dturco
dvh99
| Posted: Tue Dec 13, 2011 11:34 pm Post subject: |
are you sure it`s a pt22???
i have a pt22 and it is exactly the same size as a p19lcp09
dturco
| Posted: Tue Dec 13, 2011 11:38 pm Post subject: |
| dvh99 wrote: | are you sure it`s a pt22???
i have a pt22 and it is exactly the same size as a p19lcp09 |
Did you check my link? The stickers on the tubes say PT-22-08
http://www.hulu.com/firefly
dvh99
| Posted: Tue Dec 13, 2011 11:40 pm Post subject: |
yes sorry,i was to quick with my reply.
my pt22 tube is a pt22-19 iirc instead of a pt22-08.
maybe that`s the reason he sold them this cheap.
this really sucks dave, you could shorten the housing of the marquee and try it.
check if the pinout is the same as a regular pt22 to be sure.
dturco
dturco
| Posted: Wed Dec 14, 2011 12:38 am Post subject: |
I removed the neckboard cage put the neckboard on, no picture. But the tube does glow at the end. I swapped the green video rca over still no picture or anything. I then put the red video rca on the green and the green light up.
Did my neckboard go bad? or something else?
What do I check and how?
| Posted: Wed Dec 14, 2011 12:56 am Post subject: |
Swap the neck boards, but I think you need to take off the pin 6 pin, enlarge the hole, and put the G2 wire on pin 6. I think the G2 pins are different.
dvh99
| Posted: Wed Dec 14, 2011 1:12 am Post subject: |
darn, i warned him to make sure if the pinout was the same.
tse
| Posted: Wed Dec 14, 2011 1:23 am Post subject: |
Curt is probably right. Look at the gun and see which pin the G-2 element is connected to. You might need to mod your cards.
WARNING! WARNING! WARNING!
If the projector is started with the G-2 element not connected to anything the CRT usually turns full on. DO NOT FREAK OUT AND YANK THE POWER CORD!!!!!!
The projector will turn off the HV after a couple of seconds. Turn off with the remote control.
If you are careful, messing with G-2 is not a problem.
Scott
Edit. Point to correct G-2 element in this pic.
| Description: |
| Filesize: |
4.81 KB |
| Viewed: |
8607 Time(s) |
Thomas Jefferson
dturco
| Posted: Wed Dec 14, 2011 1:34 am Post subject: |
Ok Guys thank you. I'm went to get something to eat, I just now checking back in. I did turn on the PJ and the contrast was at 75 or so even though I had turned it down to 20 when I took the tubes out. I just turned the power off with the remote.
The red tube never lit up, but the green and blue tubes did. If anything happened to them I doesn't matter they were still the old tubes.
So to mod the board all I need to do is drill the pin 6 on the neckboard out correct? Then I place the G-2 wire on tube pin directly?
Everything's coool
I added 3 new close-up pics here
http://s955.photobucket.com/albums/ae34/dturco/PT-22%20tubes/
I also noticed there aren't any wires hooked to the 2 pins in the "Keystone area".
Is this what I need to do?
http://www.curtpalme.com/forum/viewtopic.php?p=30273#30273
dvh99
| Posted: Wed Dec 14, 2011 3:06 am Post subject: |
removal of the r38 and replacement with a 1megohm 1/2watt is only necessary if you have a kh grid like in the lug so make sure it`s there.
r37 (330k) going to pin 6 should be removed.
this same config as on pin6 should now be applied on pin 2 i suppose, so from pin 2 a 330k (1/4w minimum) to ground.
dturco
| Posted: Wed Dec 14, 2011 3:14 am Post subject: |
| dvh99 wrote: | removal of the r38 and replacement with a 1megohm 1/2watt is only necessary if you have a kh grid like in the lug so make sure it`s there.
this same config as on pin6 should now be applied on pin 2 i suppose, so from pin 2 a 330k (1/4w minimum) to ground. |
Pin 2 is in the Keystone correct? There are no wires going to anything inside the tube in the keystone area.
I have successfully drilled pin 6 and moved the G-2 wire onto pin 6 What happens if r37 is not removed? The link says for added insurance remove r37.
dvh99
| Posted: Wed Dec 14, 2011 3:29 am Post subject: |
you MUST remove pin r37 otherwise you risk tieing G2 through the 330k to ground when swinging the tube and thus wiggle the g2 wire.
2 and 6 are reversed so now you can solder a resistor 330k from pin 2 to ground.
dturco
| Posted: Fri Dec 16, 2011 12:58 am Post subject: |
| dvh99 wrote: | you MUST remove pin r37 otherwise you risk tieing G2 through the 330k to ground when swinging the tube and thus wiggle the g2 wire.
2 and 6 are reversed so now you can solder a resistor 330k from pin 2 to ground. |
Ok I did enlarge the hole But I can't solder,period. Is there a crimping method for ground,and is removing r37absolutely necessary as the G-2 wire has plastic shielding on it?
dvh99
| Posted: Fri Dec 16, 2011 2:42 am Post subject: |
i wouldn`t risk that.
if you cannot solder ask someone to do it for you to get a secure connection.
i wouldn`t feel comfortable knowing the connections made are crappy.
flux makes soldering much easier, you will need it to connect the resistor to the big ground surface as it requires a lot of heat and without flux the solder won`t flow nicely.
you could use the 330k from r37 to tie pin 2 to ground.
dturco
| Posted: Sun Dec 18, 2011 8:06 pm Post subject: |
OK I have everything up and running. I have 1 PT-22 Red tube in and the P-19LCP G&B. The focus on the G&B is much better than the PT-22 and the image is sharper on them too. This has always been the case though, the red was always less sharp the the G&B.
Are the focus coils weak maybe? Also I tried to us the 4 pole magnetics from the Ampro but the focus was worse with them, than the original 2 poll from my Marquee. The red dots and grid lines also stay "Fat" always has and the lines bloom also,they look kinda fuzzy always have.
Any Ideas?
| Posted: Mon Dec 19, 2011 1:26 am Post subject: |
Hello
Have you tried stig and flare alignments? Elongated dots in stig gives fat test pattern lines or worse.
dturco
| Posted: Mon Dec 19, 2011 1:36 am Post subject: |
| Tim in Phoenix wrote: | Hello
Ok first what is worse?
2nd Yes I have re-set them to 50 and 50 across the board. I also have adjusted them in the service menu a couple of times. Red always has fatter lines then the Blue and Green.
I have put in the Green tube and the lines are just like before thin...but I have not done the full magnetics on the green yet.
