dvh99
| Posted: Wed Oct 27, 2010 4:21 pm Post subject: peaking circuit on vim 50-2035-02p |
. pic was wrong
the link i got will do i have to learn to write those things down, cause nashou gave me those values a while back.
dvh99
| Posted: Fri Nov 05, 2010 5:14 pm Post subject: |
peaking is for 1 set frequency, but is peaking dependent on drive g2 brightness and contrast setting?
dvh99
| Posted: Fri Nov 05, 2010 5:20 pm Post subject: |
nash have you tried peaking with the el5166 on the 03p vim?
tse
| Posted: Sat Nov 06, 2010 12:15 am Post subject: |
| dvh99 wrote: | | peaking is for 1 set frequency, but is peaking dependent on drive g2 brightness and contrast setting? |
The contrast setting can have an effect on the peaking. Especially at high settings. What is likely to happen is the one on/one off vertical lines part of the SMPTE133 test pattern will begin turning magenta as the contrast is increased past 50.
Scott
Thomas Jefferson
dvh99
| Posted: Sat Nov 06, 2010 12:20 am Post subject: |
tx scott that is what happened exactly.
so how to prevent this on the 03p vim, add another trimcap on the opamp after the ad834 with a 10ohms in series parallel to the feedback resistor?
tse
| Posted: Sat Nov 06, 2010 11:03 pm Post subject: |
There is only so much that can be done at the VIM level. Better performance ultimately calls for a better neck card. Good luck in finding high bandwidth, high voltage PNP transistors anymore. They have disappeared since CRT sales have dried up.
Scott
Thomas Jefferson
| Posted: Sun Nov 07, 2010 12:23 am Post subject: |
Nothing is/was better than the Motorola's for a discrete high bandwidth power transistor. The Motorola's were very unique mainly because they were high bandwidth RF power transistors that could be used in mirrored operation.
I used to have a data sheet on them.
There are still some NPN RF power transistors available, but the PNP's are no longer available. And that's the main part that prevents this design from still be manufactured.
tse
| Posted: Sun Nov 07, 2010 5:04 pm Post subject: |
The Mot parts are definately the best for this application (the parts on the neck card have the same characteristics as the ones attached other than increased power dissipation because of the package that allows attachment to heatsink).
Sanyo made a line of video output type transistors that could be used for higher bandwidth amps but at lower voltage than needed for the projector CRTs (ok for monitors).
There are a couple of Sanyo parts with the voltage needed but required more overdriving at the limits of bandwidth to match the Mot parts.
I believe that technique could be applied to the Mot type neck cards to get increased bandwidth over standard cards. Peaking network like C68 and R101 could be added to a better opamp. L1, L2, L3, and L7 should be lower value (to resonate at higher frequency). Probably, R84 and R85 should go away. R16 and R24 values would have to be optimized. L4, L5, and L6 might have to be slightly different value.
If attempting this I would recommend first replacing the inductors with 0 ohm jumpers and setting the peaking network for quickest rise and fall times at amplifier output. Then place the inductor values to get the shortest rise and fall times.
When I did this for the new VDC neck card I used 400MHz scope, 500MHz probes (that were close to the CRT capacitance), and pulse generator with rise/fall time less than 1ns.
Scott
| Description: |
| Filesize: |
19.95 KB |
| Viewed: |
8665 Time(s) |
| Description: |
 Download |
| Filename: |
MRF545.pdf |
| Filesize: |
83.24 KB |
| Downloaded: |
328 Time(s) |
| Description: |
 Download |
| Filename: |
MRF544.pdf |
| Filesize: |
82.1 KB |
| Downloaded: |
338 Time(s) |
Thomas Jefferson
dvh99
| Posted: Sun Nov 07, 2010 5:49 pm Post subject: |
if i understand correctly this peaking isnt dependent on resolution but only sets the amp for fastest rise and fall with the proper inductor values.
very helpful answer, thanks again.
