dturco
| Posted: Fri Dec 30, 2011 10:12 pm Post subject: Tape for aquadags? |
OK, I am hearing some static discharge while the P/J is on. The noise is coming from the blue tube, it is not the H/V, at least I do not think it is I sat and watched the tubes in the dark and never see any arcs of any kind but I do hear every 3-4 minutes a snap. Not very loud just consistent. It was not there before.
Now when I put the tubes in I put the aquadags on each tube, form fitted them around the tube, but the tape's hold was less then stellar, so I put packing tape over the copper foil tape to hold them in place. I don't think this is working out too well.
I just went out and bought some high voltage putty that I want to use as an adhesive and filler but I still want some extra insurance of tape.
So what to use?
http://www.hulu.com/firefly
jbmeyer13
| Posted: Fri Dec 30, 2011 10:23 pm Post subject: |
It's funny because I hear a snap every so often and have never noticed any sparks. It sounds more like it's coming through my right front speaker as opposed to the PJ.
Why are you taping the tubes; i.e. is this something you are experimenting with or have been advised to do?
My PJ sits on top of a carpeted riser platform and I wonder if static electricity is coming up through the carpet...
dturco
| Posted: Fri Dec 30, 2011 10:33 pm Post subject: |
Nope not an experiment. I just put in new tubes,and transferred over the original aquadags which were held on by tape. That old tape is no longer sticky.
Maybe I should have used the PT-22 thread but I thought it should have its own thread as a specific arcing issue.
| Posted: Fri Dec 30, 2011 11:35 pm Post subject: |
I use plain old duct tape. Cut it in 1/2 lengthwise. Sticks really well.
dturco
| Posted: Fri Dec 30, 2011 11:44 pm Post subject: |
Alrighty then. I bought some of that too, I just didn't want to admit it.
Duck tape to the rescue ....again
tse
| Posted: Sat Dec 31, 2011 12:05 am Post subject: |
Do a search for "copper tape" on ebay and you will have plenty of choices. Evidently the EMI shielding copper tape with conductive adhesive that is used for grounding the dag is also used for shielding guitar pick-ups. The edge of the tape is like a knife, it'll cut you if you are not careful.
Scott
Thomas Jefferson
dturco
| Posted: Sat Dec 31, 2011 12:15 am Post subject: |
Thanks Scott. I did that, then I went to an electronics store and asked for copper grounding tape and got the blank stare back. I explained what it was for still, the blank stare. We have this glue here, or this putty. The putty looked more correct to me.
This was not a radio shack place either they had Nichicon caps on the wall and all of the little resistors too. I had been there before but never really knew what all those little dohickies were. Anyway no copper tape there.
Lazy and did not want to wait to online order, but I guess better safe than sorry, and having to do it a third time.
Decibel
Joined: 31 May 2007 Posts: 904 Location: Roma - Italia
| Posted: Sat Dec 31, 2011 9:10 am Post subject: |
What's "aquadags"?
_________________ Domenico (Barco fan!)
dturco
Decibel
| Posted: Sat Dec 31, 2011 10:29 am Post subject: |
Thank you!
So aquadags there are in Marquee tubes only?
dturco
| Posted: Sat Dec 31, 2011 10:39 am Post subject: |
| Decibel wrote: | Thank you!
So aquadags there are in Marquee tubes only? |
I don't know. I have only worked on my Marquee. However, the Ampro that I bought the tubes out of did not use Aquadags. It had a copper fork that screwed to the L/C chamber and then use a series of ground wires from the forks and L/C chambers to ground the static electricity caused by normal operation.
I believe this is called "shunt to ground". There are also arc suppressors on Marquee neck boards too. Past this brief description I have no more information.
Same principal, different methods of application.
Decibel
| Posted: Sat Dec 31, 2011 3:36 pm Post subject: |
Thank you
tse
| Posted: Sat Dec 31, 2011 5:27 pm Post subject: |
http://en.wikipedia.org/wiki/Aquadag
good description of aquadag.
Scott
Thomas Jefferson
dturco
| Posted: Sat Dec 31, 2011 6:15 pm Post subject: |
| tse wrote: | http://en.wikipedia.org/wiki/Aquadag
Scott |
Well then it's the tube coating. Now I think I've got a problem. The PT-22s had the shock warning label on the area the ground tape had to go. I scraped the stickers off with a razor scraper. Which of course removed some of that black coating...the auqadag.
What do I replace it with?
I was wondering about that coating, what it's purpose was, and if I should have cleaned the tube in some special way. I just washed it with isopropyl alcohol.
What Now?
tse
| Posted: Sat Dec 31, 2011 6:21 pm Post subject: |
It is just an electrically conductive coating. The copper tape can replace it.
Scott
Thomas Jefferson
dturco
dturco
| Posted: Sun May 13, 2012 5:54 pm Post subject: |
Reviving this older thread. I have had issue with H/V since putting in the PT-22 tubes. I have replaced the splitter, and all three H/V cables. I am still having issues with the H/V every now and then; a little pop, not a big deal just a tiny static pop every once in a while. But when I shut down in the dark, I can see the H/V surround the H/V cable boot like a circular fire, then a big crackle, then shutdown. I used Dow silicone and cleaned everything with alcohol before assembly.
Now here is what I think is going on. The PT-22's came out of an Ampro, which used a grounding bar, not the tape that the Marquee uses. I think that the lack of Aquadag is my issue. The old tubes had it under the boot area and all over the tubes. The PT-22's only had it where the grounding forks were.
Picture 1&2 clearly show no Aquadag on the tubes near the H/V cable. Pictures 3,4,&5 show the older tubes Aqudag layout.
Any Hypotheses?
http://photobucket.com/Aquadags
tse
| Posted: Sun May 13, 2012 7:49 pm Post subject: |
You don't want anything conductive around the anode cups. I think the 'dag that you see around the anode on the old tubes is on the inside. It connects to the anode. The 'dag on the outside of the tube needs to be connected to ground. Through copper fingers or through copper tape with conductive adhesive. Keep grounded stuff away from the anode connection.
Scott
Thomas Jefferson
