Ooops!
Posted: Sun Nov 13, 2011 12:59 am    Post subject: Ooops!
From a customer:
I’m reading 7.9 volts on the p14 in standby mode, 13.2 volts when it’s powered up. Am I screwed?
Does anyone know if that trimpot opens on a LVPS, how high the voltage can go? 13.2 is way way more than I ever measured...
Posted: Sun Nov 13, 2011 1:08 am    Post subject:
Are you sure he has his multimeter set correctly?
Posted: Sun Nov 13, 2011 1:30 am    Post subject:
I believe +13.5 would be the maximum capability of that circuit.
Posted: Sun Nov 13, 2011 2:22 am    Post subject:
I've linked him to this thread, and have indeed told him to try another meter.
It's actually an 8000, so the only way it can have a bad LVPS is if the original went bad and a later series got swapped in.
Posted: Sun Nov 13, 2011 2:40 am    Post subject:
I have seen eleven volts on an 8500; that was the Brightest 8500 you ever saw! (for a few hours anyway)
Posted: Sun Nov 13, 2011 5:22 pm    Post subject:
yes it can go up over 12 volts from what I recall. That's why the original circuit was such a design screw-up. Your trying to dial in exactly 6.35 with a 20 turn pot on a 12+ volt circuit. So you get .6 volts per turn which is too coarse to start with
Posted: Sun Nov 13, 2011 5:35 pm    Post subject:
I believe one of the designs called for a regulator in that pot location. Surely would of been more stable.
Posted: Sun Nov 13, 2011 11:06 pm    Post subject:
the later "Ultra" power supply's did have what I believe is a small regulator circuit of some sort? IT's a little daughter board and it's still not perfect although the voltage is consistent and safe at 6.23VDC on every one I checked.
The best solution IMO that an EE at work came up for me is resistor which drops overall circuit down to 8VDC and then a new 20 turn pot which allows an exact and very stable 6.35.
Funny thing is the video-philes here are a lot more anal about that spec. than electrohome or VDC ever was. Surprised
Posted: Sun Nov 13, 2011 11:15 pm    Post subject:
This was not a daughter board. The regulator went right where the pot is. This was suppose to be on 01/02 power supplies. Of course I dont know if any went into production that way or if it was changed to the pot design before production. but it was in the original design for that production year or later.
Any pot design can drift but a regulator design can also fail. Funny how Marquees only have this filament issue though.
Posted: Sun Nov 13, 2011 11:58 pm    Post subject:
I've never even looked at what controls or regulates that on a AmPro. I just never felt it might be a issue. Not sure about Sony's but I don't think it ever was a issue with NEC.
Barco's can burn up for all I care Wink Where's Pete when I feel like bustin balls. Laughing
Posted: Mon Nov 14, 2011 12:14 am    Post subject:
THe Ampros do have a filament control on one of th ePC boards. You could access it via the rear vent slots on the old 2000, so I boosted the filament on the one I had back in 1999 to 7 volts as the tubes got a bit old.
Posted: Mon Nov 14, 2011 12:22 am    Post subject:
Fil comes from the horz supply (HOT) board in newer Ampro's. All electronic, non adjustable.
tse
Posted: Mon Nov 14, 2011 12:35 am    Post subject:
You guys are way off on this one. The Ampro projectors always had a regulator in the LVPS where the output voltage was set with two fixed resistors. The CRT manufacturers spec for fil voltage was wide enough that there was no need for a pot. How such a simple thing got so screwed up in the Marquee is a mystery to me.
Scott
Thomas Jefferson
Posted: Mon Nov 14, 2011 12:40 am    Post subject:
Scott
I found my info in the 3600/4600 schematics. It shows filament in print. I'm going to look at the LVPS prints now.
Posted: Mon Nov 14, 2011 12:46 am    Post subject:
Yes, I see the fil supply in the LVPS. Whats with the fil circuit in the horz supply?
Posted: Mon Nov 14, 2011 12:48 am    Post subject:
Don't tell me they used fil supply for horz centering...... Confused
tse
Posted: Mon Nov 14, 2011 4:03 pm    Post subject:
Well, yeah. There is a reason that that is bad. Do you know why?
It looks like the later Maquee LVPS didn't use a pot to set the filament voltage. The regulator has about 13.5V applied so worst case regulator short could put that much on the CRT heater. That couldn't be good.
Scott
 Filesize:  18.75 KB
 Viewed:  6586 Time(s)
Thomas Jefferson
Posted: Mon Nov 14, 2011 4:19 pm    Post subject:
Scott
I could think of a couple reasons why its bad and I may have had one some years back. But I want to check my notes to see if my issue was from this circuit. I'll be back there in a week. I know the problem part was on a horz board but was not a horz issue.
That Marquee image is the one I was referring to in my earlier post.
So give me your reason. Very Happy
tse
Posted: Mon Nov 14, 2011 5:37 pm    Post subject:
The filament rail is floating coming out of the LVPS. It then connects to the horizontal winding of the deflection yokes. The DC voltage applied to the h winding goes from about 20V to over 200V over the sweep range 15-105kHz. That means the filaments in the CRTs can be referenced 20 to 200V above ground. The CRT spec allows the cathode to be something like 300V more positive than the filaments but 0V negative relative to the filaments. That can be violated at the highest sweep rates. One (of many) good reasons not to run an Ampro above 80 or 90kHz.
Scott
Thomas Jefferson
Posted: Mon Nov 14, 2011 7:09 pm    Post subject:
Scott
Wow, didn't see that until looking at the horz out diagram. Also, a short failure of CR1 on the horz power board and the horz winding is tied directly to the filament supply......and heater.... Shocked
