| Posted: Thu Apr 21, 2011 12:03 am Post subject: |
| draganm wrote: | | macgyver655 wrote: | | draganm wrote: |
In your case I doubt it's a reversed cap, they will almost always blow instantly and trip the circuit. |
This has to be the most blatant non tech response I've heard in a while. Your disappointing me Drags. And after I have slowly been speaking positively of your work..  | why is it no one can post their opinion in a thread without you starting an argument? Do you see me quoting your opinions and saying they're "disappointing?
And Thanks but I don't need you to speak positively of my work and better yet if you don't speak of it at all that would be best. |
Hahahaha, isn't this just funny. I don't know why you think I'm trying to start an argument. You were the one contradicting my post.
And I stated a while back then when someone posts something "wrong" I was going to let them know about it.
Now thats not to say your totally wrong but reversing a cap will NOT always blow up or what not, especially not on a video board. So your "opinion" is mostly incorrect, and "you" should know that, but apparently you don't....... But you stated almost always. If you worded it differently I probably would not of commented.
And a "tech" would not make such a statement. Reversing a cap may blow if in a higher current line.
And I will be more then happy to "NOT" speak positively of your work.....especially after your posts here.
CxTurbo
Joined: 13 Oct 2008 Posts: 425 Location: Ontario, Canada
| Posted: Thu Apr 21, 2011 12:34 am Post subject: |
Sweet. Thanks for the offer as well Curt. I have tested most of the boards to be working with the exception of the nasty ones removed from a Runco machine that I bought basically because you had just redone the focus and convergence boards. Those I put in my 9PG. I have more parts for this damn thing then I care to admit honestly. 3-4 sets of good tubes. 3-4 of each board. Plastics and chassis. Power supplies and so on.
I will be in touch anyhow. I still need that stuff from you for the Marquee.
_________________ Paradigm Studio 100's,Studio 20's,CC-690, Paradigm DSP-3400 V1 SUB
Pioneer Elite SC-35 AVR
Pioneer Elite BDP-05FD Bluray
3x Bryston 3B's
URC Complete Control Medius TX-1000 Remote
HTPC (LGA775 Q6600, 8GB DDR2, 7TB Storage) Mediaportal
Lumagen MINI 3D
Moome FULLHD-EXT V2
Audioquest Cable Top to Bottom
9501LC
| Posted: Thu Apr 21, 2011 2:29 am Post subject: |
| CxTurbo wrote: | Here it is. I was hoping it was much simpler and I wouldn't have to swallow my pride.
I did not have 16v 22uF caps..... I put in 50V 22uF caps because I was told going to a higher voltage was ok before with other things I have done. Mainly audio buffer circuits and chip amps. | like Curt said, this wouldn't cause a problem IMO. Is it possible you damaged something with ESD? If your working in a carpeted room with the central heat running and walking around with socks on it could easily cause a big static discharge after coming back from a break.
CxTurbo
| Posted: Thu Apr 21, 2011 1:13 pm Post subject: |
I could be a possibility Dragan. Although I do not have carpet in my work area. Could happen though.
I have yet to check the voltages but it does seem logical that a low voltage could cause an issue.
Getting into the base of the chassis will not be easy and from what I see from the diagrams of that board the check points are on the connector at the bottom. Is that what you meant by needing those NEC boards Curt? If so I am probably just going to send them both to you. the one with no video output and the one with low output.
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
| Posted: Thu Apr 21, 2011 2:13 pm Post subject: |
Yeah, you'd have to individually solder wires to a test point to bring them out of the set where you can measure them. I've done it with an XG system board once, spent 6 hours on it, and still didn't get it going. I've never seen those extender boards, and haven't had the time to build any.
| Posted: Thu Apr 21, 2011 2:16 pm Post subject: |
| CxTurbo wrote: |
Getting into the base of the chassis will not be easy and from what I see from the diagrams of that board the check points are on the connector at the bottom. Is that what you meant by needing those NEC boards Curt? If so I am probably just going to send them both to you. the one with no video output and the one with low output. |
Its very easy to just remove the board, solder a bunch of small gauge wires to each voltage location you want to test and mark them with a piece of tape as to which voltage it's connected to. Then just put the board back it and tape the wires to the plastic case so they dont touch, fire it up and test from your wires. You dont need extender boards for usual testing.
| Posted: Thu Apr 21, 2011 2:17 pm Post subject: |
| Curt Palme wrote: | | Yeah, you'd have to individually solder wires to a test point to bring them out of the set where you can measure them. I've done it with an XG system board once, spent 6 hours on it, and still didn't get it going. I've never seen those extender boards, and haven't had the time to build any. |
Ha, guess we were posting at the same time.
