dkap
| Posted: Sat Mar 02, 2013 6:08 pm Post subject: |
| flipdog wrote: | | I have not read where he was made aware of that. If I remember correctly he stated that in this thread. Do you have that email? |
I posted it earlier in this thread. He said he wasn't made aware of it and I supplied the email showing otherwise. It was also posted in the original thread where he told me to send the PSU in to him for repair. (I attached a photo there of the only thing I found that looked suspicious, as a result of taking all the boards out cleaning everything out.) If Curt honestly didn't know about it, then he was skimming over far too much information and that largely explains the communication issues.
Dan
flipdog
| Posted: Sat Mar 02, 2013 6:35 pm Post subject: |
| dkap wrote: | | flipdog wrote: | | I have not read where he was made aware of that. If I remember correctly he stated that in this thread. Do you have that email? |
If this is the email your referring to, that is not very indicative of a mouse problem but rather just indicating of may have found some droppings which would not be abnormal: "Found it in my Jan 8th email to you: "I'm hoping from the [good] condition of the tubes that it isn't very highly used, just grungy from sitting around for years and having a mouse in there... Is there anything else I should send in, in addition to the 800's power supply and the 708's control board?" "
I also just reread that thread and that by no means is an indication of anything and the pictures indicated nothing of a mouse issue. saying that the previous owner had a bit of a mouse problem doesn't say anything. I'll also note that in that thread he said to send in the supplies before you posted the mouse comment. He may not have even read that post.
You almost had me leaning a little your way but if this is what your basing your issues on then your are loosing me again.....
Dan |
| Posted: Sat Mar 02, 2013 6:53 pm Post subject: |
I'll only add this here:
I may indeed have skipped over the mouse problem. I've posted many times here that I speed read, and with good reason: Posts here, 40 emails a day, a CRT market that is shrinking, and me doing sound system installations to make ends meet does indeed make me skip over stuff. While you did say the word 'mouse' in one email, I didn't correlate your previous posts here in November to an email you sent me in January. I typically put in 60-70 hours a week to keep on top of things. None of that changes anything.
You could have sent me every board in the set, and if there's a yoke wire chewed through due to a mouse in your projector, you would still get a scan fail error light the way you are now on the 800. There's no way of determining that whatsoever short of bringing up the whole set.
Take the worst case with the 708. Let's say I rushed the repair, or used defective parts. (doubtful since I ran your repaired SMPS for 24 hours before shipping it back), and then it worked for 90 minutes IIRC at your place before it died again. I'm willing to re-repair and look at any board again... BUT YOU NEED TO SEND THEM TO ME. It's that simple.
The car analogy is a good one. You've got the equivalent of two 20 year old cars, and you sent the engines into a repair shop without the car attached, because the mechanic diagnosed the engines to have internal issues. The mechanic tested said engines and confirmed that both were bad. He repaired them and tested them. He sent them back. You installed them. In one case, the engine is working fine, but the car also has transmission problems. In the other case, the engine worked for a while at your place, and died again.
Now you want the mechanic to repair the transmission for free, and cover the costs of round trip shipping. Ditto for the engine that failed again. I've offered to look at the transmission and repair as required, and also offered to re-repair the engine at no charge regardless of the cause of failure, but that's not good enough for you. You wanted the mechanic to diagnose the transmission when the engine was dead, and apparently ensure that both cars/projectors will run without further issues for X amount of time.
You claim it's my responsibility to have communicated all potential issues and to predict the future, and that you've got zero responsibility in this. I could counter by saying that you should have stated your expectations up front, and failure to do so prevented me from telling you to not bother sending in the repairs. But, I won't do that.
All I'll say is that on this CRT page, there's at least two other threads of recent repairs/board sales that I've done where the repairs or parts sales didn't work the first time. In both of those cases, as well as others over the last 14 years of doing this, the customer has incurred extra shipping expenses and downtime due to the issues. At no time, and I mean no time, in the last 14 years, has any customer ever reversed a payment on me, or has expected for me to be psychic. In fact, I'm usually thanked for sticking with the problem, and seeing it to an eventual resolution.
If it's possible to file in small claims either in Vancouver or in Wa state, I will absolutely do so, not because I need the $200 badly, but simply to prove a point. Bring your side to court and argue your case. May the correct person win.
dkap
| Posted: Sat Mar 02, 2013 7:17 pm Post subject: |
| Curt Palme wrote: | | I may indeed have skipped over the mouse problem. I've posted many times here that I speed read... |
That's the closest we've come to an acknowledgement on your part of shared responsibility in how this unfolded. Being willing to admit as such earlier might have averted the whole thing. Instead, you went on the attack, stating that I had insulted you (I'm still not sure how or where exactly) and starting this preemptive thread. Once things cool off a bit, I hope you can find it in you to look back and see that that was not particularly good customer support. I say this for future customers, not for myself.
| Quote: | | You claim it's my responsibility to have communicated all potential issues and to predict the future, and that you've got zero responsibility in this. |
No, I'm not saying that. What I'm saying is, when I ask you questions to determine the extent of the transaction, I expect that you've actually read the question you're replying to and that I have the correct information at that point. It sounds like you never fully read the questions I had asked, otherwise you could/should have simply said that it was your best guess what needed to be looked at and that there were no guarantees that would be all.
