| Posted: Fri Nov 30, 2012 3:40 pm Post subject: |
| ElTopo wrote: | | But with these you cannot blend !? |
Yes they will.
http://www.tvone.com/edgeblending.shtml
What you'll need with these tho is a CMS device. Cheapest is the Duo. But then you'll need two HDMI to RGBHV converters to
get to the TV-Ones. You'll need a CMS with any Edge blender anyhow. So the cost for those will be there no matter what.
So this would be my chain. Blu ray, to Moome Mux splits to two duo's or radiance's, then those to an RGBHV converter to the Barcos. Unless the Duo has RGBHV out. I wish the radiance had RGBHV outs.
Or you could eliminate the Moome Mux and get two Moome Externals HDMI to RGBHV but then you'll still need
a HDMI splitter to replace the Mux. I like the Mux because of its flexibility. there are many ways you can get to where you want to go.
zaphod
| Posted: Fri Nov 30, 2012 3:53 pm Post subject: |
but they are analog - for me that was what i wanted as my switcher is analog extron with dual RGBHS outputs.
if you want digital blending then these are not for you. if you have a pair of analog signals these should work well for you.
my chain was going to be
HDMI
HDFury
extron 304 - RTC2200 - TVone - NEC XG
RTC2200
TVone
NEC XG
and there you go.
zaphod
| Posted: Fri Nov 30, 2012 3:57 pm Post subject: |
yep, Nash that would also work - and I thought about it (even got a 2nd HDFury) but it meant losing my other analog video inputs
HDMI
splitter - HDFury - RTC2200 - TVone - NEC XG
HDFury
RTC2200
TVone
NEC XG
ElTopo
| Posted: Fri Nov 30, 2012 4:36 pm Post subject: |
Are you willing to sell the TV ONE 1250 pair?
If yes drop me a PM
thx
ElTopo
| Posted: Fri Nov 30, 2012 4:54 pm Post subject: |
I am a little confused, Nash. How many D/A and back are you doing?
zaphod
| Posted: Fri Nov 30, 2012 4:55 pm Post subject: |
you have PM
ElTopo
| Posted: Fri Nov 30, 2012 5:08 pm Post subject: |
There should be no difference in image quality between digital vs. analog.[/s]
| Posted: Fri Nov 30, 2012 6:17 pm Post subject: |
| Nashou66 wrote: | | Spanky Ham wrote: | | I am a little confused, Nash. How many D/A and back are you doing? |
Thats not for me Eric. Those 1250's are analog only so you need to do a D/A conversion to get to the TV-one 1250 and then leave it analog to the PJ .
Mine is digital all the way till it gets to the Moome card.
Athanasios |
Got it.
| ElTopo wrote: | | There should be no difference in image quality between digital vs. analog.[/s] |
| Nashou66 wrote: | | ElTopo wrote: | | There should be no difference in image quality between digital vs. analog.[/s] |
Right. I have used the analog outs from My C2-2250's and saw no difference.
Athanasios |
IIRC Craig mentioned to many D/A and A/D conversions in the signal chain can cause an issue and reduce image quality. I haven't tested it, so I defer to his experience in this area. Hopefully he can weigh in on this.
ElTopo
ElTopo
| Posted: Thu Dec 06, 2012 9:09 pm Post subject: |
Thanks will give it a try asap.
ElTopo
| Posted: Fri Dec 07, 2012 1:48 am Post subject: |
I am not sure that is right. While I am not blending but I can tell you that image quality in terms of sharpness at least is better the closer to the projector you can get a digital signal before converting to analog.
| Posted: Fri Dec 07, 2012 2:07 am Post subject: |
I have never liked that calculator. It uses Extron's formula, which takes the whole chain in account. CRT pjs are at the end of the chain.
ElTopo
| Posted: Fri Dec 07, 2012 5:14 am Post subject: |
Only my last part of my chain will be analog
ElTopo
| Posted: Wed Jan 23, 2013 3:02 pm Post subject: |
@Nashou: Did you use the EdgeBlend Software Tool inside the TV one's when you are connected with the COM port ? Or did you set everything on the units itself without connecting to the serial port ?
I do some testings now on my CRT monitors.
Your input into the TV one's is: 1920 x 1080 ? and output 1064 x 800 ?
thanks
ElTopo
ElTopo
| Posted: Wed Jan 23, 2013 3:03 pm Post subject: |
@zaphod: Thanks to you for the nice conversation and the TV one's
| Posted: Wed Jan 23, 2013 3:42 pm Post subject: |
| ElTopo wrote: | @Nashou: Did you use the EdgeBlend Software Tool inside the TV one's when you are connected with the COM port ? Or did you set everything on the units itself without connecting to the serial port ?
thanks
ElTopo |
No I did not use the edge blend software tool. When I did my blend it wasn't available yet. So i already had the blend set up
manually with no tool used.
Yes to the resolution. I used 1080p@24 into my lumagen and output the same res to my TV-Ones, then from the Tv-One I used 1056 x800. I also have 1064x800. I forgot why I did it that way, there was a reason but can not remember. I use the 1056 . The size will depend on the size of your blend Zone and Zoom amount. So I think the one with 1064 has the smaller blend zone and larger Zoom %.
ElTopo
| Posted: Fri Jan 16, 2015 11:05 am Post subject: |
My home theater build makes some progress......
I'll update as soon as my two 909's are ready for the 1st blending test.
ElTopo
