bachiano
| Posted: Fri Feb 24, 2012 7:37 pm Post subject: G70 - Horizontal mechanically convergence of Blue and Red ? |
Is there a way to mechanically converge the Blue and the Red with the horizontal Green?
Or
Just use cent to converge?
| Description: |
| Filesize: |
210.7 KB |
| Viewed: |
8471 Time(s) |
Motobias
Joined: 08 Jul 2008 Posts: 163 Location: Osnabrueck, Germany
| Posted: Fri Feb 24, 2012 7:47 pm Post subject: |
no... rest is gonna be either pots or digital convergence !
looks pretty good to me already...
bachiano
| Posted: Fri Feb 24, 2012 9:16 pm Post subject: |
Are there pots on the g70 for this ?
Where are they?
Motobias
| Posted: Sat Feb 25, 2012 12:15 am Post subject: |
check the manuals or service documentation !
_________________ Most peope talk about HD without knowing the meaning and how to do it RIGHT !
FIGHTING STUPIDITY SINCE 1983
AFryia
Joined: 09 Mar 2006 Posts: 965 Location: S.E. Michigan VPH-G70Q
| Posted: Sat Feb 25, 2012 1:00 am Post subject: |
| bachiano wrote: | Are there pots on the g70 for this ?
Where are they? |
I don't recommend messing with any pots.
Your mechanical aim and horizon look very good as is.
bachiano
| Posted: Sat Feb 25, 2012 2:12 am Post subject: |
Ok - I'll just use cent then.
| Posted: Sat Feb 25, 2012 2:53 am Post subject: |
Use CENT to align the cross hairs on top of each other.
Then do the rest of the alignment/centring/bow/skew etc and end up back on the ZONE page to adjust everything but the center. If you have it well set up you should either need no ZONE or only a few clicks to finish up.
EDIT: I RTFMed, sorry was thinking of the 12xx series Moon manual.
| Posted: Sat Feb 25, 2012 6:06 am Post subject: |
Are the yokes firm up against the bells?
bachiano
| Posted: Sat Feb 25, 2012 3:30 pm Post subject: |
| CasetheCorvetteman wrote: | | Are the yokes firm up against the bells? |
Why?
In the mean time I'll go check.
AFryia
| Posted: Sat Feb 25, 2012 5:10 pm Post subject: |
| AnalogRocks wrote: | Use ZONE Centring to align the cross hairs on top of each other. Don't touch any other Zone settings.
Then do the rest of the alignment/centring/bow/skew etc and end up back on the ZONE page to adjust everything but the center. If you have it well set up you should either need no ZONE or only a few clicks to finish up. |
AR Zone and Cent are different controls on the G70.
Cent H&V is used to align the cross hairs.
Zone is for final tweaks to select spots on the screen. 21 I believe in a G70, never counted em, and 40 or 50 on a NEC XG
Its best to not use Zone but you almost always end up using some.
| Posted: Sat Feb 25, 2012 8:20 pm Post subject: |
Is the G70 different than the D50's setup?
EDIT: never mind, I read that in a 12xx manual.
bachiano
| Posted: Sat Feb 25, 2012 10:55 pm Post subject: |
Yes.
| Posted: Mon Feb 27, 2012 2:51 pm Post subject: |
Don't even think of using any pots on a G70. You are good to go, just start using the convergence controls.
bachiano
| Posted: Mon Feb 27, 2012 6:02 pm Post subject: |
| CIR Engineering wrote: | Don't even think of using any pots on a G70. You are good to go, just start using the convergence controls.
craigr |
Ok!
Thanks craigr
| Posted: Mon Feb 27, 2012 6:08 pm Post subject: |
This is counter intuitive, but I will suggest that you do your mechanical alignment to the sides of the image rather than the center. Look into the tubes and create your 16x9 raster so that it is equidistant from either edge of the sides of the tube face. Then use the cross pattern to align the cross hatch hatches that are closest to the edges, not the center.
When you perform physical alignment this way you will wind up using more of the usable phosphor and the image will be more evenly distributed across the tube face. This means brighter image and sharper image.
bachiano
| Posted: Mon Feb 27, 2012 9:06 pm Post subject: |
Hi Craig
Can you elaborate a little more.
I read a previous post of your on this but I did not understand it either :-/
I'm ceiling mount btw.
| Posted: Tue Feb 28, 2012 12:34 am Post subject: |
| bachiano wrote: | Hi Craig
I'm ceiling mount btw. |
Sure, in the photo below, align the cross so that you get RGB (white) at the sides (circled in red). Don't worry what happens in the middle (circled in green, this can be misaligned). It is basically the opposite of the way you did it.
Before you start alignment, look inside the tubes and adjust the left and right edges of the cross (in each tube) so that they are equidistant from the edges of each tube on both sides. Then physically move (spin) the tubes such that the edges align on the screen.
Get it? It is kinda confusing,
| Description: |
| Filesize: |
190.82 KB |
| Viewed: |
8243 Time(s) |
Last edited by CIR Engineering on Tue Feb 28, 2012 2:15 am; edited 2 times in total
AFryia
| Posted: Tue Feb 28, 2012 1:19 am Post subject: |
| CIR Engineering wrote: | | Before you start alignment, look inside the tubes and adjust the left and right edges of the cross (in each tube) so that they are equidistant from the edges of each tube on both sides. |
It is easier with the lenses removed. you will see the edges of the tube more clearly.
BTW you will need to ground the lens leads for the PJ to operate.
bachiano
| Posted: Tue Feb 28, 2012 3:48 am Post subject: |
Craig
I think I kind of get it.
I'll try it tomorrow.
I'm sure it will make more sense once I've played with it.
bachiano
| Posted: Tue Feb 28, 2012 3:56 am Post subject: |
| AFryia wrote: |
BTW you will need to ground the lens leads for the PJ to operate. |
Once I've taken the lenses off.
What do I use to gauge the distance from the edge of the haircross / crosshatch to the edge of the tube
without touching the C element?
Does this have to be really precise or can I eyeball it?
