| Do I suck ? |
| Absolutely |
61% |
[ 13 ] |
| I've had better |
19% |
[ 4 ] |
| Keep trying ! |
19% |
[ 4 ] |
| Total Votes : 21 |
stridsvognen Guest
| Posted: Mon Nov 26, 2012 11:26 pm Post subject: |
| Motobias wrote: | thi is it:
http://www.ebay.de/itm/110975277570
it was advertised as a 9500lc and he sent me a mail because is asked about date, etc:
"Hallo,
Der Projektor ist von 97 bis 2000. Es ist ein Ultra - also erweitertes Fokusboard und hdm. Auch sie Software ist entsprechend.
Gruß"
"...projector is from production date range 1997-2000. i is an ultra - has extended focus board and hdm. software is according."
...well...what the hell is it now ? |
LOL.. Its a piece of sh*t lol... But don't worry... YOU don't suck anymore..
Sorry... But as Curt say.. Cap mods like that is worse than nothing..
Really hope you will get it up running, but prepare yourself shopping for a spare machine.
Motobias
Joined: 08 Jul 2008 Posts: 163 Location: Osnabrueck, Germany
| Posted: Mon Nov 26, 2012 11:46 pm Post subject: |
well if the caps were just all replaced by tantalum ones, that's ok
tantalums have better specs than most other caps and do not fail that often.
the mods just look ugly and i'll make sure they are electrical safe...
the hot glue is my work, i just wanted them secured in place, so they won't short out against chassis ground or other components.
if i can't get lucky with it, first seller will have to live with the consequences and you guys can jump in queue for tubes or anything you think is worth having...
i forgot to mention that the set has high spec papst fans everywhere and is almost quiet but maintains a good airflow.
_________________ Most peope talk about HD without knowing the meaning and how to do it RIGHT !
FIGHTING STUPIDITY SINCE 1983
| Posted: Tue Nov 27, 2012 12:02 am Post subject: |
Nah, I think you got a good deal overall. Even if you need to replace a board or two, they are relatively cheap and plentiful. Even though the green has a bit of wear, it's completely useable, and with the HDMI card and C elements, there's the value of what you paid for it right there.
Mike can chime in, but those are NOT his mods! I've seen lots of his work, and he wouldn't do that. I'm guessing the person that modded came to this site, looked at the Dragan mods, and said 'I can do this for cheaper'.
yes, indeed, he did!
But 36Kv? It most likely won't affect the tubes, but if you have access to an HV probe, I would turn it down a bit. That's the left pot on the side of the HVPS as you look at it pulling it out (towards the front of the HVPS). I'm assuming that CW is turning it up, CCW is turning it down, but I've never had to play with that pot.
Motobias
Motobias
| Posted: Tue Nov 27, 2012 12:09 am Post subject: |
@curt
glad to hear that
i am still a big fan of my xg135, although the green has slightly more wear that this one and it's only ac
...somehow like my barcos aswell, but as you know, they constantly give me headaches
i just want one projector to run and keep and maybe clear out a bit... thought the marquee is the one to grab
and i am already thankful for the experience on working on a marquee and understand its layout...
haven't touched a g70 or g90 but it's on the list... 909 doesn't really tease me, ist's just a big 808 and way to expensive
| Posted: Tue Nov 27, 2012 12:48 am Post subject: |
I thinkt he Marquee will be fine once you figure out that garbled video issue. It was most likely from the glycol. I hope you figure it out. Some of the mods are actually not bad.
Id like to see the HVPS.
I bet he didn't know about the 33uf 700vdc Clarity caps they could have used instead of a bunch daisy chained together.
Hope you get it going though. Still a great deal, glycol problems are a bitch!!!
Motobias
| Posted: Tue Nov 27, 2012 3:20 pm Post subject: |
it's alive !
i cleaned the lenses yesterday evening and prepared everything to go back in.
this morning i put everything back together and fired it up... wohoo
connected laptop via hdmi on 1080p 59hz and it displayed without a problem.
convergence is rock solid and i just did a 5minute job on it.
couldn't be bothered with scheimpflug, astig, focus, etc... but i looks pretty damn good already !
i didn't take the hvps out, but i will do soon for a picture.
