416ray4538
Joined: 14 Jul 2009 Posts: 517 Location: near Toronto Ont
| Posted: Mon Jan 02, 2012 3:11 pm Post subject: CRT replacement |
Could someone please walk me through the procedure to replace a CRT on an Ampro 4600?
_________________ When the first clock was invented, how did they know what time to set it to?
No point being pessimistic; it probably would't work anyway.
| Posted: Mon Jan 02, 2012 4:42 pm Post subject: |
THere isn't really a writeup, but it's pretty simple on an Ampro. THe tubes come out the front, mounted to the LC housing.
1) Take off the lenses, disconnect all wiring going to the tubes and pull off the CRT socket.
2) Take off the top metal plate over top of the tube LC housings.
3) Undo Allen bolt under the center of each tube that you want to take out.
The tube(s) will slide out the front of the set.
You'll need to cut the tube out from the LC housing if you have a raw bare tube to install. Use an Xacto blade to cut between the tube and the LC frame. Clean off old silicone, apply new silicone, seat new tube in silicone, let it sit for a week, no less before you move it.
416ray4538
| Posted: Mon Jan 02, 2012 7:13 pm Post subject: |
Thank you
Do you have a red tube that you could sell me?
| Posted: Mon Jan 02, 2012 7:41 pm Post subject: |
Sure, shoot me a PM or email. $100 for a good used LUG tube that's sharper than the LJEs that are in there. For an extra $50, I can mount it into a 4600 housing and put in new glycol. I'd need you to cut your tube out and send me your old housing, I don't need the tube or glycol back.
416ray4538
| Posted: Mon Jan 02, 2012 7:58 pm Post subject: |
Thank you,
Are the screws foe the flapping adjustment the same ones that hold the lenses in?
Can I assume that the rings will end up in a similar position so that a photo of the old tube will help me get them back in the right position?
I'll get it apart and send you a cheque for the $150.00 as soon as I can.
Thanks again.
416ray4538
| Posted: Mon Jan 02, 2012 8:24 pm Post subject: |
Curt,
The cheque is ready to go.
Could you send me your mailing address please.
Thanks again
| Posted: Mon Jan 02, 2012 8:37 pm Post subject: |
Thanks! Oh, but add $25, that will cover shipping. Here's the address:
Sound SOlutions
344-19567 Fraser Hwy
Surrey BC V3S9A4
Canada
Oh, and yes, take those bolts all the way out, that takes the lens and metal mounting frame right off, exposing the tube and LC hardware.
416ray4538
| Posted: Mon Jan 02, 2012 8:45 pm Post subject: |
It's in the mail.
Thanks again
| Posted: Mon Jan 02, 2012 11:51 pm Post subject: |
BTW, send me an email to curtpalme@shaw.ca with your address, I'll send it out before I get it.. actually, considering it will take a week to seal, maybe not.
416ray4538
| Posted: Tue Jan 03, 2012 8:57 pm Post subject: |
416ray4538
| Posted: Thu Jan 05, 2012 12:21 am Post subject: |
I was just looking at the rings near the rear of the red tube and trying to relate it to the Barco instructions????????
I see 5 adjustments . I thought I'd take pic as a starting point but a description would be nice as I won't get very far without.
416ray4538
| Posted: Thu Jan 05, 2012 10:00 pm Post subject: |
Is there another bolt hiding under the plastic cover that doen't open?
Pics still not workin
416ray4538
| Posted: Fri Jan 06, 2012 12:30 am Post subject: |
| 416ray4538 wrote: | Is there another bolt hiding under the plastic cover that doen't open?
Pics still not workin |
Found it.
416ray4538
| Posted: Thu Jan 26, 2012 10:44 pm Post subject: |
The new tube has 4 copper "springs" attached to the frame at the top. There are similar "springs" on the aluminum shield. Can I assume these are just a different vintage and I can lose the ones from the frame?
416ray4538
| Posted: Fri Jan 27, 2012 10:31 pm Post subject: |
There's a black wire about 2.5 feet long 2 conductor plug that cones from the horizontal drive board to ???????
I don't see it in the layout pic but it's probably there. Anyone know where it goes ?
416ray4538
| Posted: Sat Jan 28, 2012 2:37 am Post subject: |
Anyone got a suggestion where the other end of this wire goes?
416ray4538
| Posted: Sat Jan 28, 2012 3:09 pm Post subject: |
I think the other end goes here on theRGB board. Feel free to slap me around for not taking the picture when I was removing it ; at the time it seemed obvious, now not so much. Does this look right for a wire about 2.5 feet long that goes to the horizontal drive board
? [/img]
| Posted: Sat Jan 28, 2012 3:38 pm Post subject: |
That looks like 1 of the 3 black wires that go from the RGB board to the neck boards.
Post a bigger picture of the projector. I see you got the pic thing working.
416ray4538
| Posted: Sat Jan 28, 2012 5:11 pm Post subject: |
Just waiting for the picture to come from my phone.
The three that go to the neck boards are under my thumb in this shot and connect to the edge of the board in a nice neat little row. There is another connector at the tip of my index finger and that's the one I'm suspecting.
416ray4538
| Posted: Sat Jan 28, 2012 6:21 pm Post subject: |
Here's a pic of the horizontal board with the wire attached[img] [/img]
