No Vsync
jbmeyer13
Posted: Sat Dec 10, 2011 4:33 am    Post subject: No Vsync
I'm in the middle of watching a blu ray on my 9500LC and all of the sudden the picture turns very dim. A few minutes later it returns to normal and then intermittently fluctuates before the screen goes completely black. First I get "No Sync" and then "No VSync". I switch to HD cable and same error. What is the likely culprit here?
Posted: Sat Dec 10, 2011 5:12 am    Post subject:
Are the connections all in good order?? What cable goes to the projector?? Are all the connections all the way along the run nice and tight??
Give the cables all a wriggle near the joins and see what you see.
How are you feeding the signal? Moome card or RGBHV?
jbmeyer13
Posted: Sat Dec 10, 2011 5:20 am    Post subject:
15 ft HDMI into latest Moome that I swap between BD player and HD cable box, checked cable connections on both ends and makes no difference. PJ has been set up since June and prior to that had Dragan's HD Mods, Tim's Power supply mod, re-bellow, and motherboard replaced (all done prior to set up).
jbmeyer13
Posted: Sat Dec 10, 2011 5:21 am    Post subject:
jbmeyer13
Posted: Sat Dec 10, 2011 5:25 am    Post subject:
I cant see this being oxidation since a tear down was done 6 months ago. I did recently hear snapping through my front speakers (I'm assuming HV arcing). HDM?
diezzler
Posted: Sat Dec 10, 2011 6:58 am    Post subject:
Maybe try the a different input on the projector to rule out that the mooned card didn't die.
Posted: Sat Dec 10, 2011 12:52 pm    Post subject:
Did the picture go out of focus and then back or did it just go black instantly?
jbmeyer13
Posted: Sat Dec 10, 2011 3:44 pm    Post subject:
All of the sudden the image looked like the brightness had been turned way down. It stayed this way for about 5 mintues and then it returned to normal for about a minute. Then it began fluctuating between normal and dim with the image remaining in focus, finally going black. I tried the internal test patterns and they work fine. The PJ is floor mounted, seems doubtful something would become unseated because the failure was a progression over 5-10 minutes.
Posted: Sat Dec 10, 2011 4:14 pm    Post subject:
Sounds like a VIM issue since the internal patterns are working.
do you have any whay to test the Vim with an RGBHV signal?
jbmeyer13
Posted: Sat Dec 10, 2011 4:43 pm    Post subject:
I can hook up my Faroudja NRS and see what happens. I'll report back in a bit.
jbmeyer13
Posted: Sat Dec 10, 2011 5:37 pm    Post subject:
Hooked up my Panny RP-91 to NRS into RGBHV slot and it works fine. Is it fair to assume that problem is with Moome?
Posted: Sun Dec 11, 2011 5:15 am    Post subject:
Or the cable yeah.
Posted: Sun Dec 11, 2011 5:51 am    Post subject:
It might be the moome or as case say's the cable. if you can bring the BD player close to the PJ and use a short to see if it works.
Athan
jbmeyer13
Posted: Sun Dec 11, 2011 2:24 pm    Post subject:
I tried a shorter cable (10 ft. as opposed to 15 ft.) and it made no difference. I'm contacting Moome to return the VIM.
dvh99
Posted: Sun Dec 11, 2011 4:00 pm    Post subject:
look for cracked solder joints at the back of the moome.
jbmeyer13
Posted: Mon Dec 12, 2011 11:45 pm    Post subject:
I don't see any cracked solder joints. Does anyone see anything out of the ordinary? I emailed Moome 2 days ago but have not heard back as of yet.
Posted: Tue Dec 13, 2011 12:06 am    Post subject:
Check the fusible resistors F2 and F3 to make sure they are not open.
jbmeyer13
Posted: Tue Dec 13, 2011 12:53 am    Post subject:
Nash-
Pretend i don't know anything because well I don't..LOL Which are the the F2/3 fusible resistors and how can I tell if they are open?
Justin
Posted: Tue Dec 13, 2011 2:44 am    Post subject:
jbmeyer13 wrote:
Nash-
Justin
LOL, the two grey resistors near the connector to the Back plane. On the Circuit board you can see in the pics F2 and F3.
If you have an multimeter you can set it to continuity and see if there is continuity on through the resistor from one side to the other. the meter should have an audible beep. If you dont have one Radio shack has a cheap pocket one that i use all the time.
