kal Forum Administrator
| Posted: Tue May 14, 2013 8:23 pm Post subject: |
So I finally had some time last night to put my Display 3 meter and ChromaPure calibration software to the test and measure how this RS56 does out of the box after ~500 hours of use.
I've always thought that the results (pre-calibration) looked pretty phenominal and were probably pretty close to perfect and now I've confirmed it.
Greyscale/Gamma:
The important thing to look at is the CIE94 error (DeltaE) values. This is a numerical value of how far off the greyscale is from the target from 10% to 100% light output (stimulus). While 0 is perfection, the goal is to try and keep DeltaE under 10 for each point. A DeltaE of 3 or under is so close to perfect that the human eye cannot detect the subtle imperfection. My points are (IMHO) very good with the highest being 5.7 at 50%.
A little too much blue in in the middle range as you can see. Lowering blue or possibly raising the other two at the low end should fix it.
A little bit of tweaking and these DeltaE numbers will get a bit lower but it's really questionable with already deltaE's so low if the difference will be noticeable.
Gamma tracks pretty well between 2.3 and 2.2 (which is where I want it). About 2.2-2.4 is ideal.
I've chosen the 6500K setting and gamma set to "normal" but that doesn't mean someone else doing the same will get the same results as above (hence the whole reason why we calibrate).
I really lucked out with this unit.
The observant reader will note that I'm "only" getting 9.5 ftL of light output at 100% when SMPTE really says you should be doing around 12-14 ftL. I find this 9.5 in my darkened basement to be very bright and couldn't imagine or want more even after trying it out for a while. I find it overly bright. I have the lamp running on low lamp with the iris set to -6 (it goes from -15 [closed] to 0 [open] where 0 is brightest). So there's certainly room to go brighter if needed.
Colour Gamut:
Again, theCIE95 (DeltaE) are very good with the highest being 3.6 for the green. This means that the primary/secondary colours are pretty darned closed to perfect on my unit when using the "Film" colour profile/picture mode.
This doesn't tell us anything however about how well the colours track inside the triangle (inside the gamut). Some displays can be really off in there (example pictures here) but still be great at the primary/secondary points.
So I still want to go in and measure inside the gamut to see how much adding a 125 calibration with a Radiance video processor would help.
Even if it doesn't help much I do like the fact that the Radiance can also do 20 point greyscale and gamma, and do it all automatically in ChromaPure without me having to mess with the menus, or tweak the unit every ~6 months (because I know I won't), or even really have me have to understand what I'm doing. (My brain is full).
stridsvognen Guest
| Posted: Tue May 14, 2013 8:31 pm Post subject: |
Kal, i'm curious how the primary point tracks with 25-50-75-100%% IRE, is it possible you can measure that.?
| Posted: Wed May 15, 2013 12:18 am Post subject: |
| kal wrote: | | The observant reader will note that I'm "only" getting 9.5 ftL of light output at 100% when SMPTE really says you should be doing around 12-14 ftL. I find this 9.5 in my darkened basement to be very bright and couldn't imagine or want more even after trying it out for a while. I find it overly bright. |
Makes a big difference when you have X *ANSI* lumens vs. X *PEAK* lumens. The 12-14 ftL you get on a CRT is generally with a small 10% spot, but when you have bright scenes, you don't get anywhere near that level of ftL overall. The whole image darkens due to the current limitation. 10 or so ftL with consistent brightness is going to pump out a lot more photons on most scenes.
| Posted: Wed May 15, 2013 12:39 am Post subject: |
Good point Gary, but that doesn't change the fact that 12-14 ftL is what most calibrators recommend *today*, and this is in the day and age of digital projectors where full field vs window doesn't change the light output. The 12-14 ftL recommended output isn't a throwback to CRT (AFAIK). I see it recommended everywhere, including the ChromaPure help which states:
| Quote: | Light Output Targets:
CRT or Digital Flat Panel: 120 cd/m2 (35 ftL)
Digital front projector: 48 cd/m2 (14 ftL) |
These were the name numbers I recommended when I wrote my Greyscale Guide for Dummies back in 2008.