Dan
kal Forum Administrator
| Posted: Sat Mar 02, 2013 7:45 pm Post subject: |
| dkap wrote: | | Once things cool off a bit, I hope you can find it in you to look back and see that that was not particularly good customer support. I say this for future customers, not for myself. |
That may indeed be the case, but as Zaphod posted previously you paid for repairs, not for customer support. You got the repairs you paid and agreed to so I don't see how you can expect a refund for what you may consider to be poor customer support. I agree with Zaphod when he says:
| Quote: | the credit card paid for repairs.
customer service is paid for with return business. |
You can't have your car engine repaired at a garage and then days later reverse the payment because something else happend and you now deem that the service wasn't good. As long as they did the work that was agreed upon, I don't see how a reversal can be right.
Like Zaphod mentioned, if I had poor service somewhere, I simply don't go back.
My 2 cents.
| Posted: Sat Mar 02, 2013 10:41 pm Post subject: |
| kal wrote: | | dkap wrote: | | Once things cool off a bit, I hope you can find it in you to look back and see that that was not particularly good customer support. I say this for future customers, not for myself. |
My 2 cents.
Kal |
Exactly
The agreement was for a repair and there is no evidence that the repair was not carried out.
dkap
| Posted: Mon Mar 04, 2013 4:56 am Post subject: |
| kal wrote: | | as Zaphod posted previously you paid for repairs, not for customer support. You got the repairs you paid and agreed to so I don't see how you can expect a refund for what you may consider to be poor customer support. |
Because there may not have been repairs if not for the lapse in communication, i.e., customer support. The two cannot be separated. The net effect is that I was misled, even if not intentionally. It amazes me to hear people in an industry so dependent on long-distance troubleshooting being dismissive of the importance of communication.
For those of you who keep going back to the car analogy (which I feel is an exceptionally poor fit; most mechanics are local which completely eliminates all the pre-sales considerations of this debate), sending back the repaired 708s power supply with no explanation to watch for arcing would be like the mechanic sending back the motor and not telling the owner to put oil in it before starting it back up. That may be a "duh!" item for someone familiar with motors, but for something like CRT projectors where the vast majority of people have no idea how they work, an extremely important piece of information was missing there. Without that information, it's a pretty shaky stance to say I received the repair I paid for.
I'm not happy with how any of this has unfolded and would like to see something positive come out of it. If the dispute does get resolved in my favor, I think I'm going to donate the full $200 to a cause I've wanted to contribute to for a while now. Of course, if Curt then takes matters to small claims court, that complicates things.
Dan
hal
| Posted: Mon Mar 04, 2013 5:26 am Post subject: |
Dan, I have been watching this thread. I have suffered a few setbacks with my new to me G90. I had to purchase a used set of lenses from Craig do to a few packaging issues. This past Friday, the complete machine died. One thinks of everything. Failed YA board, Dallas chip, Power supply, Low Voltage power supply and so forth.. How does one go about fixing dead machines??
I posted a new thread, I emailed Curt and Craig. Both were helpful. Curt was leaning towards the two large low voltage power supplies. I pulled out the two boards with all intentions to drop them off at the border.
This morning I sourced a G90 with a failed YA board for parts. It's sad. Here you have a GREAT CRT, put out to pasture because of the failed chip. I swapped the two LWPS boards and the machine was still dead. Curt told me that it's rare that the main power supply fails. He can't ask his Genie what is wrong, nor can he Guarantee that it would fix my Sony. Like I said, I was planning on driving to Blaine and dropping off the two boards. It would have been in vain.. That wasn't the problem. I was still searching for answers. I can also relate to how you felt and must feel. You still have machines that aren't working. I ended up pulling the power supply and swapping it over. All is fine... I had to fork over some cash for the dead G90. I paid more money than what Curt or Craig would have for a dead core.. But it was "my" way of solving my problem. That might be easy for me to say.. But when I put the two LVPS boards in and with the email that I received.. My current machine could have been down with a failed YA board, bad Dallas chip or spotted tubes.
You are paying for a service tech to repair "your failed" products. You ask him for his best judgement call. He gave you his opinion. If it works he is a hero. If it doesn't you have to work on plan "B". If you personally needed to have a 100% Guarantee > You needed to ship your CRT's to Curt or drop them off. He would get them running for you, and your would pay him.. He is driving across the border to puck product up and drop things off in Blaine.
Nothing with these old machines are a given and 100%.. Yesterday I was thinking that I should have jumped ship and bought a JVC.
zaphod
| Posted: Mon Mar 04, 2013 3:51 pm Post subject: |
| dkap wrote: |
One last time: The dispute is about customer service, not technical expertise. The communication issues are what led to an unhappy transaction.
Dan |
| dkap wrote: |
Dan |
Make up your mind. Please.
| dkap wrote: | If the dispute does get resolved in my favor, I think I'm going to donate the full $200 to a cause I've wanted to contribute to for a while now.
Dan |
If you wanted to contribute to the charity, you would have already contributed to the charity. Don't try to garner props for yourself by using some unnamed charity.
You give or you don't give. Giving based on unrelated events that may or may not happen speaks volumes about your charitable character.
| dkap wrote: | Of course, if Curt then takes matters to small claims court, that complicates things.
Dan |
No more complicated than some one reversing charges on a credit card.for repairs that you admit getting.
| dkap wrote: |
Let's not forget, I'm still out $55 in shipping costs if indeed the dispute has gone through in my favor. It's not like I got something for nothing.
Dan |
if we gave you the $55, would you go away?
| Posted: Mon Mar 04, 2013 4:46 pm Post subject: |
| zaphod wrote: | | if we gave you the $55, would you go away? |
6 pages, and Dan still feels like a victim, even though Curt got screwed out of his labor. Now it's the shipping company, they stole $55. from him by delivering boards that didn't fix his machine.
I doubt another 60 pages would help get the point across
