Craig, maybe you can help. Radiance and HDCP with 24hz
Goto page Previous  1, 2, 3
Posted: Thu Nov 08, 2012 3:07 am    Post subject:
CIR Engineering wrote:
I had to enter the service code first. Then enter the code you
Sent me. It clears the calibration according to the menu
But it worked for what ever reason.
Well, the code I sent you actually clears a lot of things, not just calibration and user settings...
Wink
Yeah Jim told me that. Thats why I saved the settings before I did the Hard reset Wink
nashou
Posted: Wed Nov 14, 2012 2:08 pm    Post subject:
Craig, In the output set up menu i can't get the resolution changes I make to save when I exit out it goes back to what was there. It says other on the input side and I want it to be 1080p@24. Also I noticed on the second status scree there is for scaling x y they are on and i want it to match my other radiance which is off. It seams I lost the ability to save settings ? What did I do?
At work now so can't look at exactly what I did. I'll try to post pics of the screens side by side.
Posted: Wed Nov 14, 2012 3:27 pm    Post subject:
I am not quite sure what you are saying in the first bit about "other" and 1080p@24...
Try turning off "scale bias" to get your x-y scalers turned off.
Posted: Wed Nov 14, 2012 3:37 pm    Post subject:
In either output Setup menu from the input menu or the output menu you can select the resolution of the input device.
My one radiance is fine and has *1080p@4 selected(from my oppo) but the other one has the resolution *other selected.
and now that I think about it the "reference" radiance the res is selected as I want it and i dont think there is the "other" option is in the list of resolutions.
So when I select the resolution I want for the input of 1A it says other and I can not change it. It will not allow me to.
And with the scale Bias I do have that as off but it shows in the status menu its on?
I'll have to look at the manual some more, I hope I do not need to do a factory reset again and loose the calibration.
I wish there was a save function for just the CMS changes and nothing else.
It started when I went to hit the warm up screen menu code and must have hit some other code.
Also where it list the resolution in the status menu it should show 1080p but mine shows 1920x p .(spaces are there)
I wonder if i hit the menu code for 1080p@24 it will fix it? what is that again?
Posted: Wed Nov 14, 2012 9:14 pm    Post subject:
Ok pressing Menu 0 2 0 got me back to 1080p@24hz and fixed the scale bias.
I think I hit Menu 0 2 7 which is 1080p@60
Posted: Mon Nov 19, 2012 3:35 am    Post subject:
Well Now I have a bad Power supply!!! My one Radiance won't power up lights flash then it dies. Just sent an Email to tech support.
Bummer and I was loving the blend for a few days!!!
Page 3 of 3