http://www.farnell.com/datasheets/5092.pdf
dennis
tse
| Posted: Sun Nov 07, 2010 6:59 pm Post subject: |
| dvh99 wrote: | if i understand correctly this peaking isnt dependent on resolution but only sets the amp for fastest rise and fall with the proper inductor values.
dennis |
If rise and fall time is fast enough then the ringing and overshoots from overpeaking can be avoided. It also allows the amp output to be at "black" or "white" for a longer time which makes the pixel more distinct. The pic shows 0 rise/fall time and tr/tf = 1.9ns (10 to 90% of peak to peak) with pixel on/pixel off video at 400MHz pixel clock. BW can be approximated by 0.35/tr (or tf) or tr (or tf) can be approximated by 0.35/BW.
Those inductors would be good choice. High Q above 100MHz and self resonant frequency above 200MHz.
Scott
| Description: |
| Filesize: |
20.06 KB |
| Viewed: |
8643 Time(s) |
Thomas Jefferson
| Posted: Mon Nov 08, 2010 3:40 am Post subject: |
Well i adjusted the peaking circuit tonight to have it set for 96hz refresh rate. Now I have to redo my Calibrations on both PJ's as it screwed it all up!!
One thing I noticed Scott is the pattern changes color as you move out from the center of the screen. Probably because of the light drop off on the edges of the tube. I wonder if this would be a good way to do contrast modulation? Move the pattern to the edges and corners and then adjust the color zone contrast till the vertical and horizontal boxes match intensity? Would that work?
dvh99
| Posted: Mon Nov 08, 2010 4:06 pm Post subject: |
as if you like the pj to be set up so you cannot play with it anymore
| Posted: Mon Nov 08, 2010 4:27 pm Post subject: |
| dvh99 wrote: | as if you like the pj to be set up so you cannot play with it anymore  |
I should have left it as is for a while , I was actually watching movies!!!!
Iron Man 2 look really really incredible!!!
But now I have a reason to test my theory on adjusting the Zone contrast using the 1 on 1 off pattern . I have it set for the center of the screen now. So with scots info that contrast G2 etc plays into it I think this could be a way to adjust the outer and corner zones. set the pattern so it looks best in the center and then move it to the outer edges and corers and adjust the contrast for each color to get the pattern to look the same as it did in the center. then go back to the center and re adjust.
then back again till no more adjustment is needed and the pattern looks correct in all locations. I bet this will take forever but it will be worth it !
dvh99
| Posted: Mon Nov 08, 2010 4:56 pm Post subject: |
getting the peaking right should be done first.
when doing peaking brightness is increased because the hor resolution isnt attenuated as it was before.
you will actually need less gamma because now i have much more shadow detail with a lower gamma setting.
g2 didnt have an effect from what i saw on the peaking its only the contrast setting so once set do not touch the contrast button.
i really want to play further with the neckboards to see if this horizontal overshoot can be reduced so i get an almost black white 1 on 1 off.
| Posted: Mon Nov 08, 2010 5:09 pm Post subject: |
What happens when i move the pattern towards the edge using the phase you can see the pattern get a green tint to it.
Put up the pattern and shift it towards the edge of the tube in the center and see what happens. you can turn the trim pot while at the edge and fix it but wen it goes back to the center obviously it will be off there now. I think we need a zone peaking circuit lol
dvh99
| Posted: Tue May 03, 2011 4:31 pm Post subject: |
i haven`t done anything to the neckboards yet (besides changing out the electrolytes, opamp and carbon resistors) but i still have some inductors and varicaps to play with.
the question is what values i should be thinking of for r16 and r24 (they are 390ohm).
scott said they should be slightly different, but what is slightly?
all help is welcome.
dennis
edit: almost forgot about the smb connectors , that has been done too.
| Posted: Tue May 03, 2011 5:46 pm Post subject: |
It's an odd question, and off topic too, but: is there any tweak to make better the old and creepy -03p VIM, or the only way is the replace?
