G90 pricing and comparison vs 9500LC Ultra
Goto page 1, 2, 3  Next
timeo
Posted: Mon Sep 27, 2010 1:29 am    Post subject: G90 pricing and comparison vs 9500LC Ultra
I have a dilemma here. I currently own a 9500LC Ultra with little to no wear on the tubes. This machine runs great but I have the option of picking up a G90 with no wear for about $1700. The G90 is a newer machine but obviously harder to get repaired and find parts for. Any opinions on how the G90 compares to the 9500, would there be any noticeable difference by switching to the Sony? Also, any ideas on what a G90 and a 9500LC Ultra are going for today, I have not tracked prices since I bought my 9500 for $5,000 back in 2004.
Thx
secstate
Posted: Mon Sep 27, 2010 2:26 pm    Post subject: Re: G90 pricing and comparison vs 9500LC Ultra
Thx
I think a G90 is considered up there as the top of the heap along with the 909. The standard lenses on the G90 in particular are considered top notch (the top 2 or 3). The G90 also comes stock with the high resolution tubes. From what I understand a 9500LC can be the equal of the G90 with mods/right lenses/high resolution tubes. I have never seen a G90 but I have seen a 909, 9500LC and a Barco 1209/s. They all perform excellently and honestly on video material the difference between them are subtle to my eyes. All that said the one thing that would keep me away from a G90 are the fact that there are currently some unrepairable problems with them these days. There is at least, one possibly two chips that fail and cannot be replaced other than raiding another G90. That said in parts a G90 with decent tubes is probably worth close to $1700. Pricing on sets is dropping like a rock if they don't come from a trusted reseller with a warranty. I'd say a 9" set in good condition for less than $2000 is a good but not "hot" price. Many 9" sets have gone for less than $1000 of late. Of course this is in North America if you are located elsewhere prices are likely to vary greatly and most likely be more expensive.
Posted: Tue Sep 28, 2010 2:25 am    Post subject:
Sec,
The pricing bottom happens every summer. Enthusiasts tend to do other things during the summer. When fall comes everyone gets back to watching TV and movies. That is when the prices return back to normal. Of course that being said, if Curt offered me $10k for my four Barcos and one G90, then I might be tempted.Smile
Posted: Tue Sep 28, 2010 3:00 am    Post subject:
With the scarcity of Barco quadruplers right now, that might be a bargain! Mr. Green
secstate
Posted: Tue Sep 28, 2010 12:45 pm    Post subject:
Very Happy very true indeed.
secstate
Posted: Tue Sep 28, 2010 12:49 pm    Post subject:
Spanky Ham wrote:
Sec,
That is true to an extent but the peaks are getting shorter and the troughs deeper. The overall trend is down and I have seen a fair number of 9" sets for less than $1000 (sometimes considerably less) during the non-summer seasons of 09 and 10 and plenty at or below $2k. My two 9" sets were acquired in February 2009 for far less than $1k. I think the prices (or rather number of projectors sold) for resellers probably see more of more of a dip in the summer than those of us (myself included) who play surplus roulette because we are always looking for a deal.
Elaine Benes
Posted: Wed Sep 29, 2010 9:52 am    Post subject:
Having seen, setup, and used both a G90 and a 9500LC, the G90 is easily and noticeably better. You will definitely see an improved image, sharper, and brighter, it is IMHO, quite an upgrade.
However, at this late stage of the CRT projector game, you'll be fairly lucky to find someone willing to pay you $1700. for your Marquee...
One caveat, the Marquee 9500LC's I've had have all been non-Ultra's, if the Ultra chassis is a HUGE improvement over the regular, perhaps they are closer to the G90's stunning performance, but I'd be pretty surprised. The G90's electronic astig/focus ability alone enough *for me* to rate it as superior to any other projector I've had...
I'm not normally a Sony fan, but the G90 is simply superb in every aspect of image performance.
Posted: Wed Sep 29, 2010 2:16 pm    Post subject:
If the Marquee isn't color-filtered, the color-filtering alone on the G90 would be a significant upgrade.
Posted: Wed Sep 29, 2010 3:46 pm    Post subject:
Comparing stock projectors performance and setup ability between the 9500LC Ultra and G90, the G90 wins hands down in every category. The G90 has a much better menu system, lenses, flapping, magnetics, bandwidth, and everything else. The G90 does not usually even need to be opened to do a full setup and the Marquee does. Actually, you will need to spend hours with the Marquee open to do the magnetics properly and to adjsut the flapping and set the width coils. You also should use a special plastic wrench to set the width coils on the marquee (though I use an alan wrench wrapped with electric tape).