controllerboard aswell...i know you guys are craving for pictures of ugly mods
| Description: |
| Filesize: |
119.58 KB |
| Viewed: |
6624 Time(s) |
| Description: |
| Filesize: |
137.46 KB |
| Viewed: |
6622 Time(s) |
| Description: |
| Filesize: |
206.32 KB |
| Viewed: |
6627 Time(s) |
| Description: |
| Filesize: |
229.89 KB |
| Viewed: |
6633 Time(s) |
| Description: |
| Filesize: |
251.16 KB |
| Viewed: |
6640 Time(s) |
| Description: |
| Filesize: |
268.83 KB |
| Viewed: |
6644 Time(s) |
| Description: |
| Filesize: |
229.47 KB |
| Viewed: |
6631 Time(s) |
| Description: |
| Filesize: |
181.13 KB |
| Viewed: |
6629 Time(s) |
| Description: |
| Filesize: |
190.67 KB |
| Viewed: |
7060 Time(s) |
| Description: |
| Filesize: |
192.28 KB |
| Viewed: |
6630 Time(s) |
jbmeyer13
| Posted: Tue Nov 27, 2012 3:23 pm Post subject: |
Completely modding the PJ with wet tants everywhere is insanely expensive. I did this for the Conv and Stig boards for about $80 in parts. The VNB and power supplies are the areas where the dynamic range can be improved the most but there are other options that may potentially yield the same or better results for considerably less money. All of this is meaningless if the tubes aren't in top condition and the set up is first rate.
Motobias
| Posted: Tue Nov 27, 2012 3:26 pm Post subject: |
more pictures...
i fixed the phase later
i am projectiong on a piece of brown cardboard, which is not even plain.
distance at about 2,50m image width about 2,00m
| Description: |
| Filesize: |
124.45 KB |
| Viewed: |
6627 Time(s) |
| Description: |
| Filesize: |
127.53 KB |
| Viewed: |
6624 Time(s) |
| Description: |
| Filesize: |
172.25 KB |
| Viewed: |
6638 Time(s) |
| Description: |
| Filesize: |
165.05 KB |
| Viewed: |
6632 Time(s) |
| Description: |
| Filesize: |
139.28 KB |
| Viewed: |
6620 Time(s) |
| Description: |
| Filesize: |
168.24 KB |
| Viewed: |
6629 Time(s) |
stridsvognen Guest
| Posted: Tue Nov 27, 2012 3:50 pm Post subject: |
You did it..
Motobias
| Posted: Tue Nov 27, 2012 4:58 pm Post subject: |
i'll monitor the red tube for leaks and possible dislocation...so far it's all good !
checked the filament voltage aswell: 6,35V
and more pictures for your pleasure
controller board, power supply and the whole thing with case...
| Description: |
| Filesize: |
187.49 KB |
| Viewed: |
6699 Time(s) |
| Description: |
| Filesize: |
198.38 KB |
| Viewed: |
7087 Time(s) |
| Description: |
| Filesize: |
183.07 KB |
| Viewed: |
6691 Time(s) |
| Description: |
| Filesize: |
198.23 KB |
| Viewed: |
6689 Time(s) |
| Description: |
| Filesize: |
158.75 KB |
| Viewed: |
6689 Time(s) |
| Description: |
| Filesize: |
235.77 KB |
| Viewed: |
6685 Time(s) |
| Description: |
| Filesize: |
189.62 KB |
| Viewed: |
6680 Time(s) |
| Description: |
| Filesize: |
190.31 KB |
| Viewed: |
6684 Time(s) |
| Description: |
| Filesize: |
180.45 KB |
| Viewed: |
6683 Time(s) |
| Description: |
| Filesize: |
267.76 KB |
| Viewed: |
6689 Time(s) |
Motobias
| Posted: Tue Nov 27, 2012 5:01 pm Post subject: |
i wonder why whoever did all these mods, didn't replace the resistors !
Motobias
| Posted: Tue Nov 27, 2012 7:43 pm Post subject: |
looks like they are all in parrallel !
| Description: |
| Filesize: |
164.13 KB |
| Viewed: |
6691 Time(s) |
Motobias
| Posted: Tue Nov 27, 2012 8:33 pm Post subject: |
not enough voltage ?!
| Posted: Tue Nov 27, 2012 9:35 pm Post subject: |
| Motobias wrote: | | not enough voltage ?! |
Yes, having them in Parallel they increase the uf , so you add uf so 2 10uf caps equal one 20uf cap but the voltages get divided by the number of components. so if those are 600 volts then they are now 300 volts. The G2 section goes higher than 300volts. To increase voltage of multiple caps you put them in series, but then you halve the uf's.
The G2 section benefits from adding 20-40uf's. That looks like what they were trying to accomplish.
| Posted: Tue Nov 27, 2012 9:45 pm Post subject: |
| Nashou66 wrote: | | Motobias wrote: | | not enough voltage ?! |
Athanasios |
Excuse me, What? If you put capacitors parallel the capacitance will be added and the maximal voltage will be the lowest rating of all capacitors, if all caps the same, then no change.
10pcs. 1uF 600V caps in parallel equal to a 10uF 600V cap.
Motobias
| Posted: Tue Nov 27, 2012 9:48 pm Post subject: |
parallel caps:
capacity increases, voltage stays the same
series caps:
i wouldn't do that at all
