stridsvognen Guest
| Posted: Sun Apr 20, 2014 12:41 pm Post subject: |
| Nashou66 wrote: | A shorted tube would not cause Spotkill circuit to activate. The Spot kill is on the VNB and VIM. There are some measurement points on the vim to see if it being activated.
Athanasios |
Its just a guess that it was the spot kill, but when its on there is a lot of noise on the tube face, with no signal, and when turning the projector off the light colapses into a spot in the center of the tube, who then softens and fades out.
Never had any isues after changing the tube, and tested with a different VNB before changing the tube, same result.
So for me that low hour, mint tube is kind of dead.. I kept it in the chamber, and hope it can be restored.
jbmeyer13
| Posted: Sun Apr 20, 2014 4:22 pm Post subject: |
| stridsvognen wrote: | | Nashou66 wrote: | A shorted tube would not cause Spotkill circuit to activate. The Spot kill is on the VNB and VIM. There are some measurement points on the vim to see if it being activated.
Athanasios |
So for me that low hour, mint tube is kind of dead.. I kept it in the chamber, and hope it can be restored. |
Did it look like this:
http://youtu.be/fz31tMrXW7g
| Posted: Sun Apr 20, 2014 5:56 pm Post subject: |
Athanasios |
This sounds like gas poisoning in the tube (ie. there is some air in the tube), unfortunately not much you can do about that. Symptoms are: substantially larger grid currents, disability of emission shutdown, with time it will get worse, this is a sad death for a good tube.
stridsvognen Guest
| Posted: Mon Apr 21, 2014 7:46 am Post subject: |
| jbmeyer13 wrote: | | stridsvognen wrote: | | Nashou66 wrote: | A shorted tube would not cause Spotkill circuit to activate. The Spot kill is on the VNB and VIM. There are some measurement points on the vim to see if it being activated.
Athanasios |
http://youtu.be/fz31tMrXW7g |
Yes the spot looked like that, the different is just that my tube wont display a image, just noise. But when turning it off it looks just like the video.
stridsvognen Guest
