how far can we take our hobby?
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Posted: Fri Jan 20, 2012 8:40 pm    Post subject:
Boilermaker wrote:
Along comes the digital display device, which does not really transform it into the analog domain, but processes it in various ways (depending on display type) in order to "emulate" analog light as were are used to. It attempts to "fool" your eye/brain into thinking it is analog. It is here that I believe something (and I don't have the faintest idea of what it is!) is amiss, which is why we have the quoted statement above.
Bob
Thanks for this excellent illumination on the subject.
I've yet to see a digital display (regardless of cost), that did not have that artificial look to it..
Posted: Fri Jan 20, 2012 8:54 pm    Post subject:
Bob,I agree... To an extent... But, it's also worth pointing out that a scanning electron beam on phosphor-coated glass (with differential decay rates), and non-linear amplified light output... While that stuff is "analog" in nature, they aren't exactly "realistic" representations of nature, either.
Analog was not without its flaws, either... Most of the consumer broadcast mechanisms used HF rolloff filters and subsampling to get the signal into an allotted bandwidth.
But, I agree that CRT has a great look - I've always loved it. But, I see its flaws, too.
jbmeyer13
Posted: Fri Jan 20, 2012 8:55 pm    Post subject:
Boilermaker wrote:
But for movies, there is just some sort of intangible reason why i prefer the softer analog picture
While I never saw one, maybe someone on this forum has seen the analog HD Laser Disc system that was developed in Japan, and never was marketed anywhere else. If I recall it had 1050 lines, but I'm not sure. Because it was pure analog from camera to your display, it was probably superior to our new 1080i HD. Does anyone remember seeing one of these
Bob
You are talking about the MUSE system. Pioneer made a few players (HLD-X9, HLD-X0) and they were (and still are) very expensive. There was a small library of titles (Terminator 2 was notable) but the format never went anywhere. I've never seen one but they are supposed to be very good.
Boilermaker
Posted: Fri Jan 20, 2012 8:58 pm    Post subject:
Just a wild guess, but perhaps that is why you almost always see a Pixar movie used as demo material when shopping for projectors, etc. It never was in analog film. Advantage-Digital.
Bob
Posted: Fri Jan 20, 2012 9:09 pm    Post subject:
Boliermaker: You're right: the less the conversion, better the quality (in every aspect), but it seems the nano world is much like digital world (discrete steps) instead of analog.
Boilermaker
Posted: Fri Jan 20, 2012 11:42 pm    Post subject:
Yes, but this was not a flaw being analog, it was caused by a bandwidth restriction set 3/4 century ago. Now, the tremendous advantage of digital shows up here. Look at how much information we are now getting from that same bandwidth in digital format. No contest!
I find one thing interesting if you will follow this:
Using digital techniques while the signal is still in the digital domain, I blend two halves of the original signal using two analog projectors to end up with a 2.4 AR picture and have an approximate 300% gain in light output, greatly enhanced resolution capability, and effective doubling of video bandwidth. This is a 100% digital manipulation with no artifacts or other anomalies.
Now - If I had a digital projector and wanted to use a 2.4AR screen, I would use a digital method to "remap" the 800 lines to 1080 lines, AND an analog method of using a non-linear lens to end up with a 2.4 AR. However slight, there must be some anomalies with the 800 to 1080 digital remapping and there is surely some slight abberations with the non-linear lens.
Digital blending of two analog projectors is a more "lossless" method of having a 'scope presentation than the present analog & digital method used on digital projectors. I understand that soon there will be 2.4 digital projectors, but I don't know what the resolution is, so the verdict is still out on those until they appear.
I suggest you get another G-70!
Bob
Posted: Sat Jan 21, 2012 5:21 pm    Post subject:
I would be interested to see what everyone here would choose in a shoot out without knowing which pj was which and price was not a factor. People are piling on Crabb, but I bet a lot here would choose a digital if price was not a concern.
Boilermaker wrote:
To Crabb,
Bob
It won't happen, as Steve prefers the total HT experience and already hates the amount of noise of his current G70. I can't imagine him wanting to double that. I know that if he won a RS45 or could buy one for $500 then there would be a nice G70 available on Craigslist. Shocked
Posted: Sat Jan 21, 2012 5:41 pm    Post subject:
Spanky is exactly right. I love movies and home theater, not video projection. While I totally love and geek out on installs like yours Bob, or Cliffy's stack, I have exactly zero interest in a stack or blend. One CRT projector has enough visual and space impact on a room, and creates enough heat and noise... A doubling of that is a non-starter. If I had a larger, more utilitarian room... Maybe.
I'm actually very conflicted, actually. I love the look of CRT... I love the picture that looks like 35mm. But, I HATE the size, noise, and the other visual artifacts. I'm well aware that going from CRT to digital (or the reverse, really) just trades one set of artifacts (flaws) for another. But, I've seen enough setups now between CEDIA and lots of private viewings to know what I like and don't like, what I can live with and not live with. Five years ago, I had zero interest in digital... Compromises weren't worth the end product. In the last couple of years, it's a different story. For me, at least.
dturco
Posted: Sat Jan 21, 2012 6:07 pm    Post subject:
I always say to myself yeah a blend would be great...Then I say how much does it cost to do that? As far as I can tell it's north of $9000. Two P/J's, two scalers, two HDMI devices.
And then the Blending device[s].
PJ's worth having should be L/C, have good to new tubes,cost north of $1500 each. Two scalers Lumagen Mini's, 1500 each. Blend machine. What $4000? Two HDMI Moome cards or external 300 each. Plus second HDMI cabling $150. And second mounting system $200-500?
