jeffslife
| Posted: Mon May 14, 2012 6:36 pm Post subject: |
Yeah I'm fine, Thanks for asking. I am going to try that and then I'll post back.
jeffslife
| Posted: Mon May 14, 2012 7:06 pm Post subject: |
It worked. I have a good image. The VP and BD are set up under the PJ so no sound, I will try to work the Denon into the chain next.
Anything I should do to it first ?
jeffslife
| Posted: Mon May 14, 2012 7:14 pm Post subject: |
I was using the Denon as a switcher.
| Posted: Mon May 14, 2012 7:24 pm Post subject: |
| jeffslife wrote: | It worked. I have a good image. The VP and BD are set up under the PJ so no sound, I will try to work the Denon into the chain next.
Anything I should do to it first ? |
You might want to try the Lumagen back at your equipment rack using your long HDMI cable.
Jeff do you have an HDMI-HDMI cable for your long run, or is it DVI on one end or something? Do you know which HDMI cable you have?
jeffslife
| Posted: Mon May 14, 2012 7:30 pm Post subject: |
HDMI -HDMI
22 awg/10c+24awg/5c 80 degree C 30 V vw-1 high speed hdmi
30 foot
| Posted: Mon May 14, 2012 7:39 pm Post subject: |
| jeffslife wrote: | HDMI -HDMI
30 foot |
That should be ok. Is it the silver plated copper do you remember?
jeffslife
| Posted: Mon May 14, 2012 7:43 pm Post subject: |
I think so, It was the best one monoprice had about a year ago. I will see if I can check the part #.
Putting the denon in and it went right back to noise. No image at all.
| Posted: Mon May 14, 2012 7:57 pm Post subject: |
Oppo HDMI 1 > Lumagen > Projector
Oppo HDMI 2 > Denon
That should be the same thing. Did it go back to noise because of the Denon or the long cable?
jeffslife
| Posted: Mon May 14, 2012 8:11 pm Post subject: |
Just got off the monoprice site, cable was not silver plated copper, I am going down to test now.
jeffslife
| Posted: Mon May 14, 2012 8:17 pm Post subject: |
I have an image (not going through the Denon) but the PQ is slightly less than when it was on just a 6 foot cable.
Is there a setting on the denon I can change or is it just problamatic ?
| Posted: Mon May 14, 2012 8:20 pm Post subject: |
Let me mess with it when I get there.
Did you order/get the HDMI extender?
jeffslife
| Posted: Mon May 14, 2012 8:22 pm Post subject: |
not yet, going to today. Also want to get a new cable too. silver plated copper ?
jeffslife
| Posted: Mon May 14, 2012 8:24 pm Post subject: |
I better check, I am not sure if I ordered the repeater and it was backordered or not. I have some other things on backorder too.
In any case it will be here before you are.
jeffslife
| Posted: Mon May 14, 2012 8:37 pm Post subject: |
I am going to hang the G90 in the second week of june if all goes to plan, I took too much flack for not trying it first.
Craig says he can make it go with a movable screen. I am going to hang it right where the G70 is and then make the screen temporarily mobile. It took a little but the support staff here talked me off the ledge. So by July I should be enjoying the G90.
I almost cant bear to take the G70 down,Craig made it look so good. I am going to hang it on the other side of the basement where the kids game room is.(That way I can still visit it.)
jeffslife
| Posted: Mon May 14, 2012 8:48 pm Post subject: |
I was checking the Denon and it doesnt appear to support 1080 P 24
The closest was 1080 P 30
So should I order a DVI - HDMI cable or just get a HDMI-HDMI
Also it would appear that I will also need a switcher along with the extender,I will see if I can find an ALL IN ONE unit.
| Posted: Mon May 14, 2012 9:26 pm Post subject: |
| jeffslife wrote: | I was checking the Denon and it doesnt appear to support 1080 P 24
Also it would appear that I will also need a switcher along with the extender,I will see if I can find an ALL IN ONE unit. |
You don't need a switch. Jeff, you are going to use the two outputs on the Oppo; output 2 will be for audio only so your Denon will be fine and your other sources will be fine. Just get the cable and extender.
Order HDMI-HDMI silver plated copper 22 awg. The DVI-HDMI cables are lower quality. Have a DVI-HDMI converter for the cable.
The Monoprice cables have the best compatibility with Lumagen over long runs. Better than BJ in my findings.
If you already have all HDMI cables just get HDMI-DVI converters to plug into the back of the Lumagen for your short cable runs. For the short ones it does not really matter, but for the long one get HDMI on both ends.
jeffslife
| Posted: Mon May 14, 2012 9:34 pm Post subject: |
I thought you said something to that point so I went back and re read the thread. I get it now. I will check my order status on monoprice and get everything ordered. THANKS !
jeffslife
