BG 808s: Noise with bright image?
Goto page 1, 2, 3  Next
DolbySR
Posted: Wed Jun 15, 2011 7:44 pm    Post subject: BG 808s: Noise with bright image?
Hi there folks!
Just noticed something "interesting":
I feed a 720p60 image over RGB-HV to my BD 808s. When the picture itself is bright, something starts to squeak/chirp. If the picture gets dimmer again, it suddenly stops.
Any idea? This noise comes from a PCB in the rear area - perhaps one of the power supplies?
Posted: Wed Jun 15, 2011 8:05 pm    Post subject:
Unfortunately it sounds like a bad HV quadrupler.
DolbySR
Posted: Wed Jun 15, 2011 8:11 pm    Post subject:
Is it possible to swap this Quadrupler with one from a BG 800 set?
Greetings and have a nice day,
Patrick
Posted: Wed Jun 15, 2011 8:24 pm    Post subject:
When the set fails is there a Red LED lit on the EHT module ?
DolbySR
Posted: Wed Jun 15, 2011 8:31 pm    Post subject:
My PJ doesn't fail at all, it just starts to squeak (not very loud but noticeable) when feeding a bright image.
Patrick
Posted: Wed Jun 15, 2011 8:35 pm    Post subject:
THe quad from the 800 should work. It can also be the HV splitter, I've seen those cause chirping in the quad. The splitter remains quiet.
DolbySR
Posted: Wed Jun 15, 2011 8:38 pm    Post subject:
Just checked, if the 800 quad would fit ... but no, it has the wires off to the back, the 808s quad has it upwards. But I might swap the splitter, since this somehow looks the same.
Patrick
Posted: Wed Jun 15, 2011 9:52 pm    Post subject:
It will work, you just need to put a spacer between the quad and the chassis.
DolbySR
Posted: Wed Jun 15, 2011 10:01 pm    Post subject:
Okay! I will try this tomorrow ... it's midnight now in Switzerland with a wonderful deep-red moon up in the sky.
By the way: What is inside this splitter? Is it just a simple splitter or are there other things involved? And why is this small "box" on this little piece of PCB marked with "Do not touch" in your section of the 800/808 series?
Patrick
Posted: Wed Jun 15, 2011 11:05 pm    Post subject:
NEVER ask about 'do not touch'. It's like that movie Fight Club.
First rule about Fight Club: Never talk about Fight Club.
Smile
You NEVER need to adjust that control. Ever. THe world will come to an end if you do.
(it's HV calibration. Trust me on this one: DO NOT TOUCH.)
DolbySR
Posted: Thu Jun 16, 2011 8:45 am    Post subject:
All right, understood Smile
You know, an electrotechnical engineer has this certain need to know, what is INSIDE a box Wink Now I know it and I don't have to disassemble it.
After I cleaned the dust off my splitter and quad, I will swap them, starting with the splitter. Hopefully I'll find the squeaking-source before I raise it up under my ceiling on Saturday.
Patrick
DolbySR
Posted: Thu Jun 16, 2011 1:11 pm    Post subject:
Hey there, I'm back.
Swapped the splitter - noise remained the same. Reinstalled the 808s splitter again.
Swapped the quad (after adapting it so it could be mounted) - noise gone! Thanks so far @all Smile
But now I'm hearing some arcing in the region of splitter and the HV lead from the quad leading to the splitter. I'll check on it later ... I'm hungry now ^^
Patrick
Posted: Thu Jun 16, 2011 1:36 pm    Post subject:
DolbySR wrote:
You know, an electrotechnical engineer has this certain need to know, .
I'm curious, what is an electrotechnical engineer? Very Happy
DolbySR
Posted: Thu Jun 16, 2011 2:35 pm    Post subject:
(Ab-)Use Google Wink
But yea, it's usually called electrical engineer, as it seems. We are used to call it electrotechnical engineer ... from the German study description "Elektrotechnik" ^^
Patrick
Posted: Thu Jun 16, 2011 2:51 pm    Post subject:
I wanted a more personal response. I know google very well................ Laughing
P.S. Are you being snarky???? Laughing
DolbySR
Posted: Thu Jun 16, 2011 3:12 pm    Post subject:
Oh, well ... an El-Ing, as I call it (^^) is some type of engineer, who studied electrical circuits, electrical fields and components, computer science and some physics for semi-conductors, including quantum physics. There are several types of specialization here, such as power electronics, optical electronics or communication and antenna design.
And yea, although I started learning English when I was 5, I sometimes don't get the detection of sarcasm right ^^ I guess I'd need a "Sarcasm Sign" ^^
Patrick
DolbySR
Posted: Thu Jun 16, 2011 5:31 pm    Post subject:
... by the way: Arcing disappeared Smile Probably was a humidity problem since I cleaned the splitter before I installed it back into the PJ. Why not use the opportunity to remove dust and dirt off a component, when you have it outside the PJ Smile
Patrick
Posted: Fri Jun 17, 2011 12:46 am    Post subject:
If you swap in the quad from the 800 check the EHT part number on your 808 it needs to be R76XX27.
Posted: Fri Jun 17, 2011 3:22 am    Post subject:
More info on compatibility.
http://www.curtpalme.com/docs/BarcoServiceBulletin_R762716_New_EHT.pdf
DolbySR
Posted: Fri Jun 17, 2011 11:27 am    Post subject:
Interesting ...
I now have the (old, BG800) R761743 Quad, the (new) R762716 EHT Module and the new Chassis. According to the compatibility list, there should be oscillations. What ever that means ... the PJ works and the picture looks stable to me?
I'd better replace the quad with a new version then anyway?
Page 1 of 3
