ElTopo
| Posted: Thu Jul 11, 2013 8:46 am Post subject: |
The Cine9 will definately be SHARPER in comparison to a 9PG !
The is the TOP of the mountain, enjoy
| Posted: Thu Jul 11, 2013 11:40 am Post subject: |
| ElTopo wrote: | Was it shipped with a roadcase ?
Does the projector had any errors/bad boards in the past or still in it's original condition ?
ElTopo |
Some items have been replaced, including the splitter, ive got 2 spares in unknown state. Also 3 brand new HV leads.
There is a screen shot there of the green tube with failures and voltages pages.
| ElTopo wrote: | The Cine9 will definately be SHARPER in comparison to a 9PG !
The is the TOP of the mountain, enjoy  |
Yeah, its replacing an XG though
I will have to take abit of a guess at how far back i have to put it from the screen, its abit big to lift up and hold!!
| Posted: Thu Jul 11, 2013 11:41 am Post subject: |
Screen is 2270mm wide.
ElTopo
| Posted: Thu Jul 11, 2013 2:04 pm Post subject: |
If you have HFQ 900 you can use the Barco lens program
http://www.curtpalme.com/docs/Barco_lens_V15_1_full.zip
It gives you an estimate about the distance. But in reality you have to check for full raster usage on the tubes and then move forward backward and check if you can get focus in the middle and on the edges.
Are you using a 16:9 screen ?
ElTopo
| Posted: Thu Jul 11, 2013 11:23 pm Post subject: |
Yes HQF900, i tried the lens program but it doesnt work on x64 Windows.
ElTopo
| Posted: Fri Jul 12, 2013 10:32 am Post subject: |
Could you please take a pic(s) of the fans in the back and how they are connected ?
I wanna compare it to my CineMax i have here.
thank you very much
ElTopo
ElTopo
| Posted: Fri Jul 12, 2013 10:42 am Post subject: |
Would be great to have a pic of your 13/1 section.
Only Fan1 is conected at your Cine9 on that section ?
ElTopo
| Description: |
| Filesize: |
443.38 KB |
| Viewed: |
4410 Time(s) |
| Posted: Fri Jul 12, 2013 11:04 am Post subject: |
Can i do that for you tomorrow?
ElTopo
| Posted: Fri Jul 12, 2013 11:30 am Post subject: |
Sure thx
| Posted: Fri Jul 12, 2013 11:36 am Post subject: |
No problem, itll be going up on the ceiling tomorrow night, so ill do it for you before that
ElTopo
| Posted: Mon Jul 15, 2013 10:07 am Post subject: |
Hi again,
you had the time to check the fan connections on the back ?
Maybe you have a picture you can post ?
thanks
ElTopo
| Posted: Mon Jul 15, 2013 11:52 am Post subject: |
Yes, i took a picture for you when i had it on the bench, i will post it shortly for you. Sorry for the delay!!
| Posted: Mon Jul 15, 2013 11:56 am Post subject: |
Dont know how much youll see off this...
ElTopo
| Posted: Mon Jul 15, 2013 1:01 pm Post subject: |
This pic shows the fan in the middle for the HDM and the right one.
Could you post one from the left with the connections to the board in the rear ?
thx
| Posted: Mon Jul 15, 2013 1:20 pm Post subject: |
I will do that for you next time i open it up.
barclay66
| Posted: Mon Jul 15, 2013 1:26 pm Post subject: |
maybe this helps:
| Description: |
| Filesize: |
69.92 KB |
| Viewed: |
4287 Time(s) |
| Description: |
| Filesize: |
84.64 KB |
| Viewed: |
4287 Time(s) |
