David_Web
| Posted: Tue Nov 09, 2010 7:44 pm Post subject: |
Did you measure any DC?
_________________ SNR of people are ridiculously low.
JJSuperfly
| Posted: Tue Nov 09, 2010 8:45 pm Post subject: |
| Zolzar wrote: |
Boilermaker,
I still see MG sets at least once a week servicing elevators. As you said most are at least 40 years old but they are still out there and being rebuilt quite often. The last new MG sets I know of that were installed new were in 1989. Probably the last ever. Most are rapidly disappearing and are being replaced with SCR drives. |
Boilermaker;
Not extinct yet; we installed a new one in 2001 and used it for testing 9000 hp reactor pump/motor sets. Will probably do the same with the 12000 hp pumps in future as well.
One other thingy; for a boilermaker you seem to be very knowlegable about sparky stuff (i.e. not just sparky tube welding... )
Boilermaker
| Posted: Tue Nov 09, 2010 8:59 pm Post subject: |
| Quote: | Boilermaker;
Not extinct yet; we installed a new one in 2001 and used it for testing 9000 hp reactor pump/motor sets. Will probably do the same with the 12000 hp pumps in future as well. |
There is probably 9,000 reasons why you don't use SCR's!!!
| Quote: | | One other thingy; for a boilermaker you seem to be very knowlegable about sparky stuff (i.e. not just sparky tube welding... ) |
I've tried welding several times - It isn't as easy as it looks, so I thought I would stick with the sparky stuff.
Bob
Zolzar
| Posted: Wed Nov 10, 2010 11:56 am Post subject: |
I did not check for DC. I'll do that this weekend and post my results.
Thanks!
John
Zolzar
| Posted: Wed Nov 10, 2010 9:46 pm Post subject: |
I posted that last message so quickly this morning that I didn't even bother to ask how I would go about checking for DC. How do I use my meter to check for DC?
John
subraman
| Posted: Thu Nov 11, 2010 9:33 pm Post subject: |
| Zolzar wrote: | I have installed the isolation transformer and this thing is much louder than I anticipated. Unfortunately I have no choice but to install it in the utility area right where my HT equipment rack is located. It's actually mounted to the chimney which is sending the "hum" right up the house. I'll install some rubber isolation to help out with that but do you guys think a hush box with a push pull fan arrangement would work to shut this thing up a little?
John |
If your transformer is a Topaz Escort, it happens to be a Ferro-Resonant transformer - guaranteed to run HOT and LOUD! It is also impossible to wire for balanced output.
A Topaz Ultra Isolation unit will work cool and quiet if used within its ratings, but remember to halve its ratings if wired for balanced output.
David_Web
| Posted: Fri Nov 12, 2010 4:17 pm Post subject: |
Most decent DMM measures DC even with large AC signal.
I would not expect any analogue to work.
A scope with readout should work as well.
Zolzar
| Posted: Fri Nov 12, 2010 11:10 pm Post subject: |
Thanks for the information. I did a little research on the Ferro-Resonant transformer and these things are really nice but unfortunately just not for my application. I'm going to call it quits on this one and at some point possibly get around to getting the proper unit for my application.
Thanks to all who assisted me on this project.
John
