275 hour 10PG FOR FREE!!!!!!!
Zolzar
Posted: Wed Dec 26, 2012 1:32 am    Post subject:
Well, pulling the caps and using the legs is absolutely the most straight forward least likely to damage the board. Using a hot vac would be the proper tool for the job and most likely would not damage the trace. So.....should I solder to the left over leads or hot vac????
John
Posted: Wed Dec 26, 2012 2:35 am    Post subject:
I just spent 6 hours working on a 9 PG that had some leaky caps. I used needlenose pliers to pull the caps off the leads. Cut the flat top parts off that were inside the cap, and soldered to the little leads sticking up off the board. I have a high end Metcal soldering iron, and even that had issues getting those leads out clean. 6 hours later, and the set is 100%.
Posted: Wed Dec 26, 2012 3:17 am    Post subject:
John
This is what I like to do, I've replaced thousands of parts and never damage the boards. First, flush cut the wire leads on the through hole side of the board, the side opposite the components. Then add a little fresh solder, the fluxed kind, to the holes. Heat one leg at a time, and slowly rock the cap out. It's quick, one or 2 times and your free.
That just leaves the old solder, A vac works ok, but it's not 100% in my experience. I always found myself having to go back in with wik on some holes, so I just go straight to wik now.
A good high quality wick, like chemtronics chem-wik, will wick-up the solder without over-heating the board and leave a clean hole.The wick here is critical, you need stuff that has a very dense herring-bone weave pattern. if you can't get really high quality stuff then skip it and do what Curt suggests.
Posted: Wed Dec 26, 2012 4:42 am    Post subject:
I assume that NEC uses a higher temp solder than the Marquee Drags otherwise it should be simple. Probably Like the Apple Power supplies I have repaired You have to have a very very hot solder iron and work quickly. One leg at a time rocking back and forth does not work for high temp solder. I use the twin typed tweezer Iron for that job.
Posted: Wed Dec 26, 2012 8:07 am    Post subject:
Solder wicking an NEC board is a damn fine way to tear off a trace when the solder cools and is still stuck to the board...
Zolzar
Posted: Wed Dec 26, 2012 1:19 pm    Post subject:
The fail safe method that Curt uses is going to be the best way to avoid damage. I dont want to destroy this low hour machine.
John
Posted: Wed Dec 26, 2012 1:59 pm    Post subject:
Good idea, that is why we all suggested it Wink
Tinman
Posted: Wed Dec 26, 2012 4:55 pm    Post subject:
I use Curt's method on computer boards almost exclusively. Works very well when a cosmetically flawless repair isn't an issue.
And it's fast.
BTW, Curt.... Metcal does sell hotter tips. You need them for all this ROHS crap.
This space for rent.
Zolzar
Posted: Thu Dec 27, 2012 1:58 am    Post subject:
I am starting compile the order and need a little assistance in what to select. For the most part I have found FM/FC series replacements. The problem is where I can't find the low ESR replacement. What should I be looking for? Is a higher ripple current better? How about the impedance of the caps?
John
Posted: Thu Dec 27, 2012 2:04 am    Post subject:
Nash I didn't see anything special about the NEC solder. It melts at the same temp. as any other.
who the f*ck asked you, moron? Your comment demonstrates that you have no f*cking idea what your talking about. Only a complete idiot would solder the braid to the board, which is obviously what you did.
Posted: Thu Dec 27, 2012 2:24 am    Post subject:
Ahh , Never worked on an NEC board. But I know bob Stephan re capped his blend and had no issues desoldering and removing
the caps without cutting.
Good to know, I guess some just can't do it correctly hence the cut the leads suggestion.
Good advice none the less.
Posted: Thu Dec 27, 2012 2:25 am    Post subject:
Whoa Dragan! More eggnog... STAT! Smile
Frankly, I've done that too when I've used solder wick. It's not my preferred method at this point, but there's still a roll of it here somewhere.
MArc, thanks, I'll check eBay for hotter tips...
Zolzar
Posted: Thu Dec 27, 2012 3:17 am    Post subject:
Wow! WTF!!!! Such a lively discussion! LOL!
Posted: Thu Dec 27, 2012 3:26 am    Post subject:
Well I never said that leaving the old leads in there was for people who couldn't de-solder properly. Like tinman said, if aesthetics aren't key, and although i've never done it that way, I see no reason re-soldering to the old legs wouldn't give solid results. In my situation, the board has to look like factory work, that's what people pay me for.
if someone had trouble on an NEC board, I wouldn't blame the NEC. Heat causes solder to crystallize over time. At that point it doesn't conduct heat well and will not flow-out like fresh solder. That's why fresh solder and flux to an old joint, before any work is done, is key.
I obviously get really bent when people, who have no f*cking idea what they're talking about, respond to my posts with ignorant comments. Out of the dozens of people here with experience, who's opinions I respect, there is always 2 or 3 talking out of their *******.
Case is a pro, he's owned a couple of NEC's and a Sega console, and now he's an expert on capacitor failures and soldering techniques, what a joke.
Curt had the same experience with some stuff, brand is key
Posted: Thu Dec 27, 2012 3:45 am    Post subject:
No, ive never done that, but ive seen it done. The board soaks up the heat and the solder part solidifies when the iron cant keep up. I never use solder wick cause i dont like it.
But still, how many NEC boards have you done against Curt or Macgyver or Tinman? Youre always so quick to jump in and discredit them and their sugestions, but where is your experience? They all have it in droves, they have tons of it, and strongly advise against conventional desoldering methods on NEC boards ( and this is an NEC only related thread ) then you come along with one or two PG sets worth of experience and no real idea and tell us all that you know better than they do and you suggest using solder wick on a multi layered board??? Get real man...
You love to resort to name calling though dont you, shows the strength of your case i guess Wink
Posted: Thu Dec 27, 2012 3:49 am    Post subject:
Youll love it here mate Wink
Posted: Thu Dec 27, 2012 3:54 am    Post subject:
Yeah but ive also got a piece of paper that says i know Wink
You just dont like it when youre called out wrong and still want to argue, which was the case with the capacitor failures. And you arc up over nothing too!! You were WRONG. Be a man and WEAR IT.
Tinman
Posted: Thu Dec 27, 2012 7:03 am    Post subject:
Look for an 800 series tip. Those are the hottest. Normal is 700 and cooler is 600.
Marc
Posted: Thu Dec 27, 2012 3:30 pm    Post subject:
Are you suggesting that this applies to Curt and Tinman?
Posted: Thu Dec 27, 2012 3:35 pm    Post subject:
I would.
Page 5 of 9
