HELP 4000G
Goto page Previous  1, 2, 3, 4 ... 11, 12, 13  Next
Posted: Wed Dec 13, 2006 3:02 pm    Post subject:
It's like a Barco, there's too much pin or key top and bottom. Try backing off on those towards the 50% mark and see which one causes the line to go away.
Z-Photo
Posted: Wed Dec 13, 2006 4:32 pm    Post subject:
Curt-
AAAAAHHHHHHHHH
We will have to ban you from your own website for a remark like that.
the nerve. Smile
Engineer by Day
Photographer by Night
My Portfolio
Posted: Wed Dec 13, 2006 4:33 pm    Post subject:
Z-Photo wrote:
Curt-
AAAAAHHHHHHHHH
the nerve. Smile
What is that a dirty little secret Z? Twisted Evil
Z-Photo
Posted: Wed Dec 13, 2006 4:36 pm    Post subject:
No (not a secret) - He compared a Barco to an (gasp) Ampro.
I am now so upset that I may have to leave work. Smile
Engineer by Day
My Portfolio
Posted: Wed Dec 13, 2006 4:53 pm    Post subject:
Ok I'll try again. I've run the set up 5 times so far. The last three I set up were for:
480P off the line doubler
1024x768@60Hz off the HTPC
1440x960@60Hz off the HTPC
All three ended up with the line, but I will try again. At least I'm learining something. The way Barco uses these codes is kind of interesting.
Posted: Thu Dec 14, 2006 2:51 am    Post subject:
Z-Photo wrote:
Curt-
AAAAAHHHHHHHHH
the nerve. Smile
Sometimes the truth hurts Laughing
Posted: Thu Dec 14, 2006 6:06 am    Post subject:
Is that any worse than you stripping an Ampro to put the( now contaminated with Ampro coutties) tubes in the Barco? Wink
Doesn't that make it a BarAmp or a AmpCo?
Posted: Fri Dec 15, 2006 12:24 am    Post subject:
Ok this horizontal black line is bugging me. It COMPLETELY disappears when I turn of the registration (55 CODE). I tried resetting the channel to 50% across the board but it didn't help. Even with all the Key and pin at 50% there's a black line across the picture.
Incova sent me this:
incova wrote:
This is from av forums uk I remember reading it about a year ago so I did a quick search just for you.
Scott wrote:
Just finished my cinema room in the attic. I've got the 801 on the ceiling projecting on to a 8ft screen. I've got an Iscan pro connected. Problem is a line across the centre of the screen. Any thoughts?
Scott
The Reply wrote:
I had a horizontal line on a barco 808s......thin black line right thro the centre of picture....see crtprojectors.co.uk FAQ on barcos...its due to maladjustment of bow on top and bottom of pic...pic is made of 2 halves joined horizontally and you are seing the "gap"...
absolutly the bow is over adjusted. Just check all your settings anything to extreme on a crt like 80 % to correct something means that you may cause problems, i try and keep everything as close to 50% settings on the barco so nothing is stressed, tube or electronics. Yours is es I assume you have knobs or some other means of adjustments, try anything to get the line away no matter what it does to distort the screen then work backwards to see what causes the line.
good luck mate.
Does the Ampro do the same soft of thing? Is it treating the picture as two half's top and bottom? If so how can I make the two overlap with the registration on? Is there an adjustment pot on the registration board or something?
Jeremy
tse
Posted: Fri Dec 15, 2006 1:07 am    Post subject:
Which registration bd do you have? There should be a little sticker with a 8XXXX number on it. I might be able to find something on it. There probably is a pot to adjust.
Scott
Thomas Jefferson
Posted: Fri Dec 15, 2006 4:43 am    Post subject:
Scott
Thanks Scott I'll let you know.
Jeremy
Posted: Sat Dec 16, 2006 5:37 pm    Post subject:
OK Scott, the number is 80833. The 65298 REV A on the circuit board and beside the 80XXX sticker there's a 2nd sticker that says 5309-07.
Thanks.
Let me just make sure this is the right board Scott. It's the one right next to the power supplies?? It has two little pots on the back for the vertical postioning of the red and blue rasters. Is this the right board?
 Filesize:  129.14 KB
 Viewed:  9311 Time(s)
Posted: Sat Dec 16, 2006 5:58 pm    Post subject:
Let me send you a new reggie board and the convergence output board. Email me the two numbers (6XXXX) to my home address. I didn't see the issue here, but I didn't see the HVPS/LVPS ones either..Smile
tse
Posted: Sat Dec 16, 2006 7:15 pm    Post subject:
The board that is circled is the vertical deflection. Your registration bd is in the big black box toward the front of the pj. It sounds like Curt is going to help you out. That's your best bet. These old projectors will come up with problems when you start using them after they sit unused for a while. Once all the problems are worked out they should work fine for a long time.
Scott
Thomas Jefferson
Posted: Sat Dec 16, 2006 11:03 pm    Post subject:
Ok thanks for the clarification Scott. I was going by the 4600 layout tips on the website.
Hey Curt, you ever going to do a board labeling picture for the 4000? It would make things a little easier for me. Smile
Ok I'll make things easier for you. Can you please fill in the blanks 1, 2 and 3?
EDIT: Here's the updated pic for reference
Board Layout Ampro 4000G
 Filesize:  113.93 KB
 Viewed:  9224 Time(s)
Posted: Sat Dec 16, 2006 11:51 pm    Post subject:
Yo Anie
Look at the mother board where the socket is. They are labled Wink
Posted: Sun Dec 17, 2006 1:07 am    Post subject:
DOH!! I have the projector high up on a cart. I took that picture while balancing on a chair. LOL I'll have to make some stilts. Thank's for the tip Chip.
Suddenly I feel like singing "It's a small world after all" Wink
Posted: Sun Dec 17, 2006 1:34 am    Post subject:
One more thing. I think it might be cable related. I get fast horizontal lines that roll up the picture quikly. They change thickness when I went from 60Hz to 72. Is this a cabling problem?
Posted: Sun Dec 17, 2006 2:41 am    Post subject:
That might be a ground loop. Try lifting (breaking) the ground pin off the Ac cord and see if they go away.
Posted: Sun Dec 17, 2006 3:24 am    Post subject:
Ahh I was thinking maybe a ground loop. I'll try that.
Posted: Wed Dec 20, 2006 12:14 am    Post subject:
Email sent. I think I got the right numbers. Let me know. No hurry.
Page 3 of 13
