to modify. I used the same chips when I was developing the 3D for CRT to force sources to recognize my CRT as 3D capable.
The solder flow is low quality, but better than I might have guessed for $15.
I'll do some testing in a bit if I have time today. Here are some photos.
| Posted: Sat Nov 09, 2013 10:01 pm Post subject: |
All right, this thing is flipping awesome, I love it. Everything works nearly perfectly with this little splitter.
1:1 Pixel Mapping
Black Level
White Level
Passes RGB, YCbCr 444, YCbCr 422
Passes 3D
Passes Custom Resolutions
I can't find anything to complain about. The only minor issue is that the color decoder is not perfect. It is the closest with YCbCr 422, but it is very close with all types.
The device does report as HDCP compliant to the source and then strips HDCP from the output
I ran this splitter with 1080i on the input, 1080p 60Hz on the input, 1080p 24Hz on the input, 1080p 24Hz 3DFP on the input. I ran 1080p 60Hz on the output, 1080p 72Hz on the output, and 720p 96Hz on the output and it worked perfectly with all. My 720p 96Hz is using 195MHz digital bandwidth so it's really pushing the limits of HDMI and the thing passed it!
There is no default EDID on the splitter so you can forget what I said about reprogramming the EDID. The splitter seems to capture the EDID data from the display device (output) and then emulates (copies) it to the input of the splitter. This is actually typical behavior from a splitter and most likely it will favor output 1 or 2 for EDID capture depending on how the builder programmed it.
Something kind of cool... With a minor modification to the board, the splitter could actually be used to capture and then emulate EDID from any display device or a Lumagen. This would be done by enabling write protect to the Atmel 24C08 on pin six by connecting to VCC. A simple jumper could be installed to switch pin 7 between VCC and ground.
This splitter will probably also make an excellent HDMI extender since it can handle such high frequencies as well. So this splitter is a splitter, EDID emulator, and extender all for $15.
Here are the technical readouts from the splitter to my QD780.
Running Oppo BDP-103 to Splitter to QD780:
QD780 screen shown.
QD780 screen shown.
QD780 screen shown.
QD780 screen shown.
QD780 screen shown.
Running QD780 to Splitter to Lumagen:
QD780 screen shown.
Running Lumagen @ 195MHz to Splitter to Display:
G90 screen shown.
Last edited by CIR Engineering on Sat Nov 09, 2013 11:25 pm; edited 1 time in total
stridsvognen Guest
| Posted: Sat Nov 09, 2013 10:07 pm Post subject: |
Looks nice Craig..
Maybe you understand why some think its a quite nice toy to have around.. Specialy with the price in mind.
I consider it the chepest way to conect a blu ray player to a VP and output RGBHV analog, for sure a nice start to anyone with a cheep CRT projector and a old VP with RGBHV out.
| Posted: Sat Nov 09, 2013 11:34 pm Post subject: |
| stridsvognen wrote: | | i played with mine on the HDQ, and it worked fine, but i prefer not to use the HDQ RGBHV out-.. looks like it wont handle the 1080P 60 hz bandwidth to well. |
The HDQ should be excellent with RGBHV at 1080 60Hz and 72Hz. Look at it on a scope and on screen with a 1:1 pattern and you will see almost no attenuation at all.
stridsvognen Guest
| Posted: Sun Nov 10, 2013 8:27 am Post subject: |
| CIR Engineering wrote: | | stridsvognen wrote: | | i played with mine on the HDQ, and it worked fine, but i prefer not to use the HDQ RGBHV out-.. looks like it wont handle the 1080P 60 hz bandwidth to well. |
craigr |
I did a lot of testing, and was talking with Jim about that, and the HDQ will not do 1080P 72 hz with 1:1 pixel mapping, and running 1080P 60hz, around 160Mhz, the vertical lines did role off to early, so i used the DVI out instead to the moome card, looked better.
And i have other VP that resolves 1080P 60 hz with no problem using the same RGBHV cable and input.
If you know a way to setup 1:1 pixel mapping and run 1920x1080P 72hz RGBHV out ill love to know how.
