Mux-FHD With HDMI Audio Coming soon!!!
Posted: Fri Jan 06, 2012 6:14 pm    Post subject: Mux-FHD With HDMI Audio Coming soon!!!
EDIT 11/4/2012: New MUX is now out called the Video Formatter or the VF01.
here is a link to its Data sheet
http://www.curtpalme.com/forum/download.php?id=15477
Order Page on Moome's web site.
Edit:
A few people have been asking if a new Mux will be coming out and I have some good news.
I just received an E-mail from moome with the spec sheet!!
It has some great features !!
Here is a cut and past from the spec sheet:
MUX-FHD brief
MUX-FHD is a 4 HDMI input and 2 HDMI output video switch. It has 4 HDMI1.3 input ports
with remote selectable, there is an advanced HDMI 1.3 receiver, and accept any mode of
HDMI source up to 1080P, and remote controllable output signal type ( HDMI YCbCr 444,
HDMI YCbCr 422, HDMI RGB 444, DVI-RGB) to let you connect DVI monitor or projector, that
will be cleanest digital path from video source to your display. Additional Toslink/SPDIF output
to let you connect AV receiver to get up to 7.1CH sound. The MUX-FHD is an ideal product
can let you connect up 4 HDMI video sources to your digital display
FEATURES
􏰀 HDMI input path
􏰁 4 port HDMI input
􏰁 HDMI 1.1, 1.2, 1.3a, 1.3b, 1.4, HDCP 1.1, 1.3, and DVI 1.0 compliant
􏰁 DTV mode support (480P,576P,720P,1080i,1080P) for 50 and 60Hz
􏰁 PC mode support (VGA, SVGA, XGA, SXGA, UXGA) up to 165MHz
􏰁 Support 4:4:4 RGB / YCbCr input
􏰁 Support 4:2:2 YCbCr input
􏰁 Support both 16-235 and 0-255 color range
􏰀 HDMI output port
􏰁 Two HDMI output with user selectable output mode include HDMI-RGB, HDMI-YCbCr444, HDMI-YCbCr422, DVI-RGB,
bypass mode
􏰁 Audio embedded with HDMI-RGB, HDMI-YCbCr444, HDMI-YCbCr422, bypass mode
􏰁 Two audio out Toslink port support 2CH PCM or 7.1CH compressed audio
􏰁 one audio out SPDIF port support 2CH PCM or 7.1CH compressed audio
􏰁 Drive up to 20M cable
􏰀 Board and BOX
􏰁 Metal box have cleanest electrical environment for high definition content processing
􏰁 Manual select input port
􏰁 IR control select input source
􏰁 Global power supply 100V-240V
I have no idea on Price yet. I might see if he can send me a review unit.
 Filesize:  66.26 KB
 Viewed:  27983 Time(s)
Mux FHD v101.pdf
 Filename:  Mux FHD v101.pdf
 Filesize:  736.09 KB
 Downloaded:  778 Time(s)
Matrix
Posted: Sat Jan 07, 2012 1:47 am    Post subject:
Interested in one or two. Keep us posted!
Dennis in Indy
Posted: Sat Jan 07, 2012 1:51 am    Post subject:
Nash, sound like just the ticket for your blend.
Posted: Sat Jan 07, 2012 7:45 pm    Post subject:
jeremy, this is whaT i already use for my blend but the non HDMI audio version.
here moome added HDMI audio and a neat pass through function for each Color space type as well as the
ability to convert color space from one to another( great feature for some).
I just got an e-mail from moome saying he has some of the older HDMI Mux-HD with out the HDMI audio.
he will let me know what price he plans to let these go to clear his inventory. Even if you plan to get the newest
MUX-FHD it wouldnt be a bad idea to have an older version of it. I have found my self wiching I had my oler model to trouble shoot HDCP issues in other places and having to rip out the only MUX i have is a pain. And if the price is heavily discounted why not?
He said the new ones will be 299 with a possible first run discount. But that can change as always.
