Astig on the Cine 9...
Goto page Previous  1, 2, 3
the big E
Posted: Sun Jul 21, 2013 3:36 am    Post subject:
I also want to know that as my Ecp does drift some on convergence after it has warmed up
crt king of black
Posted: Sun Jul 21, 2013 4:21 am    Post subject:
It varies on different machines, im refering to Barcos. What youre seeing is normal, im interested in the time before touchup is required, hopefully in months, as this is what i expect from an NEC.
the big E
Posted: Sun Jul 21, 2013 4:50 am    Post subject:
I know of corse my nec may not need any touch up after its warmed up if I can get it to where I can use it
I haven't noticed my 10pg to drift before it did like it has so it may never drift but only time will tell
crt king of black
Posted: Sun Jul 21, 2013 6:43 am    Post subject:
My 9PG never did much at all, even after 6 months it was pretty much right where i left it. I was using most of the tube face and very little keystone, but using such a big area on the PG did require a fair amount of pincushion and a reasonable amount of point was also used where main convergence settings did not quite have the range. It was always solid as a rock and ran that way for over 2 years without a hitch.
Phoenixed
Posted: Sun Jul 21, 2013 8:21 am    Post subject:
My G90 wandered a lot. I wonder if its an upper echelon 9inch thing. No offense to anyone.
Planar PD-8150/Runco LS-5
Posted: Sun Jul 21, 2013 9:03 am    Post subject:
So how long is a reasonable time with no drift to be considered normal? And how far out of alignment do you consider to be acceptable?
I am still wrestling with a perfect mechanical setup since my projector is not standard. I don't like drift any more than the next person so I will continue until I get a perfect mechanical setup and then I will let you know if it drifts. To this end I am fitting a another LC setup. I suspect drift won't be a major issue if the electronic convergence is only performing minor corrections.
Posted: Sun Jul 21, 2013 10:14 am    Post subject:
I know your machine is pretty far from stock yes, and i do agree totally that the less electronic correction the better, but id love to know where the drift during warmup is coming from since my PG didnt really do it at all and the XG was extremly minor and only on red, which due to previous owner over tightening the long pins that hold the red in place one was broken and the red tube moved slightly from cold to warm.
Everything is tight on the tubes and the housings are all tight, but i dont think its that cause its not all over the whole screen that it moves.
Posted: Sun Jul 21, 2013 10:27 am    Post subject:
Old caps perhaps on your convergence board??
Posted: Sun Jul 21, 2013 1:37 pm    Post subject:
In a Cine 9???
Posted: Sun Jul 21, 2013 10:43 pm    Post subject:
In a Cine 9???
Yeah sure. I think if you read any references in this forum to Cine/909 you will find Curt and Craig and MP talk about poor quality caps in this projector. I believe Curt replaces certain Caps when he sells a Cine/909 projector. I don't know if they are convergence specific caps but I am almost certain the are SMPS caps and as you know that can effect all manner of things including convergence stability.
You would know far more about ESR than most so perhaps could could use an ESR meter to check some caps.
Posted: Mon Jul 22, 2013 1:13 am    Post subject:
Hmmm... Roger that, i might have to check it out i guess, never expected it would be an issue in one of these...
ElTopo
Posted: Fri Aug 09, 2013 9:56 am    Post subject:
Checked convergence on the Cine9 i have here.
After the setup i disconnect from A/C for some hours.
Convergence is rock solid after powering up again, no drift at all.
ElTopo
Barco Cine 9 the one and only
Posted: Fri Aug 09, 2013 1:03 pm    Post subject:
that is exceptionally unusual in any CRT, IMHO. The 909/Cine chassis is known for overall drift, but only certain zones... man, I'm not sure.
FYI, the convergence is all digital, stored on the system board, until the very end stage, where D/A converters change the data to analog. I can't see it being the system/controller board as a result, and I haven't had those issues on the convergence output board either.
To eliminate the focus and astig boards, disconnect the wire harnesses going between them. That will disconnect those boards from the tubes in essence, and you'll be out of astig and focus, but you can still track whether the convergence stops drifting in the affected areas.
Posted: Sat Aug 10, 2013 1:42 pm    Post subject:
Yeah mate its sharp all the time right from cold start, but convergence is out for a good 30-45 minutes.
Page 3 of 3
