EXT-FULLHD v3 - Where's the forum thread gone?
barcoed
Posted: Thu Dec 02, 2010 3:46 pm    Post subject: EXT-FULLHD v3 - Where's the forum thread gone?
Where's the forum thread gone? ... for that matter, where's the link to the product on the main site? Confused
moome
Posted: Thu Dec 02, 2010 3:54 pm    Post subject:
we will have new page later on other site~~~
ElTopo
Posted: Fri Dec 03, 2010 5:54 pm    Post subject:
Moome,
it seems my HD Fury1 died today Sad
I cannot wait for the new 3D ready external box Mr. Green
Shipment possible this year ?
ElTopo
Barco Cine 9 the one and only
moome
Posted: Sat Dec 04, 2010 5:16 am    Post subject:
ElTopo wrote:
Moome,
ElTopo
yes~~~
gravy
Posted: Fri Dec 17, 2010 6:20 pm    Post subject:
Ordered back on 11/23. Should I expect shipment before the end of the year?
Steve
richmond5
Posted: Fri Dec 17, 2010 9:48 pm    Post subject:
I already recevied mine 2 days ago!
Alex:)
gravy
Posted: Fri Dec 17, 2010 10:07 pm    Post subject:
Well I hope I receive mine today then ;(
moome
Posted: Sat Dec 18, 2010 2:32 am    Post subject:
most order should ship out before 12/20
barcoed
Posted: Mon Dec 20, 2010 1:08 pm    Post subject:
Well so far no good!
V3 ext has arrived and I can't get a stable picture on any preferred resolution:
1152x864p@75
1920x1080p@48
1920x1080p@50
I get either no picture at all or the right hand part of the picture on the left side of the display and the left on the right with a gap in the middle.
I can’t find a link to a manual and the one or two things I have tried have failed.
I’m about to unplug and return.
prover
Posted: Mon Dec 20, 2010 2:37 pm    Post subject:
Have u tried 3D-playback or "normal" playback?
Perhaps you have a problem with H-shift, have u tried to adjust it?
I have received my EXT V3 last week and normal playback was perfect.
3D playback didn't worked at all, perhaps this was a problem recognizing
my nvidia 3D vision glasses.
Anyway I have sent box back, hope replacement does better.
http://www.bluray-disc.de/blulife/heimkino/prover
View user's photo album (19 photos)
barcoed
Posted: Mon Dec 20, 2010 2:47 pm    Post subject:
I'm not interested in 3D. I'm just trying to get 2d to work. Most of the time I get a "no imput" message from the G70 (unless i'm running a 60hz input). It appears the V3 doesn't like enything unless it's @60. I've given up and have requested a refund from Moome. It's the last time I have anything to do with HDMI.
prover
Posted: Mon Dec 20, 2010 3:15 pm    Post subject:
hmmm.... I wouldn't give up so quickly.
I have an IFB V2 moome card in my 1292 and I must say it is very reliable. On the other hand
the resolutions should work... But anyway I would give Moome a chance, I am sure he is going
to fix the existing problems.
nemmi69
Posted: Mon Dec 20, 2010 9:49 pm    Post subject:
Mine didn't come with any instructions. What are the DIP switches for?
What doesn't kill you is only biding it's time
prover
Posted: Mon Dec 20, 2010 11:19 pm    Post subject:
#1 Black Boost
#2 RGB/Component
#3 Range expand
#4 Reset/input SEL
#5 H-shift/input SEL
I have received a manual via email when Moome confirmed shipping.
I can send u if you wish.
nemmi69
Posted: Tue Dec 21, 2010 10:26 am    Post subject:
prover wrote:
#1 Black Boost
#2 RGB/Component
#3 Range expand
#4 Reset/input SEL
How do you access and use these features?
nemmi69
Posted: Tue Dec 21, 2010 10:27 am    Post subject:
nemmi69 wrote:
prover wrote:
#1 Black Boost
#2 RGB/Component
#3 Range expand
#4 Reset/input SEL
Sorry missed the bit about the manual. Please, if you could send it.
prover
Posted: Wed Dec 22, 2010 11:14 am    Post subject:
nemmi69 wrote:
nemmi69 wrote:
prover wrote:
#1 Black Boost
#2 RGB/Component
#3 Range expand
#4 Reset/input SEL
pm me your private email adress for sending cause unfortunately manual too big for attachment in PM
nemmi69
Posted: Thu Dec 23, 2010 10:36 am    Post subject:
prover wrote:
nemmi69 wrote:
nemmi69 wrote:
prover wrote:
#1 Black Boost
#2 RGB/Component
#3 Range expand
#4 Reset/input SEL
Cheers for the manual...now to build a mount for the projector!
andrewsi
Posted: Sun Jan 02, 2011 5:13 am    Post subject:
The manual for the V3 that came in email says this about HDMI supported display modes:
HDMI support mode table
Table 1
PC mode
640X480 60HZ 72HZ 75HZ 85HZ
800X600 56HZ 60HZ 72HZ 75HZ 85HZ
1024X768 43HZ 60HZ 70HZ 75HZ 85HZ
1152X864 60HZ 70HZ 75HZ 85HZ
1280X1024 43HZ 60HZ 75HZ 85HZ
1600X1200 48HZ 60HZ
1440X960 43HZ 60HZ 72HZ
HDTV mode
480P 60HZ
576P 50HZ
720P 50HZ 59HZ 60Hz 120Hz
1080I 29HZ 30HZ 50HZ 59HZ 60HZ 96HZ*1 120Hz
1080P 50HZ 59HZ 60Hz 24HZ*2 25HZ*2 29.9HZ*2
30HZ*2
1035I 30HZ
3D mode
720P 100Hz, 120Hz
640X480 100Hz, 120Hz
800X600 100Hz, 120Hz
1024X768 100Hz, 120Hz
1. need use powerstrip to set graphic card output this mode
2. EXT-FULLHD V3 support these modes, and will output these signal with same refresh
rate as same as input source, but most CRT projector are only support 30Hz-150Hz,
using such low refresh rate may let projector working with incorrect behavior.
3. when set component output mode, only HDTV mode will support (50Hz, 60Hz)
4. 3D mode only support at RGB output mode
Given that, I wouldn't expect the 48hz mode to work, but the other two seem like they should be supported.
Got mine the other day (finally!) and it has been working great for me straight out of the box. Allowed me to rip out piles of old analog cables and put the Faroudja NRS up for sale on ebay...
dmvining
TV/Projector: nec 135xg air coupled
Posted: Sun Jan 09, 2011 3:06 am    Post subject:
ok- looked around the forum and concluded this as good a place as any. i realize that 3d is important to you higher ranking video magicians; for us apprentices eager to embark on a high definition adventure (ie- hdmi for crt via moome) the more basic question is: does v3 realize a discernable improvement over v2 in 2d? and if so is it dramatic? or... is it all about 3d? ive got hundred dollar bills burning a hole in my pocket to jump on a moome card but which one? currently running ps3 into farojia 401 into nec 135xg. any comments appreciated. thanks, david
