jeffslife
| Posted: Sun Jan 27, 2013 9:10 pm Post subject: 14 gauge or 12 gauge wire ? |
Ok so I am adding a sub to my set up up and I am going to put one on each side of the screen next to the front channels. The left channel needs about 40 foot of wire so I will use 40 ft on the right side also even though it only needs 28. The question I have is how much of a benefit would it be to use 12 gauge wire over 14 gauge wire ? I have heard that the amp will clip less on the front channels of lengths over 35 feet if you use 12 gauge wire. I dont know for sure if that is even true but even if it is would it make much of a difference on subs ? I need to buy a rollof wire so I am trying to decide whether to rewire my fronts with 12 instead of 14. Does it even matter enough to be noticable ? Does it really allow you to turn the amp up before it clips ? Thanks in advance, Jeff
jeffslife
| Posted: Sun Jan 27, 2013 9:18 pm Post subject: |
I am running both subs off a NHT SA2 amp. So what do you think about rewiring the fronts ? will 12 gauge make much of a difference ?
dturco
kal Forum Administrator
stridsvognen Guest
| Posted: Sun Jan 27, 2013 11:05 pm Post subject: Re: 14 gauge or 12 gauge wire ? |
| kal wrote: | | jeffslife wrote: | | The left channel needs about 40 foot of wire so I will use 40 ft on the right side also even though it only needs 28. |
Only use what you need. There's no need to keep the wire lengths balanced. That was invented by ignorant audiophiles and people that sell wire.
Kal |
Ohh that one hurt.. Well sorry to say that my ignorant audiophile ears are very sensitive to different cable lengths.
But im happy that most people know better and cant hear any difference..
jeffslife
| Posted: Sun Jan 27, 2013 11:09 pm Post subject: |
DAMN ! 10 gauge speaker wire is 80 bucks for 50 feet. So tell me why its worth all this extra cost again ? Will it really help my amp ?
stridsvognen Guest
| Posted: Sun Jan 27, 2013 11:29 pm Post subject: |
| jeffslife wrote: | | DAMN ! 10 gauge speaker wire is 80 bucks for 50 feet. So tell me why its worth all this extra cost again ? Will it really help my amp ? |
I don't think anyone can know. Try all options and you will know whats best in your setup.. but i think there is more to the cable talk than anyone can possible solve on a forum, and impedance is for me far from the worse thing in a cable.
I find that most people in a place like this have a opinion. So ill guess you can find one to recommend 5 AWG and another 25AWG.
But there is so many parameters to consider with cables and equipment like amp output impedance damping factor.
Cable impedance,capacity and more. One speaker or amp will work best with one cable and another amp with another cable.
One thing i'm very sure about is.. To long cable is better than a cable thats to short..
nettwerkjohn
Joined: 08 Mar 2006 Posts: 921 Location: Blenheim, Marlborough, New Zealand
| Posted: Mon Jan 28, 2013 12:07 am Post subject: |
i'd run a line level cable, move the amp closer to the subs, then use short lengths of the biggest cable you can afford.
dturco
| Posted: Mon Jan 28, 2013 1:10 am Post subject: |
No it won't help your amp...it will just keep you from hurting it by having to over drive it to keep the music flowing.
In all honesty 12 gauge will be fine...just not for me.
http://www.hulu.com/firefly
dturco
| Posted: Mon Jan 28, 2013 1:38 am Post subject: |
Jeff how many watts are you using over the 40 ft run? Are these subs passive only? No on board amps? can you put the amp closer to the speaker? Do the amps have XLR's and your pre-pro too?
See lots of questions. Just use 10 gauge and none of them will matter.
| Posted: Mon Jan 28, 2013 1:39 am Post subject: |
| nettwerkjohn wrote: | | i'd run a line level cable, move the amp closer to the subs, then use short lengths of the biggest cable you can afford. |
Thus is the best option. Put the amp on the floor next to the subs or on top of one. The run short speaker wires to the subs. One line level cable will be less than two long runs of speaker wire.
jeffslife
| Posted: Mon Jan 28, 2013 11:22 pm Post subject: |
OK so moving the amp wouldnt work out well, and line level isnt an option they are not on board amps. The price of 10 gauge wire is crazy. I called a friend of mine who is an electrician ( he has every kind of wire known to man) and told him of my situation, He had some 10 awg and could give me a decent price on it But he offered this up as a no cost solution since I already have a big spool of 14 awg. He said to just run two lengths and braid them together in parallel and use that. I know I would use a lot of wire, but wire I got that is only collecting dust and isnt eating anything. So basically its free. I know electricians do that all the time with AC runs,its common. Is there any reason it wouldnt work ? If it will then this is an easy no cost fix.
| Posted: Mon Jan 28, 2013 11:45 pm Post subject: |
Jeff,
You run line level from your preamp output to the sub amp already right? You can put the amp near the speakers and just make the line level longer. Than use shorter speaker cable.
jeffslife
| Posted: Mon Jan 28, 2013 11:58 pm Post subject: |
I could, but then I need to run a 25 ft extension cord and a 25 foot rca cable to the amp.
jeffslife
| Posted: Tue Jan 29, 2013 12:03 am Post subject: |
Thanks for the tip on the wire Nash, Thats a great price !
| Posted: Tue Jan 29, 2013 12:07 am Post subject: |
Has anyone ever noticed the size of the voice coil wire?
jeffslife
| Posted: Tue Jan 29, 2013 12:24 am Post subject: |
OK But I still havent got an anwser, would it work ?