Posted: Sat Jan 07, 2012 7:57 pm    Post subject:
Funny I'm going to use your old one tomorrow with a VP50 to my RPTV to see if I can crop 4:3 out of a 16:9 picture from the bluray player. I want to watch Fantasia full screen damit! Laughing
Posted: Sat Jan 07, 2012 8:17 pm    Post subject:
perfect example of why everyone who has a Home Theater needs a MUX!!!
Posted: Sat Jan 07, 2012 8:20 pm    Post subject:
The one feature I would like to see for the people that don't have gamma in their scalers is the low end gamma bump like the analog products have. That would make for a very cool MUX
Matrix
Posted: Sat Jan 07, 2012 8:45 pm    Post subject:
Moome, when you check the old stock w/o audio let me know how much for one. I am taking the HDMI audio off at the Sony IFB-FULLHD V2 anyways.
Dennis in Indy
Posted: Sat Jan 07, 2012 9:58 pm    Post subject:
I want one when available.
Posted: Tue Jan 10, 2012 3:42 am    Post subject:
The old MUX-HD are 240 and he said he has maybe 4-6 left.
the new model might be ready in Feb. if you know moome it might be longer, but it is worth the extra wait.
he likes to test and re test to make sure everything works as it should.
Athanansios
matthewrulz
Posted: Mon Mar 12, 2012 4:24 pm    Post subject:
Any updates on this?
Low Roller
Posted: Sat Nov 03, 2012 12:50 am    Post subject:
Yeah there are times the old MUX-HD would come in real handy.
I've been trying to get my hands on one with little luck. I stumbled on a solution of sorts, tho. This little inexpensive device from Monoprice is advertised to take a DVI video in and Toslink audio in, and combine them into a single HDMI out. Well, it also does a bit more than that.
Lets just say, it too is a handy device to have around while troubleshooting HDCP issues, and leave it at that. Wink
Posted: Sat Nov 03, 2012 12:54 am    Post subject:
The new MUX is out Low Roller. it now called the VF01. Video Formatter.
VF01_v01.pdf
 Filename:  VF01_v01.pdf
 Filesize:  391.58 KB
 Downloaded:  1393 Time(s)
Low Roller
Posted: Sun Nov 04, 2012 5:34 pm    Post subject:
Ahh, very cool. I'm glad a new MUX was released, looks like its received some nice enhancements. Last time I checked in here no one seemed to know if there was even going to be another MUX.
So at this point, is there any advantage at all that the old MUX-HD has over the new MUX-FHD?
Posted: Sun Nov 04, 2012 7:58 pm    Post subject:
If you need HDMI audio instead of running the Optical from the mUX then you'll want the VF01.
If you don't need HDMI audio and don't need the specific forcing of color space in or outs then the old MUX will be fine.
I'm getting the new one because I'd like to have an extra one around to hunt down HDCP issues with out taking the one I have in my system out.
DustDriver
Posted: Thu Nov 29, 2012 8:19 am    Post subject:
A question regarding the outputs:
Is it possible to use 2 different input channels, or does it only output 2 color types of 1 input?
pgs92109
Posted: Sun Dec 09, 2012 6:23 pm    Post subject:
I just received the new MUX-FHD Video Formatter VF01 from Moome yesterday. It allows HD1080i to be recorded from a DirecTivo DVR into the HDMI input of a Hauppauge Colossus at 20 mbps and on to my hard drive with excellent video quality. The audio records in excellent quality in either 2 ch PCM or Dolby 5.1 Surround (whichever output you select from the DVR). I have had no color issues or A-V sync issues with this set up.
It also is a nice way to transfer standard definition DVD content from a 480p DVD player onto my hard drive using the HDMI output on the DVD player. Very Happy Very Happy
Posted: Mon Dec 10, 2012 2:41 am    Post subject:
It will output what ever Colorspace you want for that specific input. Set it to what you want and it remembers it , but, i think the memory is volatile . So if its powered off you have to re set that color space. I always leave mine on.
Posted: Mon Dec 10, 2012 2:42 am    Post subject:
Glad to hear the new VF01 worked well for you.
ejonessss
Posted: Thu Dec 27, 2012 7:43 pm    Post subject:
i am sold where can i get one?
