Focus Issue with Vision 1
dvh99
Posted: Thu Mar 24, 2011 6:55 pm    Post subject:
if you had good focus after removing and inserting the clm i would clean the contacts on the clm that go in the backplane of the projector with alcohol.
something went wrong with posting, hence the 3 posts.
haireez
Posted: Fri Mar 25, 2011 3:14 pm    Post subject:
Hi Athanasios
I've replace with another HV splitter but still doesn't help. This is the strangest problem I'm facing with this Vision 1.
2 White Vision 1
Posted: Fri Mar 25, 2011 3:29 pm    Post subject:
haireez wrote:
Hi Athanasios
Did you check the dot shape as I suggested?
haireez
Posted: Fri Mar 25, 2011 3:55 pm    Post subject:
Hi Tim,
I will try to do it this Sunday and get back as soon as I can.
2 White Vision 1
Posted: Fri Mar 25, 2011 4:22 pm    Post subject:
haireez wrote:
Hi Tim,
I have only seen major focus issues when the stig system had problems, never seen a high voltage supply do that.
haireez
Posted: Mon Mar 28, 2011 2:52 pm    Post subject:
Hi Guys,
I have good news. I replaced 8 resistors on the vertical boards (V-Fail) and sprayed focus board contact with different contact cleaners and to my surprise, all tubes are now able to focus.
Till now, I'm still not too sure what could be the root cause...
I really appreciate the support I have been receiving from all of you here. THANKS GUYS!!!!!!!
2 White Vision 1
dvh99
Posted: Mon Mar 28, 2011 3:25 pm    Post subject:
probably just dirt.
