Marquee Geometry Problem
HK-Steve
Posted: Mon Oct 01, 2012 5:16 pm    Post subject: Marquee Geometry Problem
Hi Guy's,
turned my 9500 ON tonight, and have an issue with geometry.
The top of the test pattern and image, is tilted inwards at the top. see pic.
HDM or Vertical Board?????
Cheers
HK-Steve
Posted: Mon Oct 01, 2012 5:17 pm    Post subject:
The bottom of the pattern is straight, just does not look like it in the pic.
Cheers
Posted: Mon Oct 01, 2012 5:25 pm    Post subject:
Why would you not consider convergence board? Or DPB??
HK-Steve
Posted: Mon Oct 01, 2012 5:50 pm    Post subject:
True, also possible for both.
Just trying to work out where to start,
not in the mood today to start swapping boards, that will happen tomorrow.
Cheers
Posted: Mon Oct 01, 2012 5:55 pm    Post subject:
Helo
Copy that to a spare memory and reset the spare memory, see if it straightens out. It is all three colors, so maybe the HDM is not processing the H Key properly? HDM or control or DPB.
HK-Steve
Posted: Mon Oct 01, 2012 6:10 pm    Post subject:
Thanks Tim,
just tried your suggestion, copied to new memory, same problem, also other memory blocks also the same problem.
Yes, it is all three colors. just at the top only.
Next ad break, will pull the CLM, reseat the DPB.
More to come.
Cheers
HK-Steve
Posted: Mon Oct 01, 2012 6:12 pm    Post subject:
the chips have been de-socketed on the DPB, and directly soldered.
Posted: Mon Oct 01, 2012 6:15 pm    Post subject:
HK-Steve wrote:
Thanks Tim,
More to come.
Cheers
Hey Steve
Unplug the green yoke from the convergence board, tell us what that does for the bending.
Posted: Mon Oct 01, 2012 6:19 pm    Post subject:
Down load your settings with marquee loader/Control program. Initialize the set. Now do a quick convergence and see if its there, if not
then re load the old settings and see what happens.
HK-Steve
Posted: Mon Oct 01, 2012 6:23 pm    Post subject:
Tim,
I would have to pull the jumper off the convergence board, correct,
from memory, if I pull the connector off does that not damage the board??
Posted: Mon Oct 01, 2012 6:32 pm    Post subject:
You can run the set with no convergence coils connected no problem.
HK-Steve
Posted: Mon Oct 01, 2012 6:35 pm    Post subject:
Just pulled the CLM, re-seated the DPB.
No change to the problem.
Next ad break, convergence unplug.
Cheers
Guys
Posted: Mon Oct 01, 2012 6:40 pm    Post subject:
Hey Steve
It is either going to be distortion of a waveform driving the convergence, or a waveform driving width modulation.
HK-Steve
Posted: Mon Oct 01, 2012 6:48 pm    Post subject:
Pulled the green convergence coil off the board, same problem.
Posted: Mon Oct 01, 2012 6:54 pm    Post subject:
Control board, DPB, HDM, vertical or ribbon cable for vertical, no particular favorites. What happened on the reset of the spare memory?
Try running H Key thru its' range, does the top track at all?
HK-Steve
Posted: Mon Oct 01, 2012 7:00 pm    Post subject:
Running H Key.
the vertical lines, move a little at the top to the right, same direction as the problem,
but the bottom moves the full left and right.
Does that make sense?
Posted: Mon Oct 01, 2012 7:08 pm    Post subject:
sounds like something is wrong with the keystone control from your description.
Posted: Mon Oct 01, 2012 7:17 pm    Post subject:
key and pin are controlled by the same circuit i think try pin and se what that does.
nashou
HK-Steve
Posted: Mon Oct 01, 2012 7:25 pm    Post subject:
Pin has exactly the same problem.
Just tried to change out to my spare HDM, but the HV did not turn ON.
So looks like my spare HDM it is busted, dam........
Posted: Mon Oct 01, 2012 7:40 pm    Post subject:
Steve those signals are generated on the VDM. So it might not be the HDM.
