Everything you want to know about Frankenyokes in one shot!
Goto page Previous  1, 2, 3 ... 10, 11, 12 ... 35, 36, 37  Next
Joust
TV/Projector: Marquee 8501LC
Posted: Fri Aug 31, 2007 1:50 pm    Post subject:
i didn't notice it either. thats because I paid my measly $10 to become a member and not have to see the adds. ya bunch of cheap bAA$tards
BTW the magnets in the yokes are made of ferrite i think. They are artificially magnetised very much like a video tape is when you record onto it.
Posted: Fri Aug 31, 2007 2:30 pm    Post subject:
I found a company that will custom make exact sizes . but i requested a quote for 9 magnets the exact size of OD 2.7 x ID 2.2 x W .5 inches . We'll see what they say.
tse
Posted: Fri Aug 31, 2007 5:36 pm    Post subject:
There is alot of technology in the focus mags. As far as I can tell this attachment is the patent for the KD type mags. Special stuff involved.
Scott
5113162.pdf
 Filename:  5113162.pdf
 Filesize:  198.7 KB
 Downloaded:  371 Time(s)
Thomas Jefferson
Posted: Fri Aug 31, 2007 6:21 pm    Post subject: KF-3203 KOK21 magnets seem good to go.
Scott
Yeah I know and also that specific patent is for the KF2211 there is no astig windings as far as i can tell so it wont help out for the KF22-22. but i just tested my KF3203 KOK21 with out any dynamic or static coil windings and it looked actually better than the stock thompson with out the coil winding conected. So we now know that at least the magnets in the KF3203 KOK21 are strong enough. i attached a pic but i was shaking and its hard to take a pic of the tube face while lying on the ground . I Decided not to remove the tube from tes PJ and just let the rear plane hang, i put a piece of plywod over the back plane boards and this is where i put the test tube and did the swapping of the focus magnets.
this is a pic of the Barco KF3203 KOK21 focus coil magnets. the dip on the grid is from a bad vertical deflection board i need to replace. Let me know if this is satisfactory. Keep in mind i was not able to get a good pic and it loks alot better in person.
Athansios
PS i found a LCR meter on ebay and will test the mh of the windings in this coil now this coil is different than the one mentioned earlier in this thread that one was a 3205G i believe so this coil may work. more testing to come now that i have my test set ready for the job.
tse
Posted: Sat Sep 01, 2007 12:11 am    Post subject:
Cool! At least it is close. If there is room on the tube neck to move the magnet back it might bring it closer to perfect focus but that might make it go the other way, too. It will probably take some means of fine focus adjustment to get the projected image right. Fine focus adjustment can be done with a DC power supply with variable current output. Just connect to the static winding and adjust current. Reverse connection if it goes the wrong way.
Scott
Thomas Jefferson
Posted: Sat Sep 01, 2007 12:19 am    Post subject:
I didnt even have the winding in the magnet core, that is with a straight magnetic field. I'll try to night moving the magnet core back a bit but i think if i have the astig magnets in there correct positions(more forward about an inch) it might be the thing were looking for.
Connecting the dc source would be the same as the focus control of the red tube in the service menu correct?
i dont have a variable dc source to test it with.
Posted: Sat Sep 01, 2007 12:20 am    Post subject:
The thing i like is the dots being round and the centers bright and perfectly in the center. so maybe the astigs are in the right place farther back?
hmmm?
tse
Posted: Sat Sep 01, 2007 12:44 am    Post subject:
Believe it or not most tubes are very near perfect round dots and beam centering is usually near right even without the little neck magnets. Most need only a very small adjustment.
The statis focus places a DC current throught the winding. 50% is about 0 current, 0% is about -0.2A, and 100% is about +0.2A. That's for the Thompson magnet where the inductance is about 25mH. Lower inductance will take more current to do the same thing.
The formula is 1/2 x L x I^2 = energy
L = inductance in Henrys
I = current in amps
I^2 = current in amps squared
So with 0.2A current and static winding inductance at 25mH the energy is 500uJ.
If the static winding is 250uH it would take 2A of current to change the focus the same amount.
Yikes! Math. Mr. Green
There will be a test tomorrow. Shocked
Scott
Thomas Jefferson
Posted: Sat Sep 01, 2007 1:21 am    Post subject:
well i think my next step will be putting the coils back into the magnet cores and wire it up to the harness but with out cutting the original thompson coil harness. I'll need to go get some clored wire and some clips to fit. So with all that math mumbo jumbo what your basicaly saying i better hope i have a higher inductance, closer to 25mH than 250microH.
Athansios
Posted: Sun Sep 02, 2007 1:33 am    Post subject:
By LARGE, when describing the toroidal coil/transformers used to magnetize and then demagnetize the yokes, I mean large
enough that the yoke assembly will completely fit inside the central core space.
This makes the outer diameter of the toroid pretty big, about a foot in diameter, and it's quite heavy.
At least, that describes the one Scott uses to adjust Thomson yokes.
