| Posted: Tue Mar 19, 2013 12:34 am Post subject: |
| gjaky wrote: | Now, that could be an attempt to convert a barco to a normal projector Those are basic features on a NEC from the begining (~1992). |
Yes they are, its a very comprehensive system
Decibel
Joined: 31 May 2007 Posts: 904 Location: Roma - Italia
| Posted: Tue Mar 19, 2013 11:02 am Post subject: |
| Decibel wrote: | I've notice these differences between DTV1100 / BG1209s
Defl. coil+switch
R7621385 / R762457
Focus board
R7625035* / R762271
Horiz. defl.
R76226715* / R7621085
Vert. defl.
R762637** / R7621127 (sub board R7621127s is the same)
G2 board
R763014** / R762120
Motherboard
R762941** / R7627591 or R7627581
Splitter + EHT are newer version and are the same as BG1209s
Quad is older version but works.
All boards into convergence tray and SMPS board*** are the same as BG1209s
The controller board is the same but, obviously, different firmware and RWI.
*: same as BG808s
**: unknown
***: in my Runco the SMPS board was replaced. So I don't know if his serial number is the same of genuine Runco. |
The tests continue ...
Defl. coil+switch
R7621385 / R762457
Swappable!
Horiz. defl.
Swappable!
Vert. defl.
Swappable!
G2 board
R763014** / R762120
Swappable!
So NOW the projector work with the same hardware of BG1209s except focus board and firmware+RWI
I tried to install BG1209s firmware and RWI (also only RWI or only firmware) but the projector not work, i think because the focus board is incompatible.
Unfortunately I don't have R762271 focus board for try to complete the conversion.
The issue of the pulsating brightness on blue tube (with or without source connected) for now not fix
_________________ Domenico (Barco fan!)
Decibel
Decibel
| Posted: Sat Mar 23, 2013 8:45 am Post subject: |
| Decibel wrote: |
Focus board
R7625035* / R762271 |
Well today I checked that also the focus boards above are swappable.
The pulsating brightness (on the blue tube) is reduced and retrace lines (all tubes) are completely disappeared
Now I seek a R762271 latest version because what I put is very very old.
If someone have one, pm me thanks
| Decibel wrote: | | NOW the projector work with the same hardware of BG1209s except focus board and firmware+RWI |
With the inclusion of the focus board, my Runco have SAME hardware of BG1209s
But when I swapped the firmware the projector won't work
Really strange thing
