Everything you want to know about Frankenyokes in one shot!
Goto page Previous  1, 2, 3 ... 25, 26, 27 ... 35, 36, 37  Next
Posted: Sun Feb 07, 2010 2:57 am    Post subject:
tse wrote:
A couple of thoughts about focus mags.
1. The static and dynamic windings need to be near the nominal value. Especially the dynamic. The amplifiers are designed to drive a specific inductance.
2. Lower resistance in the windings will help the static most. Less doesn't hurt the dynamic winding but there isn't any big advantage to be gained. Use the size wire that fills the bobbin.
3. If the top/bottom and left/right focus settings are best at "0" and need to go more there is a good chance that the winding is wired to the amplifier wrong. Reverse the coil connection to the amp.
Scott
1) Thanks Scott, I was waiting for that specific info about the amps, I lost your PM from long ago.
2) I remember the static part so I think 30 Gauge will be the best as its the largest i can fit onto the Bobbin I hope.
3) Scott, is the top bottom, left and right all from the dynamic or are top and bottom part of static? I could just remove the Dynamic and try to adjust top and bottom and see what happens Wink
CJ wrote:
I picked up more parts for my magnetizer jig today. Once I order the caps (no sense in scavenging at the local electronic junkshop to try to find enough of the right type) I'll be ready to start wiring it up.
I'll be anxiously waiting pics of your "FrankenMagnetizer " Rig !!
Posted: Sun Feb 07, 2010 4:48 am    Post subject:
Scott you were right, on the very first Barkenstien Yoke I ever wound I reversed the static coil windings and it came right in. Also I am using only a 2 pole CPC set and the tube is just sitting bare on top of the PJ so everything is a bit loose. But this is the best results so far.
Some more info on my test Chassis, it has no astig board, and I also did not wire up any astig windings on this set. I also think to really optimize the Frankenyoke and Barkenstien we do need to add the thermal-resistor. It was on the original design for a reason so I think we should add this to the magnet structure somewhere.
One thing i did notice with this set up is that if i over focus, the dots get so big they overlap each other, so there is way to much current than is needed, underfocusing is fine. I think it might be due to the fact I have the dynamics wound too much, 60uh, I think i did this back then because i did not have the right gauge (16) wire to fill the entire 22 mm length of the bobbin and keep the correct 45uh inductance, I used 24 IIRC and it covered one layer but came out to 60uh which i think is causing some adjusting issues. But so far it looks promising. I need to get another set of 6 pole magnets and put the Astig amp board and wire up the Astigs on these barkenstiens. I am not sure if those windings will work. I think they are only 56uh or 60uh i can not remember but the marquees are 156uh. But for those who use the Sony Coils they are 53uh so I am wondering how they work for you guys as i never tested the astig coil yet.
I also have to reopen this Coil up and make sure the Dynamic come after the Static winding so it matches the placement of the Thompson coil, where the beam passes through the Static winding then through the Dynamic. Id like to keep this the same as well.
dvh99
Posted: Sun Feb 07, 2010 6:52 am    Post subject:
thats a nice project with those yokes.
do you wind those coils yourself or do you have someone doing that for you?
and 16 gauge is that the diameter of the thread?
i know that there are transformers with silver windings.
maybe this is something to try on the focus yokes, it might lower the inductance.
Posted: Sun Feb 07, 2010 1:28 pm    Post subject:
I use this to do the Static coil since the wire is very fine and you need about 750-850 turns depending on wire gauge.
Silver really would be a waste of money and not or real benifit. You need to keep inductance the same as Scott mentioned earlier. A lower resistance would help the Static coil more than the Dynamic.
dvh99
Posted: Sun Feb 07, 2010 8:58 pm    Post subject:
wow i am waiting in anticipation.
i saw myself getting a device like nashou has to get the same inductance.
then the question would be what threaddiameter to use 1mm 0.9mm.
smaller diameter is higher resistance.
now to i have to find some frankenyokes.
i understood they were only used in sony1292
any other models they might be in?
Posted: Sun Feb 07, 2010 9:42 pm    Post subject:
Barco 909 focus coils are better than the 1292's. I have a set in my Marquee now. I once had a set of 1292 coils, but did not like them.
The 909 coils have a more precise focus range and are easier to work with. Unlike the 1292 coils, they are closer to the design for that type of tube used in the Marquee.
But of course, that's if you can also find them.
Posted: Sun Feb 07, 2010 9:49 pm    Post subject:
Once I've successfully completed my experiments, I will be able to convert most any of the K-D brand yokes to be optimized for Marquees. Ideal resistance and inductance values, ideal magnetic strength.
I'm collecting the parts I need to build my magnetizing jig right now. I'm a few capacitors short of what I need. But I already have all
the hard to find parts, the massive toroidal transformer to rewind as a single coil being prime among them.
I guess anybody with enough patience could rewind their own coils, but to change the magnetic field strength of the magnets in the coils
to the optimal value requires special equipment. I'm making the investment in that equipment.
CJ
Posted: Sun Feb 07, 2010 10:05 pm    Post subject:
Like I said earlier in the thread the Barco yokes have the same if not better Static focus ability as the Stock Marquee Thompson yoke when not connected electronically.
Mike can also attest to this, however his 909 coils seem to have the same coil values or close to those of the Marquee's. Id like at least one here for testing,measuring, etc.