VideoGrabber
| Posted: Wed May 15, 2013 7:24 am Post subject: |
| kal wrote: | | Good point Gary, but that doesn't change the fact that 12-14 ftL is what most calibrators recommend *today*, and this is in the day and age of digital projectors where full field vs window doesn't change the light output. The 12-14 ftL recommended output isn't a throwback to CRT (AFAIK). I see it recommended everywhere, including the ChromaPure help... |
Have you tried opening up the iris, just to see what the max ftL output capability is, so you can gauge your headroom for later, when the bulb dims? Seems like that might be worth knowing.
_________________ - Tim
| Posted: Wed May 15, 2013 1:13 pm Post subject: |
| VideoGrabber wrote: | | Have you tried opening up the iris, just to see what the max ftL output capability is, so you can gauge your headroom for later, when the bulb dims? Seems like that might be worth knowing. |
I haven't measured it. I should certainly do that. However, knowing the max light output I can get today when the bulb is fairly new isn't going to help me all that much as it dims (I don't think) because I won't be able to get that much light down the road as the bulb will be dimmer... I'll be getting something less.
Before I bought the projector I did some rough SWAG calculations to make sure that I could probably always run the projector in low light output mode as it's much quieter than high light output mode (the fan's much quieter). I'm hoping that I'll never have to go to high light output mode.
stridsvognen Guest
| Posted: Wed May 15, 2013 1:22 pm Post subject: |
I dont think you will ever change to high output mode, even if it gets to dim, it wont help much, and only accelerate the dimming. Now your using the new type lamp, so its exiting how long yours will last with a decent output.
Do you have a Radiance ?
| Posted: Wed May 15, 2013 1:23 pm Post subject: |
Last night I measured the primary/secondary numbers again at 100% saturation as well as at 75%, 50%, and 25% to see how well it tracked.
ChromaPure calibration software has a really handy feature to do this and the free AVS HD709 test disc has the patterns needed. (Note: Oddly enough the patterns under their ChromaPure section aren't in the order that ChromaPure asks for - they're laid out as 75%, 50%, and then 25% in the disc when you skip through but ChromaPure asks for the patterns in the 25%, 50%,75% order. So some jumping around was required. Still only took 5 mins to do however, just seems odd).
Here are the results:
So as you can see, it tracks really well inside the gamut (between 0 and 100% saturation). Very linear. The highest deltaE errors are mostly at the 100% saturations which can be corrected with the built in projector CMS and the others will likely follow a bit.
That said, the highest dE is the green at 100% saturation but it's still under 4 which is well below the 10 target that we want to achieve. Anything below 3 is considered (for the most part) perfect and not something we'll notice with the human eye. So it's even questionable whether the 100% primaries/secondaries are worth adjusting. They certainly don't look 'off' with regular source material.
(EDIT: I've got ChromaPure set up to use the CIE94 method of calculating dE since it's the default and what they recommend, but ChromaPure does recommend keeping dE below 2.0 if possible for greyscale measurements and below 1.5 for primary/secondary colours, not below 3.0.)
While this doesn't show all of the billions of points possible it gives you a good indication of how well the projector does inside the gamut.
Using something like the Radiance 125 point colour cube correction through the advanced auto-calibration offered by ChromaPure to adjust inside the gamut will likely have little to no noticeable result.
stridsvognen Guest
| Posted: Wed May 15, 2013 1:36 pm Post subject: |
looks nice.. Wish JVC would support the older models with firmware, so they behaved like yours, looks like the green is in the same place as the older models, so that might be the limitation to the panel.
But as you mention.. its quite close, and perfectly ok.
Now we are all waiting to see how looks like when you get it calibrated..
| Posted: Wed May 15, 2013 1:38 pm Post subject: |
| stridsvognen wrote: | | Do you have a Radiance ? |
I do not. I have a spot reserved for one because I want to use it for auto-calibration with ChromaPure so that I don't have to do it myself (I'd rather have it be quick and easy) as well as provide 125-point advanced auto-cal inside the gamut, but seeing how mine tracks reasonably well everywhere out of the box it's almost questionable if it's worth it. I need to play around more with the built in greyscale/gamma/CMS adjustments in the projector and see ...