The G90 is very well built and when you open it up on the ceiling everything stays in. Wires are neatly tied up and well thought out in their placement. The Marquees are rigged together and when you work on them on the ceiling you need to use straps or tape to secure the boards otherwise the deflection and other boards will fall out of the projector while you are working on it. The Marquee has wires running every which way all over the place and it is generally poorly laid out The high voltage block is in the way of everything and you have to let it hang down in your face whenever you need to get into the front of the Marquee.
A stock G90 has better focus (especially in the corners and sides), bandwidth, gamma, brightness, and oeverall a much better image with a few exceptions. The G90 does have a little streaking though and a good condition Marquee 9500 Ultra does not streak. Other than that, the G90 has better performance all the way around in every category.
However, if you are a serious tweaker and you heavily modify a 9500 Ultra you can actually get better bandwidth out of the Marquee than a G90 at this point. Mike Parker's newest VIM and VNB's really up the performance to a new level on the Marquee. The problem is that he may never release the VNB's to the public and the VIM is yet unavailable so the performance is theoretical for the most part now. I have seen Mike's mods running at his place and have a set of his boards installed on one of my client's Marquee's. The upgrades make me wonder which projector I would rather have in my home right now... On the Marquee you also need to swap lenses with lenses from a G90 for best focus, and the focus on the sides and corners of a Marquee will still never be as good as the G90.
The Marquees fail more often than the G90's and usually require more frequent repairs. However, Marquee parts are easily available through Curt or VDC and are not usually too expensive. G90's rarely fail, but if IC421 goes out on the YA board you can't get the part. As posted earlier, the only option is to find a parts G90 and get a new YA board. I usually sell YA boards for between $1000 ~ $1500 and try and keep them in stock, but I don't always have them. That being said, I think the problem is over stated on the G90's as I have never had one of my own client's 421 fail and I service a lot of G90's regularly.
I work with Marquee and Sony projectors often and I strongly prefer the G90 in terms of performance and setup.
Posted: Wed Sep 29, 2010 3:55 pm    Post subject:
Depends on model. Some come with no filtration, some green only, and some red only.
Posted: Wed Sep 29, 2010 5:52 pm    Post subject: Re: G90 pricing and comparison vs 9500LC Ultra
Well, for starters, your theater would be a lot better looking... Wink
secstate
Posted: Wed Sep 29, 2010 5:58 pm    Post subject:
That is true, I forgot that the 909, 9500LC (green but no Red) and 1209s were all NOT (fully) color filtered. That would make a big difference.
Posted: Wed Sep 29, 2010 6:07 pm    Post subject:
The Vision Ones and Madigrals I do think came with both Red and Green as did a few other boutique Clones. To truly get the G90 better colors you need a green C from a Marquee or the 1292.
Posted: Wed Sep 29, 2010 6:08 pm    Post subject:
The G90 only has a partially filtered green and the red is always filtered. G90 used a lighter green that doesn't make Rec709, but gets it closer than clear does. You can change out the G90 light green c-element with the darker one though and then all is well. Or just leave it alone for a brighter picture which is why Sony did that in the first place. I recommend changing to the dark green filter though.
Posted: Wed Sep 29, 2010 6:10 pm    Post subject:
The Madrigal 9500LC Ultra has correct green and red filters installed. The case looks a lot nicer than the industrial Marquee as well.
timeo
Posted: Thu Sep 30, 2010 2:58 am    Post subject:
Thanks for all the information, tough decision for me as I am not sure it is worth another $700 - $1,000 to switch out the 9500. My 9500 has the GT17 lenses which I thought were the best ones, what lenses does the Sony come with?
Posted: Thu Sep 30, 2010 3:01 am    Post subject:
They have the HD 10F's but the Best are the HD 10E's or also known as the HFQ-900's.
dvh99
Posted: Fri Oct 01, 2010 5:57 pm    Post subject:
stick with your marquee do some mods and it will be just as good as the g90 if not better.
i have never seen a g90 in action but i cannot imagine the g90 to be superior.
Posted: Fri Oct 01, 2010 6:02 pm    Post subject:
You know i am a Marquee guy but i have to say, Yes the G90 is better. The reason i disnt get one at first was price and you really do not need to mod it. I enjoy doing mod work so i got it for the shear hobby factor. if I wanted one just to set up and watch it would be a G90 or 909. Wait i have a G90 and getting a 909 !!!!
Wink
Elaine Benes
Posted: Sat Oct 02, 2010 4:05 am    Post subject:
You really do need to see a G90, they ARE superior, in every way. For the cost of making a Marquee close to as good(but not better...) than a G90, you could buy several G90's, or a couple 919's...
Page 1 of 3