I HAVE seen toroidal transformers in this size range that have been taken out of scrapped industrial equipment. So
you COULD find such items if you look around hard enough, without paying insane amounts of money to get them.
But you will have to find companies that specialize in electronics recycling and surplus, and get them to help you out,
I'd be willing to bet.
The magnets in the Kanto-Denshi yokes aren't all THAT strong. They're some grade of Alnico, and FAR from the strength
of even the weakest neodymium or other rare earth "supermagnets".
Here's a concept: You can do some experiments in making a DC electromagnet as part of your Advanced Frankenyoke
project. Use it as your outer field magnet and dump the original K-D or Thomson magnets altogether.
With a good variable power supply (or three), you could determine the correct static field strength for optimum
performance, and so long as you are sticking with one resolution (focus parameters are affected slightly at different
refresh and scan rates), you'd have a workable solution to the magnet problem. Not exactly an elegant solution,
but a solution nonetheless.
And if your meter is calibrated, you could note the exact current and voltage drive to that coil that gives optimal
results, then send it off to someone who can make magnetic field strength measurements like Scott, and have him
duplicate your voltage and current settings and then have a point of reference for calibrating the customized yokes.
Winding electromagnets isn't tough. It just takes patience. Anyone could do it.
CJ
tse
Posted: Sun Sep 02, 2007 5:03 pm    Post subject:
Attached is a pic of the focus magnet that ESP was using when I started working for them in 1982. IIRR it was a flat donut shaped piece of ferrite sandwiched in between two big steel washers. The three "ears" were smaller washers welded to one of the larger ones. Something like this would not be too hard to make in a home workshop. I tried it on a 'LUG tube and it actually worked! I didn't do any measurements or comparisons to more modern magnets, though.
Scott
 Filesize:  131.4 KB
 Viewed:  8290 Time(s)
 Filesize:  135.17 KB
Thomas Jefferson
antorsae
Posted: Mon Sep 03, 2007 1:01 pm    Post subject:
Scott,
What would happen if the 15K resistor is not connected? The earlier diagrams in this thread do not include it and yet people seem to be using these mods with success.
BR - Andres
Joust
Posted: Mon Sep 03, 2007 2:05 pm    Post subject:
antorsae wrote:
Scott,
BR - Andres
Have I missed something? What 15k resistor?
tse
Posted: Mon Sep 03, 2007 2:07 pm    Post subject:
When the thermistor is connected it changes the static focus a small amount (<1%) depending on it's temperature. It might change the top (or bottom) extreme of static focus if not connected. Must not make much difference.
Scott
Thomas Jefferson
Joust
Posted: Mon Sep 03, 2007 2:19 pm    Post subject:
OH Yeah. I've been menaing to try that. But it certainly isn't required.
Posted: Tue Sep 04, 2007 1:33 am    Post subject:
I've found the CD with most if not all of the original photos in my first posts in this topic, which now are broken links. I'll attempt to restore
those pics and edit the posts to match over the next couple of days.
CJ
antorsae
Posted: Wed Sep 05, 2007 8:34 am    Post subject:
Hi - I have one question for the magnetic experts: as per the instructions in this thread and AVS I opened the shell and reversed the direction of the coils so that the magnetic polarity is the same as with the Thomson yokes. I also had to do this on the G90 yoke as I had the same polarity as the 22-22 one.
My question is: what would happen if I hadn't reversed the coils? I believe cmjohnson mentioned that this was important as otherwise the tube may be damaged but the more I think about it, I think it would not have an effect... as the G90 and 1292 are driven with reversed (as the Marquee would see it) and the rest of the electronics are almost compatible (unless the deflection coils is doing something I don't understand).
I am saying this as I'd like to try the focus coils are they were designed (I suppose the static/dynamic focus closer to the tube face, stig closer to neck boards).
Let me know what you think!
Andres
Posted: Wed Sep 05, 2007 12:29 pm    Post subject:
I now believe that it's merely important that all three coils have the SAME magnetic orientation in the same projector.
Whether it's "north to the front" or "south to the front", it shouldn't make much difference. Just as long as all three are
oriented in the same way in the same projector.
CJ
antorsae
Posted: Wed Sep 05, 2007 12:31 pm    Post subject:
Well... I couldn't wait so I tried the focus coils in their original magnetic position (the opposite as in the Marquee) in my test bench projector and THEY WORK! The did not fry and tube. I will install them in one of my Ultras to see how it compares to the "reversed" version.
antorsae
Posted: Wed Sep 05, 2007 12:35 pm    Post subject:
CJ
Chris - I just verified this. I installed all 3 in the same position (stock position for the 22-22 and the G90 yokes) and they did not break anything.
What this means is that you:
1) no longer need to open the frankenyokes.
2) SHALL NOT mix thomsons and frankenyokes in the same PJ (assuming you keep the stock polarity in both).
Chris - This mod is amazing! Thanks! Thanks also Scott, Joust, JohnHWMan etc and all others participating here as I couldn't have done/tried this without the (magnetic) insight.
Page 11 of 37
