Reality check: Been out of the loop
mutantaction
Posted: Sat Sep 08, 2012 10:07 am    Post subject: Reality check: Been out of the loop
Hey guys!
I'm new here Very Happy
I've been completely detached from the world of projectors for 6 or 7 years. I use my
Marquee 8500 everyday, and it never fails me. Since it's from 1998 or so I'm beginning to
think about recapping everything with panasonic/rubycon caps.
Then I get the thought....how much has happened in the last 7 years? Where are the DLP's etc
on the quality scale compared to an 8" Marquee(with Moome HDMI). How much would it cost
to get an DLP(or other?) digital-pj that has comparable or better image than the Marquee 8500?
I know that my Marquee can scan to 152kHz or the like and be way more flexible with resolutions
than the fixed res. digital pj's, but I've never really used it....Smile
I've also had the plan of building a 3-D HTPC since I have the glasses etc, but it never got off the
ground. So, it could seem that some of the CRT pros would never actually be used...
I REALLY love the Marquee. It's the ONE thing in my house that's ALWAYS working and never fails.
I have no desire for another projector, but I have to check in with reality! I learned that with
LaserDisc back in the day...where many of the LD-user maybe should have pushed more for DVD
than we did.
I'm asking this in the CRT forum...hoping for 100% brutal realism answers:)
Thanks!
RObert
mutantaction
Posted: Sat Sep 08, 2012 12:00 pm    Post subject:
...by DLP I mean LcOS, D-ILA and what ever else:)
Posted: Sat Sep 08, 2012 4:37 pm    Post subject:
ok, here's the BRUTAL, COLD REALITY, CHECK YOUR ASS AT THE DOOR answer .
Enjoy what you have Wink
There's no whiz-bang wonder box out there for a few hundred bucks. The better DILA based LCD's are a few grand.
mutantaction
Posted: Sat Sep 08, 2012 5:15 pm    Post subject:
Well, a few grand is pretty cheap....how much do Marquees go for these days?
On the other hand, those digital pj's seem to come and go like everything else....there's probably zero
chance of repair and there certainly isn't anyone making input-cards for them 20 years from now
(or mods)
How would the image be on a 2 grand digital LCD-ish compared with a Marquee 8500?
Posted: Sat Sep 08, 2012 5:46 pm    Post subject:
Unless it's a newly retubed 9" set, any other set at this point is more or less worthless. Dragan nailed it. Use it until it dies, and even then you can usually repair it for cheap. If you've consistently used it for a few years, then you most likely have some tube wear, and the set is worthless. I was offered a free low hour 8500 yesterday. I turned it down because it was in Fl, and shipping to me would have been $350 incl customs clearance.
mutantaction
Posted: Sat Sep 08, 2012 6:27 pm    Post subject:
Ok. I'll recap the machine and keep it. Which is what I mostly want to do. I just forced myself to be realistic. I love CRT's,
but also I owe to myself to push for the best image quality....even if that means getting out of CRT...which IS the hobby.
Paradox:)
The machine has never had a problem of any kind. It has a die-hard community and it even has hardware being built
just for it. It's a real workhorse and even though it's only 8", I think I have a great image.
I wonder how much I should expect from a cap change. I take it that the focus module will give me the most?
I just wonder if the bottleneck is the beam size and not the focus module?
Phoenixed
Posted: Sat Sep 08, 2012 6:32 pm    Post subject:
mutantaction -
An 8500 with mods can smoke a 2k digital. Trust me.
Planar PD-8150/Runco LS-5
mutantaction
Posted: Sat Sep 08, 2012 6:37 pm    Post subject:
Phoenixed, in your signature you say that you have 1080p on an 8" ? Is that with normal HD-8's?
Posted: Sat Sep 08, 2012 7:12 pm    Post subject:
Run 1080p@48 hz and it will look fine for 16x9 aspects and then run 800p@60 or 72 for 2.4 aspect movies. its called active area scanning
and only scans the area of a blu Ray with an active image. the black are above and below the 2,4 movies is ignored by the scaler and PJ therefore freeing up bandwidth.
http://www.avsforum.com/t/737385/want-to-optimize-your-scaler-and-crt-calculations
Posted: Sat Sep 08, 2012 7:45 pm    Post subject:
the focus module is one of the smallest gains, there's very little noise or performance degradation coming from the FCM.
Doing capacitors overall is fine , it restores some reliability and gives some degree of performance improvements especially on high hour machines. However to truly unlock the machines potential there's some additional electronic filtering that should be done in the video chain and the stock lenses should be replaced with HD-145 color filtered ones.
Top it all off with a pro calibration and you really leap forward in pic quality.
mutantaction
Posted: Sat Sep 08, 2012 8:06 pm    Post subject:
The HD-145 lenses sounds a little too much, as do the filtering. I hope that a regular cap change will, as you say, give me
some improvement + prolonging the problem-free life of the unit
I'll recap the LVPS too.
I can see that many of the caps are already good Rubycons, but they're pushing 15 years now
Where do I see the number of hours? in the 0901 menu?
