NEC 9PG insufficient width above 1080i
Posted: Tue May 07, 2013 9:32 pm    Post subject:
NICE,not many new people here can get a CRT that needs work and get it running properly again. Sure is a good fealing though to repair something you got for next to nothing and have it outperform your old gear Thumbs Up
andy2000
Posted: Thu May 09, 2013 2:31 am    Post subject:
CasetheCorvetteman wrote:
I have those boards, make an offer.
Thanks for the offer. I got the IFB3000 working, and I think that will take care of all my 480i needs for now.
Assuming I don't run into any problems, I might still want the composite video board in the future, but it would need to be cheap since it probably wouldn't get used much.
Posted: Thu May 09, 2013 3:25 am    Post subject:
Depends if you want one i replaced all the leaking caps or you want to do it yourself as to what ill expect to get for it Wink
Why the set doesnt have that board allready is abit of a mystery...
andy2000
Posted: Thu May 09, 2013 4:07 pm    Post subject:
I don't mind changing caps (it will be a breeze after doing the rest of the projector). Someone might have removed the board if it was bad, and never put it back in. Based on the condition of some of the screw holes, it's been taken apart and put back together a LOT.
Posted: Fri May 10, 2013 3:57 am    Post subject:
Seems pretty common on NECs.