CxTurbo
| Posted: Thu Apr 21, 2011 4:37 pm Post subject: |
ha, ha. Don't know why I didn't think of that.....
Am I correct in assuming that the top row of that bottom connector is "A" and the pin on the far left is "1" component side up? I did not see a pin diagram in the board level repair manual.
As always thanks guys. Is it not human nature to overlook the simplest things and think the worst sometimes. Plus I build, tune and sell car parts. Electronics is just an interest of mine. I learning slowly and I do mean slow..........
James
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
| Posted: Thu Apr 21, 2011 4:54 pm Post subject: |
| CxTurbo wrote: | ha, ha. Don't know why I didn't think of that.....
James |
If your manual is the same as mine then the connector diagram is on page 6-59.
I never trust the diagrams for pin numbers. I always use my DMM set to continuity or diode and look for the nearest component on the schematic to the pin I'm trying to locate and test for that pins location in the connector. Identifying 1 pin on each row is all that's needed.
| Posted: Thu Apr 21, 2011 7:36 pm Post subject: |
| CxTurbo wrote: |
I looked over the service manual and could not find what components C3009 affects and if it by chance took out something else when it blew.
Or where in the circuit it is and if it would/could affect all three channels output.
I must of over looked this post. C3009 is tied to the +12v line which is also the line that feeds the RGB video gain chips. So if this line is low or dead it will affect your video. The OSD is injected after these chips so that would explain why your OSD is fine.
| Posted: Thu Apr 21, 2011 7:45 pm Post subject: |
I tried to vaguely answer your question on capacitor values and changing them because as I said ,the answer is much larger then yes or no.
As rule of thumb in the electronics world you can increase both voltage and/or value without any consequences, however, there are some circuit that don't like either being altered. Mostly because changing the value can change impedance and if the circuit relies on a specific resonant frequency is may not be achieved and may not function. Or function poorly.
This can also be affected by the voltage value increase because the larger leeds, plates and fluid volume can on a much lesser degree affect impedance.
I wanted to find a document that gets more involved in this explanation and I found this one that is of interest.
http://www.tnt-audio.com/clinica/regulators2_impedance1_e.html
CxTurbo
| Posted: Thu Apr 21, 2011 10:04 pm Post subject: |
Awesome Mac thank you for that post. I will read it and then read it and probably read it a third and fourth time just to make sense of what is going on and retain what I can.
If you do not mind my asking what affects in this peticular circuit would even changing the ESR of a capacitor have? i.e using a cap not listed as low ESR or a higher rated ESR than what was there.
Would it affect the white balance trim pots by introducing a higher resistance in those lines or would that be so minor it is a non issue?
As far as the manual I have several of them. The only one with schematics for the boards is the + models. The board level manual I have for the plains only has block diagrams and no schematics.
Thanks again my friend.
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
CxTurbo
| Posted: Thu Apr 21, 2011 10:51 pm Post subject: |
Ok, so I was looking at the diagrams that I have and I can see that the 12v+ line feeds the 3 C3*09 caps that do indeed go to those chips.
I can also see that that 12v+ line is regulated by a 7812 positive regulator. driven by the +15V line on the main connector.
My plan is to attach a lead to the output and input line on that regulator and see if there is the correct voltage on those lines then go from there. Should be fun! I will let you guys know how I make out.
If it turns out that regulator is bad I will order a bunch and replace that. Then go on from there.
Thank-you all for the help
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
CxTurbo
| Posted: Fri Apr 22, 2011 7:33 pm Post subject: |
Well, Tested that regulator and it has 11.9v out and 15.2 in so that is within spec in my eyes. I am going to now look to see if I can find what the output of those gain chips should be. I have video but no control over how bright that video signal is. I suspect that they might be blown.
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
CxTurbo
| Posted: Fri Apr 22, 2011 7:58 pm Post subject: |
Well it is either the Gain Jfet or the LM chip that is bad I suppose. I do not have a scope to test the output on the LM chip.
Would a blown cap really take out 3 Jfets or the three Lm chips? I do not remember if it was backwards I just tore it out when I saw it was bad and put in a new one.
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
| Posted: Fri Apr 22, 2011 8:17 pm Post subject: |
I really don't want to discuss this much further in open forum because I believe we have already passed the recapping part of the original discussion.
So I will offer 1 last question. Did you check "ALL" of the incoming voltages to that board like I told you to?
CxTurbo
| Posted: Fri Apr 22, 2011 8:22 pm Post subject: |
I respect that.
I will go over them again and double check.
Thanks for the advice.
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
