| Posted: Fri Oct 26, 2012 11:37 pm Post subject: |
Just to elaborate, where he says 1nf for the cap value that would be 10{-9} farad or 0.000000001% of 1 farad.
dturco
| Posted: Sat Oct 27, 2012 2:34 am Post subject: |
| macgyver655 wrote: | | Just to elaborate, where he says 1nf for the cap value that would be 10{-9} farad or 0.000000001% of 1 farad. |
Ohh. ok.
So if I say to you Pfeisteria shumwayae uses spiral flagellum as taxis at 3 um its as clear to
you as mud right?
http://www.hulu.com/firefly
| Posted: Sat Oct 27, 2012 2:17 pm Post subject: |
| dturco wrote: | | macgyver655 wrote: | | Just to elaborate, where he says 1nf for the cap value that would be 10{-9} farad or 0.000000001% of 1 farad. |
Ohh. ok.
you as mud right?  |
| Posted: Sat Oct 27, 2012 2:23 pm Post subject: |
And just to elaborate..... 3um = 3x10[-6] or 3 micrometers......
dturco
| Posted: Sat Oct 27, 2012 4:07 pm Post subject: |
| macgyver655 wrote: | | dturco wrote: | | macgyver655 wrote: | | Just to elaborate, where he says 1nf for the cap value that would be 10{-9} farad or 0.000000001% of 1 farad. |
Ohh. ok.
you as mud right?  |
Good, now that the size is known, picture is known... Linnaean FGS?
| Posted: Fri Nov 02, 2012 12:36 pm Post subject: |
Guys
First test is encouraging but the 1n caps are too small in value and too large in size; fitting caps to the crowded section of the board should prove interesting.
tse
| Posted: Fri Nov 02, 2012 2:04 pm Post subject: |
You could change the value of the original caps if there isn't enough room to add more.
Scott
Thomas Jefferson
dvh99
| Posted: Fri Nov 02, 2012 2:30 pm Post subject: |
wouldn`t it be easier to replace the caps that are switched on in long retrace mode and run the projector in long retrace only.
| Posted: Fri Nov 02, 2012 2:38 pm Post subject: |
| tse wrote: | You could change the value of the original caps if there isn't enough room to add more.
Scott |
Yes, once I determine the value needed. And a source for the caps, Vishay perhaps.
tse
barclay66
| Posted: Fri Nov 02, 2012 4:07 pm Post subject: |
| tse wrote: | These would work.
Scott |
I think that the label "MKP" is the key as it indicates pulse capacitors. "FKP" should be even more reliable. All of these are available from Wima too (see: http://www.wima.de/EN/products_pulse.htm).
Regards,
barclay66
| Posted: Sat Nov 03, 2012 4:53 pm Post subject: |
Guys
In order to make sense of this pico- nano- stuff, remember that in Michael Faraday's time, a One Farad capacitor was the size of your bathtub..........
| Posted: Tue Nov 06, 2012 4:38 pm Post subject: |
Guys!
I expect more parts here this afternoon to test with, and I have booked the use of a Quantum programmable pattern generator for test patterns at 1080i, 720p and 1080p. I want to know that optimizing for 1080p doesn't screw up display of the other resolutions.........