VideoGrabber
| Posted: Wed May 15, 2013 4:16 pm Post subject: |
| kal wrote: | | ...knowing the max light output I can get today when the bulb is fairly new isn't going to help me all that much as it dims (I don't think) because I won't be able to get that much light down the road as the bulb will be dimmer... I'll be getting something less. |
Of course. Yet knowing your max output lets you gauge where it will be at when it dims to 60/50/40% (I don't know the profile for these bulbs). Let's say it will spend most of it's life on the tail at 40% peak output. Knowing max ftL, you can simulate that 40% right now (using the iris), and see how it sits with you.
| Posted: Fri Sep 06, 2013 4:23 pm Post subject: |
No Itai or Crabb at that meet. Would have liked to have gone, but haven't been to the Pacific Northwest in forever.
Definitely looking forward to seeing what's at CEDIA in terms of 4k, and what happens to availability and prices compared to last year. It was just three years ago that I coined the term "3DEDIA" because everybody was showing or talking about 3D. I think there were 3D recliners, power cables, and carpet that year. That was the same year I saw the big 4K JVC, which the redefined one aspect of home theater for me. Much, much more excited about 4k than I ever was about 3D.
| Posted: Fri Sep 06, 2013 5:17 pm Post subject: |
Thanks for the link to Kris's review of the X95 Spanky. I was interested in reading it since I was toying with the idea of the X75 vs X95 myself when I purchased, and not being able to really see both in ideal setups (or any setups for that matter) ahead of time had me 'guessing' at the perceived difference in video quality.
Kris wrote in his review:
| Quote: | | The DLA-X95R’s measured peak contrast was better than I could achieve with my DLA-X75R, but my projector had a bit more light output, and the difference in contrast was nearly imperceptible with real-world content. |
Which is what I suspected. Glad I stuck with the X75.
| Posted: Sat Sep 07, 2013 3:58 am Post subject: |
| ecrabb wrote: | That was the same year I saw the big 4K JVC, which the redefined one aspect of home theater for me. Much, much more excited about 4k than I ever was about 3D.
SC |
I don't remember that at all.
Unfortunately, I don't think there is going to be a lot in the way of 4k pjs this year. I guess it will be relegated to Sony and flat panels. I glanced at AVS and I think someone mentioned that TI is not going to release inexpensive 4k DLP this year and will instead wait till next year. JVC isn't going to have any 4k pjs in the consumer line. I do wonder if they have improved upon the cinema 4k pj (you know the one ). Epson isn't going to have anything worth talking about and IIRC LCD may not be able to scale to 4k. I believe that is why they attempted their version of LCOS.
Kal,
I would have thought you miight be more interested in the calibration tips. I have always wondered if the price difference for hand picked parts was worth it.
AVphile
Joined: 02 Dec 2008 Posts: 334 Location: Ottawa, Ontario
| Posted: Sat Sep 21, 2013 4:25 pm Post subject: |
I am curious to see if a new color standard emerges before jumping on a new 4k PJ. Right now we are still using CRT-based standards so I don't see the point of trying to emulate CRT characteristics with a digital while I still have a functioning CRT. My ears would benefit more due to the lower noise floor.
_________________ AVStefan
Old setup: HDFury3 -> BG-808s -> HD-145
New setup: JVC D-ILA -> Stewart StudioTek 130 G4
| Posted: Wed Oct 02, 2013 1:14 am Post subject: |
| Spanky Ham wrote: | | but next year we should be in the $5k to $10k range. |
5K? Wow. That fast huh?
I have to admit I'm looking forward to owning a PJ with that resolution.
benareeno
| Posted: Thu Oct 03, 2013 1:18 am Post subject: |
resolution is so freaking overrated...there are far more important things which would improve the picture quality.
| Posted: Thu Oct 03, 2013 1:55 am Post subject: |
| benareeno wrote: | | resolution is so freaking overrated...there are far more important things which would improve the picture quality. |
I disagree completely. Resolution is totally underrated!
We now have tablets, notebook computers, and desktop displays with higher resolution than 1080p, and they look absolutely phenomenal. Most of the good new digital displays have excellent color gamut, great calibrated greyscale and gamma, great ANSI contrast, very good on/off, good to decent motion resolution... Spatial resolution is one area where we'll see an immediate and huge improvement over 1080p - especially with large screen front projection!
I bet you haven't seen 4k projected on a big screen, have you?
