Reballing SMT devices
Bodi79
Posted: Mon Jan 02, 2012 8:49 pm    Post subject:
@Curt
I am actually working since 2009 in the Reballing Business.
Really would suggest you go IR.
The INT 732 is a very unstable beast, had it for a few months and only problems getting constant results.
I settled for an Achi IR PRO SC which i modded somewhat with the German Elstein Heaters.
Mainly i repair Notebooks and Game Consoles (done over a 1000 and counting)
There is a shop in the US which has the modded Version of the ACHI IR PRO SC which has all the ugprades built in.
This one ships worldwide: http://thebgastore.com/LYIRPROSCV2040theBGAstore.aspx
Just shout if you need more infos.
Cheers
Ronald
Posted: Mon Jan 02, 2012 9:52 pm    Post subject:
THanks for that, it's always good to talk to someone that has used these before, I appreciate that!
Posted: Mon Jan 02, 2012 10:59 pm    Post subject:
Wow thats a good price too!!!
Posted: Tue Jan 03, 2012 10:54 pm    Post subject:
Did you check out some of the training video's???
Re-balling by hand.......Now that's right up Curt's alley Laughing
Posted: Mon Jan 16, 2012 5:06 pm    Post subject:
OK, if I'm lucky, I might just be able to order this in the next week or so. I'm going with Bodi's suggestion above:
A couple more questions, just because I'm new to this:
1) Check out the second video at the bottom of the above link. It shows that once the chip is removed and the solder pads are cleaned, they paint on flux and reheat the chip. They do not show any new solder being applied. Is that correct, or would I need to add a preformed bunch of solder balls prior to placing the chip back on the cleaned board?
2) They show no pressure being applied to the chip as it's being reheated. That's normal? No slight pressure needed to make sure all 80 or 120 pads get good contact with the board?
Bodi79
Posted: Mon Jan 16, 2012 7:01 pm    Post subject:
@Curt
1. Yes if you remove the chip you need to clean it with an desolder wick.
After that you use new Solder Balls (really cheap via Bga Store or ebay) and apply the new solder balls.
That is the term "reballing"
As another less time consuming option is to buy the chips preballed from china.
I can send you links ( I know the ones which have better quality)
Two Options:
A. http://thebgastore.com/DirectHeatReballStationavailible40theBGAstore.aspx
plus http://thebgastore.com/ConsoleBGAstencilsDirectheattype40theBGAstore.aspx
This is what i use to reball the chips
or
B. http://thebgastore.com/New2011SilverReballStation9090mm40theBGAstore.aspx
http://thebgastore.com/210PcsNonDirectHeatStencils40theBGAstore.aspx
2.
No you donīt need to apply any pressure.
The applied flux seats the Chip steady and from 180-225 Degrees Celsius it gets to liquid state
and centers by itself (cause the solder pads on the board are actually not even and lock in).
As soon as it cools down again itīs tight as a rock Wink
Any Questions... just shout.
Cheers
Ronald
Posted: Mon Jan 16, 2012 7:11 pm    Post subject:
Awesome, thanks! I figured the video was missing the step of putting on the new solder balls. Time to stock up on XBox 360s to practice on! I've got 5 here right now...
Posted: Mon Jan 16, 2012 7:42 pm    Post subject:
Make sure you don't drink any coffee before doing it!! You need a steady hand placing the solder balls, even with the template. After do a close inspection to make sure each pad has a ball. Then heat with IR gun.
Bodi79
Posted: Mon Jan 16, 2012 7:54 pm    Post subject:
@Athanasios
I donīt use coffee to get a steady hand for reballing.. i use my own raspberrie schnaps Wink
Cheers
Ronald
Posted: Mon Jan 16, 2012 8:24 pm    Post subject:
LOL !!!!
If I;m ever in Austria i'd love to try a little....or a lot!!!
Tinman
Posted: Thu Jan 19, 2012 6:32 pm    Post subject:
Hey Curt,
Did you ever get that station? I'm planning on the same this year. It's all just part of doing business.
Marc
This space for rent.
Posted: Thu Jan 19, 2012 6:54 pm    Post subject:
Not yet. The bastard on eBay flaked on buying the 909, so I've got to put getting it and the MetCal on hold. Once I sell that remaining 909, I'll order it.
