G70 arc problem
alexander
Posted: Wed Apr 17, 2013 7:58 pm    Post subject:
Phoenixed wrote:
Did you double check all of your wire connections?
yes i did.I dont see anything strange.The 26 error is LENS missing,it doesnt see there is a lens.I cant understand how it checks if the lens is there.
To take out the lens you unscrew the 4 screws,and remove the grounding.Thats all.I dont see any other connection.
Posted: Wed Apr 17, 2013 8:09 pm    Post subject:
That 'grounding wire' you referred to is the lens mount sense wire. If that isn't grounded, the projector won't stay up and it'll throw the 26 error.
See the note at the top of this page:
http://www.curtpalme.com/SonyG70_Layout3.shtm
alexander
Posted: Wed Apr 17, 2013 8:35 pm    Post subject:
i see,OK.Thanks.But when i put the lens back on i reconnected the grounding wire,it should be able to see there is a LENS there.
The 2 errors i get now,is this one and 35 which is as i understand,the H-Board.Its strange why it was showing error 21 before we disconnected the blue tube and now its showing 35.