Phoenixed
Posted: Sun Sep 09, 2012 3:08 am    Post subject:
Yes on the 8 inch and no I am running hd145s and my machine is modded to the hill.
mutantaction
Posted: Mon Sep 10, 2012 5:42 am    Post subject:
Ok, that sounds amazing !
Jeremy112
Posted: Mon Sep 10, 2012 3:09 pm    Post subject:
Glad you've decided to stick with CRT, I still dont understand how people can watch a puky digital image on such a large format, especially if its not HD on a HD digital projector!! At least SD looks incredible on a CRT projector, something no digital will ever be able to do good unless its one of those super low resolution antique digitals Very Happy
I also have a recommendation for capacitors. 15 years ago Rubycons may have been some top notch caps, but these days I have found them to be a lot less reliable than some other brands, such as Nichicons.
In all of the electronics I've ever repaired, when it comes to capacitors, Nichicons have been THE MOST reliable capacitor I have used. Not only are they reliable, but their specs are usually right on or damn close when you purchase brand new ones. I have found that that is not the case with several other brands like Samxon or Rubycon.
That doesn't mean that every capacitor by Rubycon is a POS, but I've only ever seen 2 domed Nichicon capactiors in anything I've repaired with the Nichicon caps installed.
I just replaced 14 capacitors in a power supply of a TV that used Rubycons. They didnt physically look bad at all, but once I replaced them the voltages went back to spec and the TV operates flawlessly as it should.
Like I said, I'm not saying rubycons are the worst, but if you are looking for THE MAX in reliability and performance, spend some bucks on some high end Nichicon caps, especially if you really love the projector and don't want to get rid of it anytime soon.
My NEC XG1100 dates back to.... I THINK 1997, not entirely sure, but pretty sure. I haven't done a single bit of work to it other than use it and replace all 3 tubes because they were pretty toasty and one cracked.
If I were you, and I was looking to get at least 70% better PQ, I would not only do the capacitors, but I WOULD DEFINITELY get the HD-144 or HD-145 Color corrected lenses, the difference is HUGE, I mean VERY HUGE, not just a little "Oh that does look a bit better", I mean "DAMN, Look at the image, and people traded these boat anchors for 10 minute setups and perfect geometry??"
So my 2 cents, don't have to use a darn bit of it, but I think it would make you much more happier in the long run.
mutantaction
Posted: Mon Sep 10, 2012 11:05 pm    Post subject:
Thanks for the advice! I usually feel safe with Rubycon/Panasonic/Nichicon, and will use them as a toss up:)
Well, I'm almost afraid to ask...how much does 144's cost? I assume some brackets will be needed too?
Phoenixed
Posted: Mon Sep 10, 2012 11:31 pm    Post subject:
Try looking around here in the buy/sell forum here. Theres also a whole 8500 ultra being sold with everything needed somewhere on the net.
OR just ask Curt.
Posted: Tue Sep 11, 2012 12:18 am    Post subject:
Not sure if I have 144s, but I do have 145s at $100/set.
HighDefMike
Posted: Tue Sep 11, 2012 1:51 am    Post subject:
Jeremy112 wrote:
....If I were you, and I was looking to get at least 70% better PQ, I would not only do the capacitors, but I WOULD DEFINITELY get the HD-144 or HD-145 Color corrected lenses, the difference is HUGE, I mean VERY HUGE, not just a little "Oh that does look a bit better", I mean "DAMN, Look at the image....
draganm wrote:
.... However to truly unlock the machines potential there's some additional electronic filtering that should be done in the video chain and the stock lenses should be replaced with HD-145 color filtered ones.
Just chimin' in. The truth is definitely being spoken 'bout the HD-145s and pro calibration.....I have a lowly 8500 as well..with a v1.3 Moome card & HD145s with the Joust mods....and the image is sweet! Blu-ray @1080p 60 is jaw dropping.
ChadB was just here 08/29 for a professional touch-up of my 8500, and the picture quality is just ridiculously stupid as far as picture quality. Shocked The HD145s are well worth it; both color and focus-wise.
Hey Curt, I put the Vision 2 case (metallic-flake, custom-painted I might add Thumbs Up ) on my original 8500, & afterwards when I fired up the Vision 2, it was no longer giving me that weird double image on the menu...go figure. It still says M8000 though in the menu.
This badly-taken photo was before I transferred the case to my original 8500. The sofa in my HT is 'bout the same color; same carpet in HT as well...light/ice blue
Posted: Tue Sep 11, 2012 2:01 am    Post subject:
Damn Mike, that's a SWEET color!
mc86
Posted: Tue Sep 11, 2012 3:51 am    Post subject:
MutantA - Actually, Curt DOES have a set of 144s and they are in my storage area. He accidentally sent them to me this spring (instead of 145s) and I told him I'd sit on them until he had a buyer. It just seemed silly to spend ~$30 mailing them back to him. Anyway, if you and Curt work out a deal, I'd be happy to send them to you (and my wife would be even happier) from Pittsburgh.
I am pretty sure for your 8500 you would need the mounts, but others will chime if not true...
cheers,
Matt