So $3000
+$3000
+$4000
+ $600
+ $150
+ $500
$11,250 Shocked Shocked Shocked Shocked
Rs55 $6000
VDC L.E.D. $14000 [without discount.]
The math is in favor of DIGITAL. Eases of use digital. Brightness, digital again. Noise, hands down digital is quieter. Picture quality... maybe CRT wins here, but by how much? I sure don't know anymore.
http://www.hulu.com/firefly
Boilermaker
Posted: Sat Jan 21, 2012 6:36 pm    Post subject:
Exactly! Each of us is looking for something different from this hobby. I don't think that there is a "one size fits all", but we all get enjoyment out of it.
Yes, while you can probably beat your estimates a little, it ain't cheap. It is all in what you want out of it. I enjoyed immensely creating a custom blend and made some good friends in the process. I am also guilty of spending considerably more time tweaking and changing things than I do watching movies. Also, when I do watch a movie, I spend too much time looking for flaws that I can "play" with. But that is what I enjoy!
My intent was an assault on the "state of the art" and yet stay within my budget (I cheated somewhat on that!).
Actually, if I won a huge lottery and had no budget, I would stay with a crt blend but do the following:
1 - Build a dedicated room such that I could use rear projection so the projectors could be as big, ugly and noisy as they are and it wouldn't matter.
2 - I would call Curt and ask him to find the two most pristine G-90's he could find and fill them with new tubes.
Bob
Posted: Sat Jan 21, 2012 6:52 pm    Post subject:
So $3000
+$3000
+$4000
+ $600
+ $150
+ $500
Rs55 $6000
Ok, here's where I must interject again.
Now I'm again not disagreeing that digital may be better for some
But your math equation is again leaving out longevity. How many digital projectors will it take to last as long as a CRT? 2....3.....4????
4 X $6000 = $24,000
And this is not calculating bulbs.......
dturco
Posted: Sat Jan 21, 2012 7:11 pm    Post subject:
4 X $6000 = $24,000
Yes it does leave lifetime TCOO out. But given the rate of digital advancements the 4k projectors, which will be coming out soon, should last longer then 5 years. Now to compete with that 4k machine, which will exist during the lifespan of the CRT, you would need two 1080p machines and a non existent set of scalers and blending devices. Meaning during the lifetime of the blend you will spend more cash to get to where the 4k machines will be in the next 5 years.
I am not against the CRT blend in theory, But starting one now seems like it would not make sense for nearly anyone. Having to wrestle up Nine Thousand, to do it and knowing the effort that will go into it... My TIME is more valuable then that NOW, let alone what my future time will be worth.
Cost isn't always dollars. Time to enjoy instead of fiddle has value too.
Posted: Sat Jan 21, 2012 7:24 pm    Post subject:
dturco wrote:
should last longer then 5 years. This is a bold and unsubstantiated statement... no offense!
Now to compete with that 4k machine, which will exist during the lifespan of the CRT, you would need two 1080p machines and a non existent set of scalers and blending devices. This also depends on whether 4k will eliminate the digital affect in their image.
Meaning during the lifetime of the blend you will spend more cash to get to where the 4k machines will be in the next 5 years. This brings about the question if 4k will outdo 1080P blend in IQ.
I am not against the CRT blend in theory, But starting one now seems like it would not make sense for nearly anyone. I would never recommend it for you , You've had enough problems.... Your a digital guy as from what I see.
Your definitely a digital guy. I was just commenting on your math...lol. Very Happy
dturco
Posted: Sat Jan 21, 2012 7:37 pm    Post subject:
Cool, what would you recommend? Wink
Boilermaker
Posted: Sat Jan 21, 2012 7:47 pm    Post subject:
That isn't quit true. First, lets look a little closer at what the new 4K machines really are. There is not now, nor will there be in my lifetime a source of 4K movies. The 4K machines scale up to 4K from 1080 programming material. The prime reason for the scaling was to be able to get closer to the screen without seeing the screen door effect. The horizontal upscaling just got a free ride because they are stuck with square pixels. There is not a real increase in resolution - It is more a marketing specsmanship IMHO.
Actually, to have the same effective resolution as the 4K machines have, there is no need for any new hardware. The actual horizontal information that we are dealing with is 800 lines. It would take me about ten minutes to change the output on both TVOne's to 1064X1600 which would have the same effective resolution but have a much more natural scaling of just doubling.
Granted, this would be pushing the resolving limit of my 8" XGLC's, so I just use 1200 which is almost as natural. If I had a pair of 9" projectors, I would be running 1600 right now, and have less artifacts than the 4K machines will have.
I haven't checked, but what is the price on those new 4K's.
Bob
Posted: Sat Jan 21, 2012 7:53 pm    Post subject:
No offense, but it's no more bold and unsubstantiated than the constant stream of bold and unsubstantiated claims you and Curt rattle off about digital projectors only lasting 2-3 years. We all know the digitals aren't built as well as the CRT's were (that original cost many, many times more to manufacture than the new digitals... But, let's see the data to back your claim of 2-3 years. Let's see MTBF ratings. Let's see percentages and probabilities... Until then, your assertions about TCO are hyperbole.
I would probably agree with the majority here with the JVC. I've actually been in contact with JVC professional as I may be looking into being a repair center, if it's viable. I'm not even sure yet if they have independent centers like their consumer line or if it's all in house.
Posted: Sat Jan 21, 2012 7:54 pm    Post subject:
Nope....and your still living in dream land......
Posted: Sat Jan 21, 2012 7:56 pm    Post subject:
That's what I thought. Ya got nothin'. Sorry, Mac! Wink
Posted: Sat Jan 21, 2012 7:58 pm    Post subject:
Yep...nothing for you...... Cool You can take a horse to water but you can't make him drink....... Laughing
Page 4 of 10
