jask
| Posted: Mon Oct 04, 2010 5:10 pm Post subject: |
um..
ahhh.....
wow.
four 909..... porntastic.
| Posted: Sat Oct 09, 2010 3:19 am Post subject: |
Peri,
I am not sure what is going on, but I will find out in the next week or two.
I haven't forgotten about these. I have decided to pack them all up and take them with me down to Miami. It is going to be easier to work on them in a dedicated room. If one ends up being a part's mule, then I am going to put the lugs into the G90.
I was going to stop by tse's place and do a shootout, but it doesn't look like that is going to work out this time.
| Posted: Sat Oct 09, 2010 2:34 pm Post subject: |
| Spanky Ham wrote: | Peri,
I was going to stop by tse's place and do a shootout, but it doesn't look like that is going to work out this time. |
That would be really cool to do, but a LOT of work as well. Just hauling the projectors in and out and then doing all the setups correctly...
| Posted: Sat Oct 09, 2010 3:33 pm Post subject: |
| Spanky Ham wrote: | | I have decided to pack them all up and take them with me down to Miami. It is going to be easier to work on them in a dedicated room |
When you get to a place of checking them out, call me and I'll show you how to best do that.
Scott has the perfect generator for this.
| Posted: Fri Oct 22, 2010 3:47 am Post subject: |
I wanted to update this, as I still haven't gotten around to playing with them. I somehow acquired a roommate and he has decided to take over. I thought I was at least going to have the garage, but he has taken half of that and there is little room to get these things spread out. I will probably get to them next week hopefully. I think I am going to start with the G70s and then go to the Barcos.
| Spanky Ham wrote: | Mike,
I have been meaning to ask you. Do the 1209 parts fit the 909s? |
| Curt Palme wrote: | | No, none will. I have some 909 parts, and can fix others. |
That is good to know. I have to go through all of them, since only one is working correctly at the moment.
| Spanky Ham wrote: | Do you want a whole 909? |
You will probably get your wish.
| Posted: Fri Oct 22, 2010 12:52 pm Post subject: |
if only one is working, I'll take teh other three.
Didn't you post originally that you went down to test them and that all worked and showed an image?
| Posted: Fri Oct 22, 2010 4:15 pm Post subject: |
No, Nash said all of them worked. I only tested one and assumed that the rest worked. You know what assume means. I have to go over them again, but I get a raster I think on two but no image. I need to check the inputs. The other one goes to standby only and I have swapped the boards in the rear from the good one to this one with no luck.
