| Posted: Mon Feb 14, 2011 8:27 am Post subject: |
| zGman wrote: | I have P43 phosphor 9" tubes here from 909 3d applications,
they are labeled < PT22-30 > The output is distinctly
yellow-green, and the output at 60Hz is less than a LUG,
but quite usable, especially in a driving sim application....
Normal green LUG tubes are not P43 phosphor, despite
the coincidence in the part # - otherwise you would
never get the correct primary color .... never ever, not
even with a filtered c-element.
LPB03 is a Barco pinout High Res 9" tube - very nice to have!
Another thing that can be used to identify tube types -
High Res tubes will have white/white glass for the
gun assemblies, for both 8" and 9" versions.
(These tubes have Barco pinouts.)
LUG tubes will have white/pink-brn,
LQF tubes (G90 stock) also white/pink-brn.
(These tubes have grid 3 on pin 7 and Barco pinouts.)
Marquee standard res - white/blue
Barco standard res - white/yellow |
Would it be possible for you to upload an image showing where to look for the colours you describe above?
| Posted: Mon Feb 14, 2011 3:03 pm Post subject: |
Galen,
Thanks for this fantastic information. I should have just asked you about these tubes instead of getting ready to run an experiment I wish I would have thought of you beforehand. Anyway, based on your info I am going to cancel the P19LUG43 test because I am sure you know what you are talking about and I trust your information.
Thanks again, you saved me some serious time.
zGman
| Posted: Mon Feb 14, 2011 6:02 pm Post subject: |
""Would it be possible for you to upload an image showing where to look for the colours you describe above?""
Maybe later - but the glass supports are integral to the gun assembly, which is in the tube neck,
near the neckboard end, right about where the cpc magnets usually go - maybe harder to see
on some PJ's than others, especially if the area is dusty.
G
dturco
dturco
| Posted: Mon Feb 14, 2011 6:49 pm Post subject: |
| Nashou66 wrote: | Dave those pics are of High res tubes.
I have a P43 Green phosphor in one of my 8 inch Marquees and even with the HD 145 green lens I was not able to get Green in REC 709 CIE chart location it should be. On my Longbows I get very close. So Galen's info is spot on.
Athanasios |
Ok but as obtuse as I am, I am really just trying to figure out what part of that picture we're talking about. Is it those plastic strips on the cathodes? I think it is?
http://www.hulu.com/firefly
| Posted: Mon Feb 14, 2011 6:58 pm Post subject: |
| dturco wrote: | | Nashou66 wrote: | Dave those pics are of High res tubes.
Athanasios |
Ok but as obtuse as I am, I am really just trying to figure out what part of that picture we're talking about. Is it those plastic strips on the cathodes? I think it is? |
Yepp!!!'
dturco
| Posted: Mon Feb 14, 2011 7:07 pm Post subject: |
Good to know! Now how about that tube face
dturco
| Posted: Mon Feb 14, 2011 7:18 pm Post subject: |
I Can't see any wear on the tube face when I look at it. It just looks snow white. Although it does look like there is in that picture.
| Posted: Mon Feb 14, 2011 7:58 pm Post subject: |
Athanasios |
Except that they are made of glass, not plastic I have had them crack in shipping before so always inspect them before you mount up a new tube.
dturco
| Posted: Mon Feb 14, 2011 8:04 pm Post subject: |
| CIR Engineering wrote: | | dturco wrote: | | Nashou66 wrote: | Dave those pics are of High res tubes.
Athanasios |
craigr |
Man you guys , always give someone something new to worry about don't you. Now I've got wear on new tubes, and cracked GLASS INSULATORS on the cathodes. I won't get perfect 709 green and I need 72hz to make them look good.
Anything else?
Oh and they were not shipped. I picked them up.I wrapped them in plastic and foam and cardboard and then wrapped them in a quilt to keep them warm. And the were transported in a fine luxury Lincoln Town Car.
| Posted: Mon Feb 14, 2011 9:36 pm Post subject: |
| Nashou66 wrote: | | dturco wrote: | | Nashou66 wrote: | Dave those pics are of High res tubes.
Athanasios |
Yepp!!!' |
So what does blue/blue mean
zGman
| Posted: Mon Feb 14, 2011 10:01 pm Post subject: |
Never seen Blue/blue - what type of tube?
| Posted: Mon Feb 14, 2011 10:09 pm Post subject: |
| zGman wrote: | | Never seen Blue/blue - what type of tube? |
Sony 09MEX2
| Posted: Mon Feb 14, 2011 11:42 pm Post subject: |
| dturco wrote: | | CIR Engineering wrote: | | dturco wrote: | | Nashou66 wrote: | Dave those pics are of High res tubes.
Athanasios |
craigr |
Anything else?
Oh and they were not shipped. I picked them up.I wrapped them in plastic and foam and cardboard and then wrapped them in a quilt to keep them warm. And the were transported in a fine luxury Lincoln Town Car. |
LOL
Well, if it is any help, I think Tom might be wrong about the wear. What we may be seeing is the way the light can reflect off the phosphor when light comes in through the sides made of thick glass. So you may not have wear.
Gerbrand
| Posted: Tue Feb 15, 2011 12:28 am Post subject: |
To get this topic back on topic: by cranking my contrast up to 90 I managed to get 10 ftL out of my projector. The grayscale is almost flat and the scan lines remain visible.
I think I can go and watch a movie now!
Gerbrand
| Description: |
| Filesize: |
89.7 KB |
| Viewed: |
8452 Time(s) |
_________________ BG1209s (color filtered,new LUGs!), 13000h
Bat cave
azzkicker
| Posted: Tue Feb 15, 2011 5:57 pm Post subject: |
hi
@Gerbrand
how large is your screen?
my 1292 on an 100" screen makes calibrated 11ftl Gain is 0,9
regards
_________________ 1292 without streaking
Gerbrand
| Posted: Tue Feb 15, 2011 6:52 pm Post subject: |
| azzkicker wrote: | hi
@Gerbrand
regards |
I have a 100" screen also.
Gerbrand
Bat cave
