CRT's and the new OPPO 103, what HDMI>RGB TO use ?
virusc
Posted: Wed Oct 31, 2012 1:42 pm    Post subject:
thanks guys. keep the feedback coming
HaydnG90 - I am also using a ADA mach2 and I love it until I can afford a mach4. I have the MPA-500 amp connected to it.
I use a Runco 947 and barco 1100 right now and not sure how long I will use CRT (sold my 1209s).
I do not have the 83 but if I am going to spend $500 on a new player I wanted it to play video off of a HD of some sort. I heard the 83 is not that easy to use. Thanks to CIR post I think the 83 would be a better bet as I like to send composite video to the rest of the house which also the 103 does not do. Seems stupid to not have any analog video outs to me.
I have a gen1 moome ext but never got it to work right.
Anyone know if the middle atlantic shelf faceplate would be the same between the 83 and 103?
opv
Posted: Wed Oct 31, 2012 1:55 pm    Post subject:
virusc
Do you plan to connect the player through a video processor? Oppo-->VP-->moome--> PJ
Or directly to the moome card? Oppo-->moome-->PJ
virusc
Posted: Wed Oct 31, 2012 2:30 pm    Post subject:
I do not use the moome right now.
I connect all of my sources to a switcher. It is a barco RCVDS-05 so really this is a direct connection I guess. My 847 has component direct in so this is not a problem. I do have a transcoder that I have not used in years floating around. I think it is a extron.
The picture quality I get now is surprisingly good for a 7" crt projector. 1080i looks the best to me. With my 1209s I used to have this would not have worked and I used 1080p at various frame rates but that was 5 years ago.
opv
Posted: Wed Oct 31, 2012 2:38 pm    Post subject:
virusc ,
I'll rephrase my question,
How do you control the source signal timing or porch values?
Unless you're using an HTPC or have a VP, the default porches of a source device like the OPPO may not be appropriate for your CRT projector.
HaydnG90
Posted: Wed Oct 31, 2012 3:53 pm    Post subject:
Guess we have similar taste in audio gear. My ADA MACH 2 (Select Series) is feeding a MPA-500 too. Picked up the amp real cheap a month ago on Craigslist together with a matching BPA-500 subwoofer amp. The power capacity in the 500 beast is incredible. It takes a good 30 secs for the audio to drop out once its turned off. Build quality of the ADA processor was a revelation. The feel of the knobs and the switching feel are very old skool, but in a good way.
virusc
Posted: Wed Oct 31, 2012 4:20 pm    Post subject:
Ha, I have 2 500 base amps as well. Love them. use them for bass shakers though.
I have not had any problem so far with porch issues with 1080i from any device. Do you think this will not be true with the Oppo 83 or 103? I am sure I would if I was running a higher resolution. I was thinking of getting a older Lumagen for this like I used to have but not for awhile.
opv
Posted: Wed Oct 31, 2012 4:33 pm    Post subject:
I can't give an answer regarding the oppo.
What I can tell you is that in my chain including pop110 media streamer --> moome ext2--> BG1209s, I have several porch issues.
For example, the pre defined 1080P@60 & 1080P59 horizontal porches are too small and I can't get the full image to fit the raster.
In 1080P@50 the porches horizontal porches are too large, so I had to use very large raster width values for the image to be wide enough.
A VP in the middle of the chain would sure make my life easier.
Posted: Wed Mar 27, 2013 10:02 pm    Post subject:
CIR Engineering wrote:
Craig just noticed that the 103 can accept two HDMI sources!!! So can it take the 1080i@60 from a dish network box and have it output 1080p@24? Have you tried it if it is possible?
You know Tom, I am going to try this. I haven't watched the newest Dexter episode yet...
SO Craig have you tried this yet? I cant stand that the radiance can not down the refresh rate of 1080i@60 or 720p@60 to 1080p@24. If the newer oppos can do it well, Im buying one today. I watched the SD version of Dead men don't ware plaid on SD DVD from the oppo and its Up conversion of 480i to 1080p@24 is awesome!! IF it can do the same for 1080i@60 to 1080p@24 I'll be watching my blend more often for HD 1080i TV.
mc86
Posted: Wed Mar 27, 2013 11:34 pm    Post subject:
Nashou, if this does work, are you ready to consider a new home for your two HDQs? Wink
Matt
Posted: Thu Mar 28, 2013 5:49 pm    Post subject:
Not sure yet, I still have a need for at least one.
