will this work to connect a ps3 to a projector?
freidich
Posted: Fri Dec 21, 2012 1:12 am    Post subject: will this work to connect a ps3 to a projector?
http://www.ebay.com/itm/181029076774?ssPageName=STRK:MEBOFFX:IT&_trksid=p3984.m1432.l2649
I imagine that this works and is so cheap because the AV/Component/Composite output of the PS3 is analog and thus another device to convert from hdmi to analog is not necessary.
Or would I be better off with a hdmi cable and then a (much more expensive) device that converts hdmi to analog like a Moome or HD fury?
Posted: Fri Dec 21, 2012 1:19 am    Post subject:
Honestly I can't see how that would work. Looks a little shady to me.
You could get a PS3 component cable:
http://www.amazon.com/PS3-Component-AV-Cable-Playstation-3/dp/B000MIXFWA/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1356052539&sr=1-1-catcorr&keywords=PS3+component+cable
and a Kim-Coder Component to RGBHV/VGA box RTC2200:
http://www.curtpalme.com/RTC2200.shtm
and a VGA to RGBHV cable: http://www.amazon.com/Cables-Go-02574-Premium-RGBHV/dp/B0073DP3YK/ref=sr_1_11?s=electronics&ie=UTF8&qid=1356052687&sr=1-11&keywords=VGA+to+5BNC+cable
freidich
Posted: Fri Dec 21, 2012 1:58 am    Post subject:
at that price, i might as well get this http://www.curtpalme.com/NEC_XG-FULLHD.shtm
Posted: Fri Dec 21, 2012 2:02 am    Post subject:
Oh you have an XG. You may have issues at 1080p ( 1080p digital timings have porches too small for some CRT projectors )
BUT yes that's a great deal. Plus the HDMI output of the PS3 is better than the component.
freidich
Posted: Fri Dec 21, 2012 2:07 am    Post subject:
ok, and it does appear to be a good deal, but $260 is still $$$ ...
Posted: Fri Dec 21, 2012 7:25 am    Post subject:
What XG? A couple models have component on them.
The other item in the first post will depend on your console, if its a model that puts out RGB-S then yes, itll likely work.
freidich
Posted: Fri Dec 21, 2012 7:34 am    Post subject:
model 1351LC, and i think it is quite possible that the ps3 does RGB-S. i will look into it and report back
freidich
Posted: Fri Dec 21, 2012 7:38 am    Post subject:
it looks like the ps3 does not do RGBS
Posted: Fri Dec 21, 2012 8:02 am    Post subject:
I looked around a bit at the PS3's VGA cable. Seems they are sending component over VGA. Not useful when you need RGBHV or RGBS
Posted: Fri Dec 21, 2012 8:11 am    Post subject:
Dont think the 1351 has component. Have a look in the signal entry menu.
If not, i dont see how that VGA adaptor as they call it could work on any monitor if its only component.
At 1080i, component will look just as good as HDMI on a PS3, you cant do 1080p via component at all as far as i know.
Posted: Fri Dec 21, 2012 8:25 am    Post subject:
HDMI looks much better than Component on the PS3. I've done the A/B on that one at 1080i. This was on the 60GB PS3.
There are TV's that can take 1080p over component though I don't know of anything that outputs that off the top of my head.
freidich
Posted: Fri Dec 21, 2012 8:28 am    Post subject:
ok, i may have to bite the bullet and buy the moome, though if i could get one used on the forum for less, that would be ideal
Posted: Fri Dec 21, 2012 8:40 am    Post subject:
You're more likely to find a used HDFury or external Moome box but post in the Buy and Sell and see what comes up.
Posted: Fri Dec 21, 2012 8:42 am    Post subject:
There is only 50MHz bandwidth there so itll look pretty streaky at 1080p
freidich
Posted: Fri Dec 21, 2012 8:46 am    Post subject:
what has only 50mhz bandwidth?
Posted: Fri Dec 21, 2012 8:48 am    Post subject:
The only sources ive seen that output 1080p from digital 100 MHz component is some AVRs, two of my 3 H/Ks do, but its YCbCr, not the YPbPr that is output from the PS3.
Posted: Fri Dec 21, 2012 8:50 am    Post subject:
YPbPr or analog component video has 50MHz bandwidth.
freidich
Posted: Fri Dec 21, 2012 8:52 am    Post subject:
oh well based on what we've discussed above, I'll just use the hdmi output on the ps3. I have an hdfury, i believe it is a gamer model, but am still interested in getting the moome
Posted: Fri Dec 21, 2012 8:59 am    Post subject:
Why not get an internal MOOME?
freidich
Posted: Fri Dec 21, 2012 9:01 am    Post subject:
that is exactly what i am considering, but there is the small matter of $$$
