What Colorimeter are You Using
Goto page 1, 2, 3  Next
AFryia
Posted: Fri Dec 15, 2006 4:35 pm    Post subject: What Colorimeter are You Using
Specifically for front projection CRT's what colorimeter are you using (hardware/software)?
Any issues with FP CRT's?
Does it work with other displays?
Z-Photo
Posted: Fri Dec 15, 2006 4:59 pm    Post subject:
Mark 1 eyeball. Smile
but I am looking into a spyder2.
Engineer by Day
Photographer by Night
My Portfolio
Brian Hampton
Posted: Fri Dec 15, 2006 5:00 pm    Post subject:
Pantone ColorVision Spyder 2.
Does it work with other display types? Well, it's designed for other display types mainly directview CRT and LCD.
Does it work for CRT FP? I think it works pretty well. It seems responsive in all the right ways. I mainly went this route because it was cheap (under $100).
-Brian
Bruce 09
Posted: Fri Dec 15, 2006 5:21 pm    Post subject:
I use the philips Colorimeter, it is specific for CRT's , But I have used it on a couple friends digital before
http://www.testequipmentdepot.com/philips/colortruth/pm563900.htm
http://www.testequipmentdepot.com/philips/colortruth/pm563925.htm
I Have them both the three headed sensor is meant to measure three points for white field uniformity, but I use the three head sensor directly over the crt lenses and adjust the three colours all at once.
Doing Greyscale at the projector or right at the screen on my screen yeild very similar results .
Bruce
aspec2
Posted: Fri Dec 15, 2006 7:27 pm    Post subject:
Colorfacts 6000
Walt
AFryia
Posted: Fri Dec 15, 2006 9:05 pm    Post subject:
What is the difference between a Spyder2 and Spyder2 Pro?
My Volt Blog
JustGreg
Posted: Fri Dec 15, 2006 9:08 pm    Post subject:
Bruce
$7K for a rarely used tool for a hobby all over what is probably a sub $5K projector?????? Shocked And you have two of the things??? Huh. Unless you're doing ISF, or are the idle rich, hire a pro to set it up. There. I jsut saved you money. Feel free to send me just 50% of what I just saved you and we'll call it even. Mr. Green
Greg
Z-Photo
Posted: Fri Dec 15, 2006 9:10 pm    Post subject:
yeah -
Art's setup is out of hand also. But you do not see me complaining about how he spends his money. Smile
no one said this hobby made sense.
Engineer by Day
My Portfolio
Tinman
Posted: Fri Dec 15, 2006 9:15 pm    Post subject:
Bruce
Ditto. I love my Philips. I do have colorfacts 6000 pro, but never use it since the Philips. That's why I'm selling it. The Philips gives me the same results and is MUCH faster.
Marc
This space for rent.
Posted: Fri Dec 15, 2006 9:21 pm    Post subject:
I have an old Minolta TV2150. Nothin' fancy but it seems to do the job.
Alaric
Posted: Fri Dec 15, 2006 11:18 pm    Post subject:
Hi There,
Spyder2 with CalMAN.....The spyder2 express/pro/tv all have the same sensor the difference is the software (and price).
The only useful software is the TV, as this will also do main brightness/contrast, however if your happy with DVE/AVIA and eyes then the Express is cheaper.
The CalMAN software is great and getting better, it uses the spyder2 hardware and its own software, so any of the packages will run with it.
You can with the TV service mode or with extra Optical (the old software software) get the data out XYy (?) and use a spreadsheet and maths to get thier the cheap way, or there is a frech piece of software that may work....it was detailed in another thread and due to a dead PJ (SMPS fail) i've yet to try it.
cya,
Lee
AFryia
Posted: Sat Dec 16, 2006 4:53 pm    Post subject:
That is what I'm wondering about. What is the bare minimum package that will accurately measure a FP CRT color temp, tracking, gray scale, white balance etc.
The sensor may be the same but are all the software package able to read/sense a FP CRT.
ChrisOH
Posted: Sun Dec 17, 2006 9:15 am    Post subject:
I came at this from a slightly different perspective over on the UK forum and got some very comprehensive stuff about Spyder and associated software from Lee (Alaric).
Makes some interesting reading
http://www.avforums.com/forums/showthread.php?t=436229
Thanks again Lee
Chris
AFryia
Posted: Sun Dec 17, 2006 8:13 pm    Post subject:
I thought I read that the Spyder2 Pro does not adjust the primaries?
Stupid question but aren't the RGB tubes the primaries?
signed: looking for enlightenment
Posted: Sun Dec 17, 2006 11:07 pm    Post subject:
Its unfortunate that no one makes an elaborate freeware program (GNU Public License) the use the Spyder2 sensor.
SYC
Posted: Mon Dec 18, 2006 12:00 am    Post subject:
I have only Spyder2pro, DVE, and AVIA. Is it enough to calibrate the CRT FP? Or I have to buy Calman?
SYC
Posted: Mon Dec 18, 2006 4:28 am    Post subject:
I also use the TV2150. It takes a bit of getting used to but works fine for me. It does wig out below 20 IRE. But if you can get your PJ to track flat all the way from 100 IRE to 20 IRE, there's no reason to think that it's going to run to far out in the last 20 IRE that you can hardly see anyway.
Lyckman
Posted: Mon Dec 18, 2006 8:19 am    Post subject:
Someone did..actually. And it is really good. Smile
http://www.avsforum.com/avs-vb/showthread.php?t=737550
It also has support for Monaco OpticXR (DTP-94), which is better compared to Spyder2. (I have both).
// Lyckman
igroucho
Posted: Mon Dec 18, 2006 1:10 pm    Post subject:
Trichromat here (+CF 6.0)
AFryia
Posted: Tue Dec 19, 2006 12:18 am    Post subject:
Just got a reply from ColorVision.
What up with this?
wrote:
Sorry, no ColorVision products support CRT projection.
Bob Cxxxxxxxxxx
ColorVision Customer Support - USA
1-800-554-8688
***Please make sure the Ticket ID remains in the subject at all times.***
Ticket Details
Ticket ID: JJB-747985
Department: Digital Imaging - USA/Canada
Priority: Medium
Status: Closed
Page 1 of 3
