Need help to ID Ampro 4600 boards
incova
Posted: Wed Sep 28, 2011 7:32 pm    Post subject: Need help to ID Ampro 4600 boards
Hey guys I got these a while ago but just wanted some help to Identify what they are and what they do:
4600 cpu board
65334 rev b
 Filename:  PICT0923.JPG
 Filesize:  428.75 KB
 Downloaded:  231 Time(s)
Input Card 3 svhs Video input card?
65440 rev a
 Filename:  PICT0921.JPG
 Filesize:  163.74 KB
 Downloaded:  221 Time(s)
65440 rev a
65439 rev a on top
 Filename:  PICT0920.JPG
 Filesize:  421.13 KB
 Downloaded:  222 Time(s)
Input card 2 Secondary RGB board? 65424 rev a
back
 Filename:  PICT0918.JPG
 Filesize:  292.81 KB
 Downloaded:  209 Time(s)
 Filename:  PICT0917.JPG
 Filesize:  156.99 KB
 Downloaded:  193 Time(s)
Intensity Modulation Board piggybacking
65425 rev x
 Filename:  PICT0916.JPG
 Filesize:  374.41 KB
 Downloaded:  212 Time(s)
Input card 1 input view 65369 rev x
 Filename:  PICT0915.JPG
 Filesize:  155.92 KB
 Downloaded:  210 Time(s)
Input card 1 65369 rev x
 Filename:  PICT0914.JPG
 Filesize:  205.75 KB
 Downloaded:  208 Time(s)
The more I learn
the less I know.
incova
Posted: Wed Sep 28, 2011 8:50 pm    Post subject: PICT0923.JPG
4600 cpu board
65334 rev b
is this a 4600 cpu board?
The more I learn
the less I know.
Posted: Wed Sep 28, 2011 9:04 pm    Post subject:
Post a pix of it. Smile
Posted: Wed Sep 28, 2011 9:43 pm    Post subject:
That CPU is for a 4600i.
Posted: Wed Sep 28, 2011 9:49 pm    Post subject:
That RGB 1 is for a second input. You would still need a primary RGB card for it to work.
Posted: Wed Sep 28, 2011 9:52 pm    Post subject:
As for those other input boards, look for a sticker number, something like 81388, 31388 or similar. Or maybe the firmware chip number.
Posted: Wed Sep 28, 2011 10:15 pm    Post subject:
Type Oriface.
RGB1 is the primary input card. RGB2 does not work alone. It is switched to and passes through RGB1
At least that's what the guy driving the ice cream truck told me.
incova
Posted: Wed Sep 28, 2011 10:16 pm    Post subject: Hi Curt
the picture of the 4600 cpu board is PICT0923.JPG in the subject headline, just trying to figure out whats working in the pj and whats not then I got to get some parts from you Curt!
The more I learn
the less I know.
Posted: Wed Sep 28, 2011 10:23 pm    Post subject:
The first board is non functional.
The mail man pointed that out to me.
incova
Posted: Wed Sep 28, 2011 10:31 pm    Post subject: from the site
from the site it says
from the siteOptional RGB/quad decoder boards:
All Ampros come with the option to add a secondary RGB input board and/
or a quad decoder (video/Svideo) board.
Some sets didn’t come with the female connectors installed on the motherboard, most have one spare connector installed on the chassis. The secondary RGB input boards have a lot less components installed than the main RGB board, and are hard to find.
The video/s-video boards are readily available.
that just leaves the Secondary RGB board? Intensity Modulation Board, I assume this board controls brightness/contrast for all three tubes so you can have equal brightness in all areas of the screen?
The more I learn
the less I know.
Posted: Wed Sep 28, 2011 10:39 pm    Post subject:
stefuel wrote:
Type Oriface.
I was referring to his picture identification "RGB1", not projector RGB1. He named them input 1, input 2, input 3. No reference to the projector. Very Happy
Posted: Wed Sep 28, 2011 10:40 pm    Post subject:
Where did those pix come from? Smile
I'm in hte middle of my yearly cold, and feel like crap. Sorry. Smile
incova
Posted: Wed Sep 28, 2011 10:43 pm    Post subject: hi
Which board is none funtional Chip? could you tell me by jpeg number? Thanks.
The more I learn
the less I know.
incova
Posted: Wed Sep 28, 2011 10:46 pm    Post subject: Hi Curt
No problem Curt, I took the pictures tonight, I thought it might be nice to have some pics of the actual boards that are reffered to on the site as optional ampro extras, more for everyones info than anything else. I had the change of season cold as well................. annoying.
The more I learn
the less I know.
tse
Posted: Wed Sep 28, 2011 11:50 pm    Post subject:
The 65XXX numbers are for the bare PCB. The same bare PCB could be stuffed with different parts for different aplications. Look for paper stickers with 8XXXX numbers. That will tell what projector the board is for. Sometimes the boards will have a 69XXX sticker. Those are probably older boards.
Scott
Thomas Jefferson
Posted: Wed Sep 28, 2011 11:53 pm    Post subject:
Must be an eco in here...... Laughing
incova
Posted: Wed Sep 28, 2011 11:53 pm    Post subject: thanks Scott
same as the Neckboards then Scott, I will take them out tommorow and have a look through again.
The more I learn
the less I know.
incova
Posted: Thu Sep 29, 2011 12:12 am    Post subject: echo heh
Ok, the backup rgb card is a older card 69448. Pictures are gone? Sorry maybe they are too large.
The card with the SVHS, Video and V Drive has two white stickers the main pcd has a 69409 sticker on it and the daughterboard has a 81121 number, maybe a scaler quad?
The CPU board has a 81437 sticker on it, I have to check the RGB board with the intensity modulator tommorow, thanks all.
The more I learn
the less I know.
Posted: Thu Sep 29, 2011 12:53 am    Post subject: Re: echo heh
That CPU board also has the +/_ 25v error fix on it.
Posted: Thu Sep 29, 2011 1:25 am    Post subject: Re: echo heh
You saw that eh.
But why does that CPU board think it's a peanut butter and jelly sandwich??? Laughing
