HK-Steve
| Posted: Mon Oct 01, 2012 5:16 pm Post subject: Marquee Geometry Problem |
Hi Guy's,
turned my 9500 ON tonight, and have an issue with geometry.
The top of the test pattern and image, is tilted inwards at the top. see pic.
HDM or Vertical Board?????
Cheers
HK-Steve
| Posted: Mon Oct 01, 2012 5:17 pm Post subject: |
The bottom of the pattern is straight, just does not look like it in the pic.
Cheers
| Posted: Mon Oct 01, 2012 5:25 pm Post subject: |
Why would you not consider convergence board? Or DPB??
HK-Steve
| Posted: Mon Oct 01, 2012 5:50 pm Post subject: |
True, also possible for both.
Just trying to work out where to start,
not in the mood today to start swapping boards, that will happen tomorrow.
Cheers
| Posted: Mon Oct 01, 2012 5:55 pm Post subject: |
Helo
Copy that to a spare memory and reset the spare memory, see if it straightens out. It is all three colors, so maybe the HDM is not processing the H Key properly? HDM or control or DPB.
HK-Steve
| Posted: Mon Oct 01, 2012 6:10 pm Post subject: |
Thanks Tim,
just tried your suggestion, copied to new memory, same problem, also other memory blocks also the same problem.
Yes, it is all three colors. just at the top only.
Next ad break, will pull the CLM, reseat the DPB.
More to come.
Cheers
HK-Steve
| Posted: Mon Oct 01, 2012 6:12 pm Post subject: |
the chips have been de-socketed on the DPB, and directly soldered.
| Posted: Mon Oct 01, 2012 6:15 pm Post subject: |
| HK-Steve wrote: | Thanks Tim,
More to come.
Cheers |
Hey Steve
Unplug the green yoke from the convergence board, tell us what that does for the bending.
HK-Steve
| Posted: Mon Oct 01, 2012 6:23 pm Post subject: |
Tim,
I would have to pull the jumper off the convergence board, correct,
from memory, if I pull the connector off does that not damage the board??
HK-Steve
| Posted: Mon Oct 01, 2012 6:35 pm Post subject: |
Just pulled the CLM, re-seated the DPB.
No change to the problem.
Next ad break, convergence unplug.
Cheers
Guys
| Posted: Mon Oct 01, 2012 6:40 pm Post subject: |
Hey Steve
It is either going to be distortion of a waveform driving the convergence, or a waveform driving width modulation.
HK-Steve
| Posted: Mon Oct 01, 2012 6:48 pm Post subject: |
Pulled the green convergence coil off the board, same problem.
| Posted: Mon Oct 01, 2012 6:54 pm Post subject: |
| HK-Steve wrote: | | Pulled the green convergence coil off the board, same problem. |
Control board, DPB, HDM, vertical or ribbon cable for vertical, no particular favorites. What happened on the reset of the spare memory?
Try running H Key thru its' range, does the top track at all?
HK-Steve
| Posted: Mon Oct 01, 2012 7:00 pm Post subject: |
Running H Key.
the vertical lines, move a little at the top to the right, same direction as the problem,
but the bottom moves the full left and right.
Does that make sense?
HK-Steve
| Posted: Mon Oct 01, 2012 7:25 pm Post subject: |
Pin has exactly the same problem.
Just tried to change out to my spare HDM, but the HV did not turn ON.
So looks like my spare HDM it is busted, dam........