The 1292 magnet structure would definitely benefit from an increase in magnetization as would older weaker magnet structures.
The only way to know for sure how strong the static focus is to unplug your yokes. If its fairly well focused then you do not need them magnetized any more.
dvh99
Posted: Sun Feb 07, 2010 10:13 pm    Post subject:
so now i am on the lookout for 909 coils thanks mike.
where to find this needle in a haystack Smile. ehm 3 needles
i will send a mail to arbey the barco guy.
can pick them up personally if he has some.
i will mail barco too they might have some lying around.
i hope they switched to digital alltogether and want to get rid of their obsolete stuff taking up space. just kidding i dont like digital.
i will mail a company here in holland that makes very high quality trafos and ask them how to achieve a certain magnetic field strength, i will report that here once i got an answer.
Posted: Sun Feb 07, 2010 10:32 pm    Post subject:
Just a thought here...wait until I've done my prototypes and announced complete success. Then, at that time I can use most ANY K-D yokes and turn them into optimal yokes for Marquees. Rewind and remagnetize them to the IDEAL values. 909 yokes are very hard to
find, and justifiably so. But less desirable types built on the same basic design are completely suitable for conversion. When I'm done,
it won't matter if the donor yokes are from a 909 or a Sony 1292 or an AmPro or some other PJ....it's the after conversion results that
matter, and at that point they should ALL be the same.
CJ
Posted: Sun Feb 07, 2010 10:34 pm    Post subject:
CJ
Exactly !!! Thumbs Up
nashou
Posted: Mon Feb 08, 2010 12:38 am    Post subject:
I think I need to add that I have learned that there are SOME models of K-D focus yokes which are not useful for Marquee usage no matter what you do to them as their core diameter is simply way too small. They are suitable for thin necked Toshiba tubes, as found in, for
example, NEC XG 75s, but in no way, shape, or form are they going to be any use at all for a Marquee.
One part number for one of these useless yokes is KQD17. Don't bother to save up any K-D yokes which have the small diameter central hole.
The ones that are suitable have a hole diameter of about an inch and a half. The useless small ones have a hole diameter under an inch and a quarter.
CJ
dvh99
Posted: Mon Feb 08, 2010 12:58 am    Post subject:
oh my god when will u use the metric system i had to get those silly measurements allen tools 3/16 9/64 lol.
inches and fahrenheit so funny.
Posted: Mon Feb 08, 2010 1:27 am    Post subject:
It's deeply entrenched in American culture and you'd better get used to it. Why did you Europeans feel the need to mess with a perfectly
sound system?
I'm not handicapped and unable to work in metric, though. I convert to metric in my head when needed.
Say 30 mm for the small hole in the KQD17s, and 38mm for the larger hole in the KD yokes that are usable for the conversion. That's close enough.
Don't criticize my love of the Imperial standards system or I'll double the price on the Advanced FrankenYokes, just for you! Very Happy
Posted: Tue Feb 09, 2010 5:42 am    Post subject:
Here is a pic from my first Barkenstein yoke I have been testing.
I found I got better focus this time by moving the coil back and forth till it focus
well at settings i had the other two tubes with stock coils at, it cam out to be about
9mm behind the convergence yoke, or where the stock coils is. the edges where i thought i had trouble with came in nicer.
But I am still going to do a new wind of the Dynamic with 16 gauge and the static with 30 gauge.
But as they are now they are ready for use in my opinion.
One more thing that might be affecting my specific set up is i am using a deflection coil from
an 8 inch tube, I think i asked this before but are the 9 inch coils much different in shape
so they would fit better on the 9 inch bell housing?
If any one has some 9 inch deflection coils let me know.
Posted: Tue Feb 09, 2010 12:57 pm    Post subject:
What is your static focus value?
Don't work on this too fast...I'm supposed to be the guy who leads in the Frankenyoke project! Slow down a bit! Very Happy
CJ
Sparky015
Posted: Tue Feb 09, 2010 2:09 pm    Post subject:
Sort of related, but I was doing a search for the heck of it looking for 9 inch tubes. I figure as My 8 inch tubes age, I would look for some 9 inch, preferrably LUGS, at a decent price for a future upgrade. In my quest, I found this website:
www.tubularoutlet.com/index.html
Not sure if any of you have any experience with these guys as you work on the frankenyoke project?
Paul
Posted: Tue Feb 09, 2010 2:28 pm    Post subject:
Paul
Not very good, take your chances. Id get the Tubes from Greg Eiseman instead.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=13063.html
Posted: Tue Feb 09, 2010 2:42 pm    Post subject:
CJ
My static value is exactly 30uh for that coil.
Chris you were away for so long, i started this way back in fall of 2007, but posted my first pic of the
one barco magnet structure that did not focus as well "dead" as the newer set i have.
http://www.curtpalme.com/forum/viewtopic.php?p=87675#87675
Then I started back up again in the fall of 2008:
http://www.curtpalme.com/forum/viewtopic.php?p=155906#155906
And then again once I got my test chassis into my Work shop and painted the LC chamber with black Epoxy and mounted
the Thomas Tube.
Posted: Tue Feb 09, 2010 2:50 pm    Post subject:
I mean, what's your static focus value in the Marquee's focus setting? With 50 being ideal, how close are you?
I'm just pulling your leg about being first. It doesn't matter! Very Happy
CJ
Page 26 of 37
