No Vsync
jbmeyer13
Posted: Tue Dec 13, 2011 3:57 am    Post subject:
I'll pick up a meter, probably good to have. If there is not continuity is that likely due to the resistor failing and needing to be replaced or simply a matter of re-soldering the connections? I'm assuming you have had this problem with a Moome card before. I don't want to do anything to void the waranty but Moome seems to be slow to respond and I need big black up and running by Christmas.
Posted: Tue Dec 13, 2011 4:20 am    Post subject:
oops, sorry I missed this thread. Sounds like the card if the RGBHV port is working normally. Incidentally had a customer in FL with the similar issue, video problem but internal parts are fine. He jumped on the Moome card to soon and sent it back but it wasn't the problem. All indications at this point is a faulty Lumagen scaler that went bad.
In most cases it's turning out to not be the projector, so that's at least good news.
jbmeyer13
Posted: Tue Dec 13, 2011 4:49 am    Post subject:
Believe me it was a big sigh of relief when the RGBHV port worked:-)
Posted: Tue Dec 13, 2011 4:55 am    Post subject:
I have owned tons of lumagen gear and follow the forums there and have never seen a bad one. Also I dont think he has one in his set up, does he?
Try a standard def dvd player with hdmi out. if that doesn't work then it could be the moome or the switching between input 1 and input 2
in the PJ.
You could send the moome card to someone close by to test and then you'll know what to do in the meantime. If you had to send it to moome it wont get back by Christmas.
jbmeyer13
Posted: Tue Dec 13, 2011 2:45 pm    Post subject:
No Lumagen, just BD player straight into Moome. When I first installed the Moome back in July I tried Input 1 and it didn't work therefore I swiched to input 2 and have used that ever since. When I added the HD cable box 2 weeks ago I simply disconnected the HDMI connector from the BD player's output and connected to the Cable Box's output. The BD player outputs 1080p and the HD cable box 1080i.
What good would a standard def DVD player be; are you thinking that the Moome input will work with SD but not HD? That would be strange..
Posted: Tue Dec 13, 2011 3:33 pm    Post subject:
Replied to your PM
Posted: Sun Dec 18, 2011 3:50 am    Post subject:
Justin, I Just test your Moome Card in one of my Marquee's and it works fine. Both inputs, gamma and color space selections.
It has to be your Vim.
But lets see how the old Moome card works when you get it. I only tested this for about 10 minutes, i'll run it longer either tonight or tomorrow.
jbmeyer13
Posted: Wed Dec 21, 2011 12:23 am    Post subject:
Nash-
Your Moome card works fine in my machine, both HDMI and Component Video Inputs. I tested both HD cable box and BD player in HDMI input and a DVD player with the Component Input.
I'll have to run the audio out of the cable box to my pre-amp since their is no optical output on the first generation Moome.
WTF? How has further testing worked with my Moome card in your machine?
This $#!@ doesn't make any sense....
Posted: Wed Dec 21, 2011 12:48 am    Post subject:
I have not had time to be in the theater. I'll try to fire it up tonight and run yours for couple hours before I go to bed. At the restaurant till close tonight.
Posted: Wed Dec 21, 2011 1:27 am    Post subject:
could be your old moome card is buggy only after longer test periods. Or, I had a VIM here once that would synch up fine at lower resolutions then show "No Synch" at higher rez. In that case replacing the primary 5 and 15 volt DC rail by-pass caps fixed the card. I've seen the exact same problem and resolution on a few CLM's too so I think those old Yellow tant's in some high-hour machines are beyond their expiration date.
Posted: Wed Dec 21, 2011 6:06 am    Post subject:
Ok Just watched the entire Atlas Shrugged movie and no issues at all.
Dont know what to tell ya...
jbmeyer13
Posted: Wed Dec 21, 2011 1:57 pm    Post subject:
Dragan is sending me a VIM to test. I guess you might as well send back my Moome to me and I'll test both with the new VIM and my current VIM to see if anything else peculiar happens. Bizarre to say the least...
Posted: Wed Dec 21, 2011 1:59 pm    Post subject:
Ok Will do! At least you don't have to send the card all the way back to moome.
Posted: Fri Dec 30, 2011 5:49 pm    Post subject:
just heard back from Tony, it was his Lumagen Razz
Yep, the Lumagen HDCP board is messed up. Lumagen is going to replace it with a "B stock" board
and download all the old settings onto the new one for me.
Looks like Justin's problem remains a mystery at this time
